Question about Belling Freezers
IT KEEPS FREEZING VERY BD AND SO MUCH O THAT WE
IT KEEPS FREEZING VERY BAD AND SO MUCH SO THAT WE CANNOT GET FOOD IN DRAWERS OR CLOSE THE DOOR AND DONT KNOW IF WE NEED TO DEFROT AND START AFRESH AGAIN WITH THE WHOLE THING!! IT IS APPROX 4 YEARS OLD AND WE NEVER HAD THIS PROBLEM BEFORE. THERE ARE 2 LIGHT COMPONENTS AT END OF FREZER AND WE ARENT SURE IF BOTH SHOULD BE ON OR JUST ONE OF THEM AND AT WHAT SETTING FROM 1 TO 7
THANKS
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 162 Answers
Turn 2 lowest setting and if it continues to run u may have a bad thermastat.
Posted on Jul 26, 2009
Why is my upright freeze is not keeping food frozen
Good Morning Friend, thank you for allowing me to assist you!
If your Frigidaire freezer is not cooling, it could have floating restriction in the line or something more complicated like an issue with the sealed system that only a professional can repair. This can include the compressor not working, the evaporator fan not turning, or even coolant in the lines at incorrect levels to properly cool. It is typically normal to hear the compressor running, humming, or even to be a little warm. However, if you do not hear the compressor at all, I suggest cleaning your freezer out including the coils you can reach (typically located in the bottom behind the toe grille) and make sure no food items are blocking any vents in the unit. Also try checking and see if the door seal is bad; place a dollar bill between the body of the freezer and the door. Now close the door. The dollar bill should stay in place and pull out with a small amount of resistance. If the dollar bill falls out when placed between the gasket and cabinet double check to see if the door is being blocked by anything stopping it from closing. If any of these suggestions prove to be ineffective, connect with a professional to accurately pinpoint any potentially more serious issues.
Best regards! - Z
May 18, 2014 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
I have a hotpoint freezer fza34 The red high temp
it could be that your fridge,freezer setting is not turned up high enough to keep the freezer cold enough.turn it up to setting number 5 at least and if that dont do it u could have a faulty thermostat.have it checked by a engineer.
Oct 30, 2013 | Freezers
FRIGIDAIRE CHEST FREEZER WILL NOT FREEZE FOOD OR KEEP FROZEN
Hello Cory Mitchell - If your freezer is not cooling, it could have a floating restriction in the lines or something more complicated like an issue with the seal system that only a professional can repair. This can conclude the compressor not working correctly, the evaporator fan not turning, or even coolant in the lines at incorrect levels to properly cool. If the compressor was running, humming or even a little warm then that was typically normal. Also try checking and see if the door seal is bad; place a dollar bill between the body of the freezer and the door. Now close the door. The dollar bill should stay in place and pull out with a small amount of resistance. If the dollar bill falls out when placed between the gasket and cabinet double check to see if the door is being blocked by anything stopping it from closing. If it proves to be ineffective, connect with a professional to accurately pinpoint any potentially more serious issues.
Feb 13, 2013 | Frigidaire FFFC07M2KW 7.2 Cubic Foot Chest...
My kenmore is not pressure sealing
the problem is that the compressor is not working
call a technician for a proper diagnosis
and it is not a pressure sound but a vacuum sound as the door when closed drops the temp inside the unit and that creates a vacuum making the door temporarily hard to open
May 15, 2017 | Kenmore Elite Side By Side Refrigerator -...
Our chest freezer isn't keeping food on top frozen although the bottom is still frozen solid?
Most times this is a bad cold control, but there are other things to check for. Make sure the condenser fan is working and the coils are not covered with dust. A separated heat exchanger ( small capillary tubing soldered to the large suction line ) can separate from one another and make the fridge run too long. - tape tubing back together. A poor working evaporator fan motor could also make the fridge run too long and freeze - replace the fan motor. An inefficient compressor or refrigeration system could make the fridge run too long and freeze - have a service tech check this out. A misaligned control settings, make sure the air damper and cold control have not been bumped and are out of normal settings. Stuck open air diffusers or air dampers are becoming more and more common for allowing too much air to be blown into the fresh food section and freezing things. On all frost free fridge's the freezer temp air is blown into the fresh food section, if you have "easy" to freeze items ( eggs, veggies in water, etc ) in front of or under where the freezer temp air comes out, they could freeze - store them in a different spot. Doors not closing properly making the fridge run too long is something else to check for.
Hope this help in solving the problem....
Jan 11, 2011 | Freezers
Food is not completely freezing in spots
This is a symptom of air leaking into the freezer. The most common place is around the door. Check the door really good to make sure something is not obstructing it from closing all the way, it may be closing enough to satisfy the ajar alarm but not enough for a bit of moisture to sneak in. Look for tears or breaks in the seal. If you put a bright flashlight inside the freezer and close the door, turn off the lights in the room you may find a leak that way.
May 03, 2010 | Electrolux 21.0 Cu. Ft. Upright Freezer -...
Hotpoint FFS70 freezer door won't close
there must be a basket that is bent ,
Jan 18, 2008 | Freezers
Freezers Logo
93 people viewed this question
Top Belling Freezers Experts
AJMAL KHAN
James Coghill
Tom Chichester
Are you a Belling Freezer Expert? Answer questions, earn points and help others
