Question about Zenith R57W46 57" Rear Projection Television
Temp ted light blinks twice then turns off tv
I push the on button and it the green light button flashes for a good 5 times then it flashes red light on the tempeture display then turns off but the tv never turns on.
Re: temp ted light blinks twice then turns off tv - Zenith R57W46 57" Rear Projection Television Projection Televisions
Red light on does not turn tv on
Posted on Jun 03, 2011
  • 537 Answers
Your lamp might be bad. Also, it is possible that the lamp door is not closed.
Posted on Nov 21, 2007
0 characters
3 Points
I have a sony rear projection TV model number kfws60s1 that will not turn on I press the on button and green light will flash 5 times then goes red again please help shed light into the problem pleaz
Understanding Sony Television Blinking Codes ' Techlore
Now the red light blinks 5 time while watching it. Is there any way of ..... 2006 that willnot power on and the green LED is blinking 6 times. We had a service ...
Sony KDF E55A20 - 5 Flashing Read Lights - TV Forums
Mar 17, 2012 - 14 posts - ‎4 authors
We have had a Sony KDF E55A20 since January 2006 and it has been trouble free. ...The TV will switch on fine green power lights. Then after about 20 ... If I turn off and turn on the power light will flash red 5 times. Leave it off ...
Sony TV - How to troubleshoot a red or blinking light ...
? 3:36
Apr 6, 2012 - Uploaded by SonyListens
Sony TV - How to troubleshoot a red or blinking light ... and power lights, these easy steps will help you determine what the... 5:17. Easiest TV repair - How to Fix Power [TV turns off, freezes, ... Get video URL at current time.
Dec 02, 2015 | Sony Projection Televisions
Tv dont power on green light flash then turns off red lights blinks 5 times
Had that problem and replace the lamp twice, I finally replaced the optic block.
It is quite involved to replace, if not technical get professional help.
Mar 21, 2014 | Sony KDS-60A2020 60" HDTV
Red light blinks 5 times and wont power on. Is not the bulb
error code is model specific---some it means lamp door issue and others something else.
Oct 31, 2012 | Sony Projection Televisions
TV turns itself off, then on automaticlly
The fan should run for a few minutes after shut off to cool the lamp down.
If I read and understand correctly somewhere in the cycle you are getting 5 red blinks? that is an error code........
Either you or I can Google the model number of the set with 5 blinks.....or visit the Sony site to see what it means.....
Apr 24, 2012 | Sony KF-42WE620
I have a Panasonic Model PT-50LC13 flat TV. Was working when got it brought it home, it is used and now when I go to turn it on --- we get a green light then a flash of 5 yellows blinks then no light for...
This tv has 3 indicator lights on front, Power, Lamp and Temp
I assume Temp light is blinking 5 times after every 5 seconds, if that is correct then it is problem of clogged air filter located in light engine that need to be cleaned.
Below is an image of light engine and air filters locations are marked with red circle, it is job of professional to fix this issue because complete light engine need to be take out from tv cabinet.
Hope these info will help you, let me know if you have additional question or need service manual copy if you want to repair tv by yourself.
Nov 10, 2010 | Panasonic PT-50LC13 50" Rear Projection...
Panasonic pt-43lc14 won't turn on
Try checking your lamp door. I have seen a few of these that you need to really wrench that screw down. Let us know.
Mar 22, 2010 | Panasonic PT-43LC14 43" Rear Projection...
I want to find the Sky remote code for this Tv.
Just got an LG 42LH2000 and code 0206 works
May 16, 2009 | LG Projection Televisions
Flashing red light
I think this sounds like my problem (need to replace the projector lamp). However, when I hit the "on" button, my SXRD 50" blinks green for about a minute then starts blinking red. Can you confirm the bulb solution? I was very pleased with this sight when my fan malfunctioned. I got the fan in a matter of day's from Sony and it fixed that problem.
Oct 29, 2007 | Sony KDS-R60XBR1 60" Projection HDTV
No picture or sound - Power Save light blinks red 5 times - nothing on the screen
i also have the same problem with the flashing green light for a while then a different red light starts blinking on and off around 5 times....and i replaced my burnt bulb with a new one...still no picture.
Oct 24, 2007 | Sony Grand WEGA KF50WE610 50" Rear...
Zenith R57W46 57" Rear Projection Television Logo
199 people viewed this question
Top Zenith Projection Televisions Experts
Jaime Hernandez
matt martin
matt martin
Are you a Zenith Projection Television Expert? Answer questions, earn points and help others
