Question about RCA DIRECTV Satellite Remote Control
Got a new RCA tv, can't program the charter remote to turn the tv off or work the volume. have tried different codes for RCA, nothing works.
fixyadude1
  • 57 Answers
SOURCE: RCA remote
Could it be possible that the remote needs reconfigured? If none of the buttons work, the it could possibly be that you need to re-enter the TV code back into the remote.
Posted on Sep 24, 2008
  • 17 Answers
SOURCE: Insignia TV code for RCA Universial Remote Control (RCR450)
If its a four digit code remote. I may be able to help.. Try these...0171, 1204, 1326, 1517, 1963, 2002..
Good luck
Posted on Nov 11, 2008
  • 4 Answers
SOURCE: Need updated codes for RCA RCR860 remote control
If this is the post about the RCA remote and the Emerson TV, try 189. I have found the Emersons are NOT easy to program using universal remotes. I happened to stumble across the 189 code by accident and it works for the one Emerson (analog, 20" flatscreen) TV, but not an older model nor any of the Emerson VCRs that I used to won.
Posted on Mar 02, 2009
SOURCE: Broksonic TV code for RcA RCU704 remote control
I had a similar problem with a 1994 vintage Broksonic TV. I called the company (Hatzlachh Supply Inc. @ 800-333-9099). Broksonic TVs are not compatable with any universal remotes! You need an original factory remote. Remote for my set cost $20.00 plus shipping for a total of $24.95.
James Benson
Posted on May 27, 2009
  • 814 Answers
SOURCE: I need codes
Codes for direct TV are 200,201,202,203,204,205,206,207,208,209,210,211,212,213,214,215,216,217, CODE INPUT SETTING:
You will need the list of codes to manually select and input the correct codes to your
specific device.
1. Turn on the device that you want to set.
2. Look for the brand name under the specific device listing provided.
(Note: You will notice that some brands will have more than one 3-digit code. During the
code input process, you may have to try more than one 3-digit code that will match your
device brand and model.)
3. Aim the remote control at the device and press down and hold CODE SEARCH button for
at least 3 seconds until the red LED lights up solid red.
4. Press the device button for the item you wish to program, e.g. TV, DVD, VCR, etc. and the
LED light will blink once and then remain solid red.
5. Using the number keys, enter the 1 st set of 3-digit codes from the list. You will notice
that each number that you press, the LED will blink once. After you have entered the
3rd digit, the red LED will turn off indicating that the code was recognized for the device.
(NOTE: If the code entered was not compatible, the red LED will flash several times.
You will then need to repeat Step 3. You have 30 seconds to enter a code.)
6. After the red LED light has turned off. Press the ON/OFF key. If the device you are trying
to program powers off, then you have found the correct code. If the device does not
power off, then you will need to repeat the process again from Step 3, using another
3-digit code.
7. Make a note of the 3-digit code for future use.
CODE SEARCH SETTING:
This is an alternative method to programming your device without using the code list. The
remote control will scroll through the list of codes to identify the correct code for your
device.
2. Aim the remote control at the device and press and hold down the CODE SEARCH button
for at least 3 seconds until the red LED lights up solid red.
3. Press the device button for the item you wish to program, e.g. TV, DVD, VCR, etc. and the
4. Press ON/OFF button on remote slowly and repeatedly until the device you are trying to
program shuts off. (Note LED will blink once each time you press ON/OFF button)
5. Once this occurs, press ENTER button to store the code and the LED light will turn off I hope this information helps you with you remote controls problem. Thank you for using FixYa and have a nice day!
Posted on Jun 19, 2009
Need remote code list for my element tv
Element TV remote codes
Codes to operate your Element TV:
Newer codes 5 digit:
11886
10178
11687
12183
Older codes 3 digit:
046
005
028
043
048
076
096
155
004
051
127
151
153
154
231
236
238
247
252
168
121
ON MOST REMOTES:
1. Turn on the TV.
2. Press and hold the TV and SEL buttons simultaneously for 3 seconds. The button will light.
3. With the button lit, point the remote at the TV and enter the TV's 3, 4, or 5 digit code.
4. Verify by pressing the VOLUME + button. This should turn the TV VOLUME up.
5. Press the TV button to store the 3, 4, or 5 digit code. The button will blink twice to confirm the code is stored.
Your Element TV can be controlled with a universal remote and work with RCA remotes, Comcast, DirecTV, Charter, and more.
Jan 29, 2018 | Element Televison & Video
Working my RCA T.V with my Dish network remote
Download a list of programming codes for your specific "Dish" remote that are applicable for RCA TVs:
https://www.mydish.com/support/products/remotes/how-to/program-to-tvother
The RCA brand has many codes since it has been built by different manufacturers over a long time. Try each one.
If no RCA codes work, and it is a newer LCD or LED TV, try programmable codes for SONY televisions, as the RCA brand seems to use the same codes as SONY for some features like Power/Volume Up Down/Channel Up Down.
Best of Luck.
Nov 15, 2017 | RCA Televison & Video
How do I program a charter remote to a rca converter box
Charter 1060BC2 and 1062BC3 - Setup
www.urcsupport.com/html.php?page_id=762
SETUP. The Charter 1060BC2 and 1060BC03 Remote Controls are preprogrammed to operate the cable box (converter) provided by your cable system, an RCA TV, a Toshiba DVD player, and a Pioneer audio receiver. To control devices other than the default brands, perform the following steps; otherwise skip this section.
Program the Digital Cable Remote Control
mscharter.custhelp.com/app/.../program-the-digital-cable-remote-control
Dec 10, 2013 - Highlight or write down the codes and device you wish to programbefore moving on to Step 2. On the remote control, press a device key once (i.e., AUX, DVD , AUD, TV or CBL); it will blink once. Then, press and hold SETUP until the selected mode key blinks twice, then release SETUP.
Charter.net Charter Remote Controls - 1060BC2/1060BC3
www.charter.net/.../charter-remote-controls-106...
Charter CommunicationsProgramming Codes: Select the manufacturer of your device from the list. The codes will appear beside the list boxes. Not all manufacturer brands listed may be ...
Charter.net Charter Remote Controls - OCAP-4
Jan 21, 2016 | RCA Televison & Video
Why doesnt the volume on my remote control work?
The wrong code on the remote has been used. Though some codes will work parts of the system only the right code will operate all.
If you don't know the code for the TV, then you will have to try ALL the codes until you find one that operates all the controls.
Aug 09, 2017 | Charter Ltd Ocap-4 C4000 & S4000 4-device...
I have an ol RCA tv, new dish remote everything works but the mute button...i can raise and lower volume, turn off and on but not mute
Hi there Stacey, my name is Kimberly and I form part of the Social Media Department with DISH. We do not promise that our remote will control all the functions of you TV. The codes used to program your DISH remote to the TV may be limited to some functions. You can try addressing your remote to the TV using different codes. I have listed the steps below to assist with programming the remote to your TV. If you have any other questions, let me know at Kimberly.escobar@dish.com!
You can lookup the different codes here: http://www.mydish.com/support/apps/remotecodes.aspx?WT.svl=leftnav
1.) Press and hold the clear TV button until all mode lights light up.
2.) Release and TV light will be blinking.
3.) Enter code and press #. The TV button should flash 3 times.
4.) Try functions (Volume, Power, etc..) and see if it is working.
5.) If no function, repeat steps 1-4 with another code.
Kimberly Escobar
Social Media Representative
DISH L.L.C
Feb 27, 2014 | DISH Network Televison & Video
Need the number code for rca tv
I hope that after 9 months, you have gotten this resolved but if you have any problems, or you have another remote you would like to program, here are some simple steps!!!
The first instructions here are for a power scan, which scans the tv for the correct code for the remote. You just hold down the clear TV button until all lights at the top of the remote light up, then press the Power button, then press the up arrow about once a second, until the tv turns off. If the tv turns off, press the # (pound) button. Try your volume and to power the tv on/off. If one or both of these do not work, start the process over.
If you want to use only codes, here are the steps:
1. Hold down the clear TV button until all lights at the top of the remote light up.
2. Punch in the 3-digit code (provided below for RCA tv.)
3. Press the # (pound) button
4. Try the volume, and to power the tv on/off. If one or both do not work, start again at step 1 with a different code.
503
652
646
Becki Barned
DISH Network Customer Service
May 15, 2010 | DISH Network IR Remote Control
I need a remote code for my RCA TV . Comcast Cable provided a remote for their digital adapter and was told to enter one of the RCA codes. None would work. Comcast and RCA told me to use both remotes which...
your rca does it have a button for cable. then you can program your tv remote to work with the cable box. go to the manual and try all the codes for rca tv. if this does not work then you have to try it manually. have them give you a different adapter. it might be in the box or remote.
Feb 09, 2010 | Televison & Video
Volume
You have programmed the wrong code. If this is a 3 digit code try 189 or all the Funai/Emerson codes for the RCA remote.
Apr 30, 2008 | Durabrand DWT1905 TV
Remote control codes
You need remote rc64 to control the Olevia 32 inch LCD. You can call Directv and order the remote. Use code 11610.
Oct 15, 2007 | Olevia LT32HVM 32 in. LCD Television
ILO universal remote code
I had the same problem trying to program my satellite remote to work with the ILO tv. I found that the emerson codes DO work. Yes local cable remotes will work as long as you have the code and the brand is getting more popular. The code that worked with both cable companys, Charter and DirecTv was 10171 I believe. You can find it under the Emerson codes. Hope this was helpful.
May 23, 2007 | iLO 3200 32 in. LCD Television
RCA DIRECTV Satellite Remote Control Logo
717 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
