Question about Whirlpool Dishwashers
My dishwasher is not pulling in water
When I turn on my dishwasher there is no water going in to it
  • Whirlpool Master
  • 19,396 Answers
Check that the inlet hose is not kinked or blocked, and ensure that inlet line has sufficient pressure.
Check that the water level switch is not stuck.
Try unplugging appliance power cord for five minutes (or trip circuit breaker) to reset appliance control board.
If you do not find anything, then there is probably a fault, parts to be tested are inlet valve (Ohming solenoid, energizing), Water level (bridge it, read continuity), and control board by reading volts. On some model you may also need to test pressure switch located near to the pump.
Posted on Jul 25, 2009
Gsd3660g00ss leaking water
Hi Bob sorry to here of your problem , the only thing i can sugest is to remove the two screws at the top of the dish washer they screw into the counter top and pull the
dish washer towards you , it should have long wires and tubeing for the water so that you can pull it out then turn the water back on and see where it is leakingfrom . I would guess the water valve or the tubeing going to or from the water valve pull it out and get back to me i will be on and off here all day let me know what you find Frank
Dec 15, 2011 | GE Nautilus 24" Built-in Dishwasher
Hotpoint dishwasher buzz when turned on an thats all it does
If the buzz stops when you open the door it could be the water solenoid valve which if it is not filling with water there is a 90% chance it is the valve. Turn off the water supply going the dishwasher under the sink or by the pipe. Pull the dishwasher out and unplug it if the hose length allows it to pull out. Put a towel or pan under the dishwasher hose connection disconnecting the hose on the dishwasher valve. Remove the racks and tip the unit forward with the unit unplugged and unbolt the valve where the water inlet is connected. Undo the hose clamp and wire connector. Check the valve or order a replacement and reinstall clamps and connectors. Be very careful when using the unit the first few times that no water leaks from hose connections by using a tissue touching the connections to see if water is present. Mold sucks so use a flash light looking in the front panel and tissue even after replacing the unit back in its final place.
Jul 14, 2009 | Hotpoint Dishwashers
GE Profile Max Dishwasher
I,m not familiar with this make or model but all spray arms should be removable bottom normally pulls off top quarter turn and pull and the back water feeding tube can also be removed usually by clips.rinse through thoroughly and hook out food stuffs with needle from the eyelets.the cause is general build up but mainly pips seeds rice etc.solution is to rinse plates before going in machine also checking filter is firmly in place before wash cycle.remove and check filters regulary. hope this helps
May 18, 2009 | GE 24 in. Profile PDW9200J Built-in...
No water going to the dishwasher
actually there is a pump that moves the water threw channels. this pump may be experiencing motor issues. i would find a repair man or, if you good a disassembling the dishwasher, you can extract this part and replace it at you local appliance shop.also, this pump assembly could be jammed as well due to an object.
Feb 07, 2009 | GE Adora GHDA654LBG Dishwasher
Our dishwasher goes straight from rinse to the endwithout going through the washing cycle. How do I change the cycle? Have tried holding the button to change the cycle, but doesn't change. The dishwasher...
It turned out that the pipe bringing the water into the machine had a kink in it. We pulled the machine out and straightened it. A dishwasher technician suggested we look to see if the pipe taking water away from the machine might be the problem, but it was the incoming water pipe.
Jul 24, 2008 | Dishwashers
Dishwasher won't work
9 times out of 10, when this happens, the fill valve has gone bad. Thats the little valve with 2 wires that your inlet waterline attaches to. They are inexpensive to buy and easy to install. You normally don't even need to pull the dishwasher out. To test the dishwasher before you go to the trouble, pour a bucket of hot water into the dishwasher and turn it on. You'll have to wait a couple of minutes before it will turn on. If it works properly spraying the water around inside, then it's just a bad fill valve.
Mar 04, 2008 | Dishwashers
Kenmore 18inch Portable Dishwasher
how is the water flow at your sink this is a portable right un screw the connector at the sinkand check the screen 2 your fill hose could be kinking up when you pull it out take a light and look down into the washer see if you can see it kinked we will go from there
Dec 31, 2007 | Dishwashers
Dishwasher fix
something has gotten passed the screen and is jamming your pump impeller pull lower spray arm pull screen and see if you can find what is jamming the impeller and remove it drain pump is separate
Dec 30, 2007 | Maytag MDB7100AWB Dishwasher
Bosch dishwasher SHU9922UC
Sounds like you already know how to fix it. The inlet valve is only held closed by water pressure...if you have low water pressure it could be causing this. Its more likely just a bad fill valve though. The water inlet valve is accessed by removinf the lower kickplate and the sheild behind that. Then all you have to do is remove the water line from the valve, remove the 2 screws holding it and pull it out far enough to disconnect the 2(possibly 3) wires and the fill hose. Make sure to mark where your wires go, if you hook it up wrong it could continue to fill and overflow. Hope this helps!
Feb 01, 2007 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwasher water comes in and goes stright out of drain
is the drain upto specifaction? sounds like its siphoning. should be in your manual
Sep 22, 2006 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwashers Logo
111 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
