SOURCE: my micromax x600 mobile asking input phone lock code
visit www.hard-reset.com or see the result.Hard reset
Cold boot method: Hold the "Power Button" of the Pocket PC with one
hand while holding the stylus tip to push in the "Reset Button" with the
other. Simultaneously release both the "Power Button" and "Reset Button".
Appropriate situation: If a previous reset has already been attempted and
the Pocket PC is still unable to maintain normal operations, has no
response, or if the screen is frozen.
Before executing the preceding "Cold boot method", please carefully
consider the following instructions and then decide on the cold boot
method.
1. After a cold boot is performed, if no buttons are pressed, when Pocket PC automatically completes the system startup process, the last display will be the Today screen. This is identical to the reset result.
2. If a previous reset has already been attempted but the Pocket PC is still unable to maintain normal operation, consider the following solution:
After cold boot, hold the End Button on the bottom right of Pocket
PC until the system inquiry screen is shown, and then release the End
Button. Next, please read thoroughly through the instructions on cold
booting before continuing carefully.
Erase all data and load default?
The default is "No." If Yes or No was not
selected, after a few seconds the system will
automatically execute the default No.
If you long press Left Soft-Key for a few
seconds to select "Yes," then the system will
erase all data and load default. After your
Pocket PC restarts, follow the instructions on
the screen to complete.
Caution!
1. After performing a cold boot, the system will retain Microsoft Windows
and pre-installed programs. If you answer "Yes" to the question displayed
after a cold boot, other items such as the user's input data, newly installed programs and user settings will be lost.
2. There are two ways to retain your data, loaded default and registry:
Perform a Reset.
Performing a Cold Boot, and answer "No" when the above question
displays.
sir g if u open ur phone self u are se there main bord right side down a little jack . there wire are going down to main speekar cecuit there jack or there wire are if not connect properly then other butten are not working
