Question about Husqvarna Lawn Tractor 48" Deck, 23 Hp, Model# Yth2348
Can't level deck.
Changed blades, Leveled deck on level concrete surface. Checked air pressure on all tires.
Appears to be too much pressure on front center wheel on deck (constantly cocked over). Front adjustment arm is screwed all the way down.
I'm lost. Cutting is off, and on level 6, outside of cut is the same level on both sides; while center is scalping the ground - still too low.
  • 21 Answers
Try checking the blade spindle to see if there is any play (up,down,left,right) hope this helps
Posted on Jul 27, 2009
How to level lawn mower deck
Check air pressure on all tires first then park on flat surface and adjust until the blades are the same distance from the flat surface on both side & front & rear.
Nov 15, 2014 | Garden
How do I level the deck on a John Deere X500 mower
FInd and buy a deck level guage (makes it so much easier) photo.25191349-sc2hyhwnmj3wm0xvqhiyjoyo-1-0_0.jpgAdjust the front tire pressures to 14 psi. Set the rear tires to 10 psi. Make sure that the mower is on level ground,concrete driveway or garage floor. Set you deck height knob to 2.5 inches. Move the blades to where the blade tips are pointing to the side of the mower deck. Level the deck side to side by adjusting the lift link nuts,15mm or 17mm wrench. Get the side to side as level and possible and close to a number or mark on the guage. Move the blade tips to the front of the mower deck. Check the front to back and have a 1/8" to 1/4" lower on the front of the blades than the back. 18mm and 19mm wrenches for the front adjusting bracket.
Oct 06, 2014 | John Deere Garden
How to level 60" zd 21 Kubota deck
YOUR GOING HAVE TO ADJUST SCALP ROLLERS OK THIS IS ABOUT ALL YOU DO LIFT DECK UP MEASURE THE BLADES TO THE DECK WHAT YOUR CHECKING FOR IS A BAD SPINDALL GRAB YOUR BLADE WITH GLOVED HANDS JANK BACK AND FORTH 9F THAT SPINDEL MOVES REPLACE IT CHACK OF OF THEM YANK THE HELL OUT THEM ALL THE SPINDEL THEN LOOK AT SPINDEL SUPPORT PLATE MAKE SURE NON OF THEM OR BENT FORWARD OR BACK WARD STICK A SMALL RULER ACROSS TO SEE IF FLAT ALL THE WAY AROUND IT CHECK ALL OF THEM LIKE THIS THIS THE LAST THING YOU CAN DO YOU DONE EVERYTHING ELSE IT COULD BE IM REALLY CURIOS IF THIS DOENT FIX IT WHAT IT COULD BE HAVE YOU CHECKED THE ALINEMENT DECK TO MOWER IT ISNT OFF CENTER WERE IT COULD BE PUSHING DECK TO THE SIDE THATS ALL I NO WHAT TO DO THE RED NECK LET ME NO WHATS HAPPENS
Sep 01, 2014 | Garden
What is the proper way to adjust deck of a gravely pro stance 52" fixed deck? Should deck be level or slightly pitched to front?
Ideally, the blades should be level when measured on a flat concrete surface. Otherwise, they'll cut shallow trenches - front if the deck is pitched forward, rear if the deck is pitched rearward. If the blades are level, they'll cut flat all the way across.
Jul 31, 2014 | Garden
Cub cadet m60 tank
check tire presser in all tires.14 psi infront and 10 psi inrear.if that dont fix it, it is most likley a bent blade or manderal housing.
if mower deck is leveled by blade gage.
Aug 21, 2013 | Garden
Husky yth1542xp. I've changed the blades, leveled
When levelling the deck, rotate the blades so that the right blade has one of its cutting edges at or near the right side center of the deck. Do the opposite with the left. Measure to the blades from the level ground, not to the deck. Try leveling that way.
Gary
Jul 03, 2011 | Husqvarna Garden
We changed the blades, changes a spindle and checked the deck and tire pressure on our Poulan Pro Mower. It is still cutting uneven. What else should we check.
Well the plane of the spinning blades obviously is not parallel to the ground. While the ground will never be level, do what you can and first get the mower on a good piece of flat concrete. Measure distance between each corner of the mower deck to the concrete. You have had the deck off, the deck hang mechanisms have some adjustment so you can lower the front of the deck relative to the rear and vice versa, and lower the left relative to the right side, and vice versa. Look for threaded rods with adjusting nuts, pins which can go into different holes, etc.
As a last resort you could google "poulan, mower, manual" which would take you to their website and you can download the manual for the mower. All my mowers, MTD, Husq, Simplicity, came with a manual and had explicit instructions for this process. Most all these mowers are made by Roper or AYP and you may find information by googling those companies.
Aug 25, 2010 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Uneven cut
1-----------tire pressure? 14 front 10 rear
start with a level mower on a level surface
2------------deck level side to side?
3------------deck level front to back? (front can be 3/8 lower than back)
4-----------deck hangers bent or hung up?
5------------blades even when pointing at each other? no more than 1/8 high or low
6------------blades dull or upside down? turned up ends go towards deck
7---------------incorrect blades for mower?
8------------deck lifting mechanism should pick up deck evenly and drop evenly?
9-----------under the deck need cleaning because it is packed with grass?
Jun 15, 2009 | Garden
Craftsman 917273223 50' cut. Hit a stump with right blade started cutting poorly on right side. Replaced blade still cut bad. Replaced a 3 blades and still cutts bad on right. Held pully and tried to turn...
you need to bring all 3 blades to point at each other on the deck
do they all look the same?
aLL 3 should meet each other evenly with no more than 1/8th inch difference high or low point to point.
the stump strike could have bent the deck on that side
also be sure the fin side of the blades are pointing towards the deck when installed.
check that your deck is level on a level surface and the air pressure in all for tires are up to recommended pressure.
most of the time 14psi front and 10psi rear
Jun 09, 2009 | Craftsman Garden
Husqvarna Lawn Tractor 48" Deck, 23 Hp, Model# Yth2348 Logo
480 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
