SOURCE: Power LED blinks red
it is a bad fan. it also could be a power supply. Quite often the real problem is dirt clogging up the fan(s) to the point that they need to be replaced. Operation of the set in a dirty environment is not a good idea
SOURCE: Panasonic PT L501U Projector
Right , if the indicator light goes from Green to Orange when shutting down , it will be the Powersupply that is giving problems and not the Ballast.
SOURCE: Infocus X1a no picture, solid green LED
if the lamp is new, it could be the power supply (the ballast is built in to the ps). but make sure you have the right lamp. the X1 and X1a have an sp-lamp-019 and the similar X2 and X3 have an sp-lamp-018. the lamps are almost identical except for the wire configuration on the lamp plug. make sure the wires in the plug match the positions in the socket. also, when you turn it on, if you don't hear a high pitch squeal, the colorwheel is not working. and if that isn't working, the lamp won't either. also check to see if the lamp door is closing properly and hitting the switch at the top of the opening.
SOURCE: REPLACED LAMP AND LAMP BALLAST IN SAMSUNG HLS6187 - NOT WORKING
the problem will be the board
SOURCE: rca lamp replacement, still no picture, power light still blinks.
Ballast Board #261629 Ballast is what turns Lamp on, Also Check your Lamp Fan if it is defective Lamp will not Light!
