Cable input connector broken off
The cable input connector has broken off the enclosure on the circuit board due to the service cable being pulled too tight. Can that circuit board be replaced?
    Champion:
  • 230 Answers
Hi, thank you for visit fix ya.
You can replace just the connector.
Go to :
http://www.encompassparts.com/tritronics//
Ask for RCA connector ( for tuner).
Use solder gun,clean and install the RCA connector.
Thank you
Posted on Jul 28, 2009
  • 41 Answers
Usually the connector or at least a new connector can be put back on. If there is minor damage to the board, a tech can repair it in most cases.
Posted on Jul 27, 2009
2 Suggested Answers
dnewcombe1
  • 1564 Answers
SOURCE: cable input jack bronken off
Actually I just repaired one of these "similar" units. If you remove the backing of the tv, unpluged of course, Theres a panel facing you if you are looking at the right side of the TV. This panel pops off easily with a light prying motion all around. You'll see where the connector broke off and can solder it back together with a small pin type tip. Solder the center pin to the center probe first,hold in place with needle nose pliers. 2 people are better than one at this. Then lay down agood bead of solder around the perimeter of the connector. Clean up any solder that may have dropped and put it back together, you'll be ready to go in about one hours time. Let me know how it goes!!!
Posted on Jul 25, 2009
Can I connect a vcr to the cable jack on my flat panel tv?
If you are sure the VCR is having valid output, this could be a problem with the interconnect cables. If the cables and VCR have been verified to be okay, then the fault could be with the input matrix circuits in the TV set. A simpler form of this problem could be with the input connector, or the solder connections, or a trace on the board.
Sometimes the main input IC goes defective or one of its support components. In these sets the components are mainly surface mount types. Normally, the service centre will change the complete circuit board containing the input circuits.
Jun 21, 2014 | Apex Digital Apex 32 in. LED 720p 60Hz...
My cable connector pulled out from the tv and now the tv won't stay on the power button will blank three times and go off what can be the problem?
when the cable got pulled it broke a connection on the board , and thatswhy it won't come on
it will need to be resoldered where the cable was pulled
need more help just ask me!
electech
Oct 26, 2008 | RCA Televison & Video
Tip
LCD TV TROUBLE SHOOTING
1.Do not power on .
1 .1 Please check AC cable if connect to AC plug. Is true the connector don't connect to AC plug. Please connect it.
2.2 Please check AC cable if connect to AC power. Is true the AC cable don't connect to AC power. Please connect it.
3.3 Please check power board of fuse if broken. If the F1 fuse is broken, Please pull out the AC cable from AC power. Please check AC L power and AC N ground by multimeter, The read number is infinite, the fuse is broke. Then look up power board if not burn out place. Is true it. Please change power board or be changed power board.
2. The power on switch of green extinguish.
2.1 The power of led(indicator light) is red light, To touch power on key when indicator light wink. Is true that the power DC output have somewhere short circuit. Check connector J39,J31 .If not connector direction is wrong. Or the mainboard somewhere of power short circuit.
FOR MORE CHECK THE LINK BELLOW
Electronics Equipment Repair Center
on Feb 14, 2015 | iLO Televison & Video
My connection for the cable on the back of my tv is broken!
If you have RCA inputs for video and sound their will be a white and red which is audio and yellow is video. If you have a cable box that you use to change channels, this should have the RCA outputs for your audio and video. You will also have to set your tv to select that input to get the cable. Hope this helps
Apr 17, 2013 | Sony KP-53V85 53" Rear Projection...
About 2 months ago I bought a samsung s2 portable 1Tb. It has worked fine until yesterday. It slipped down from where it was laying (while plugged in and running) and was hanging the 20 cm usb-cabel. Now I...
Hanging by the 20cm USB cable?
The cable could be stretched, and wires broken inside.
The cable to small circuit board, inside the case, could have broken solder joints.
The circuit board inside the Samsung's case could be broken.
Inside that small outer case of the Samsung portable is a laptop size Harddrive.
The harddrive measures 2.5 inches across in width.
(6.4cm. In comparison a desktop size harddrive is 3.5 inches across in width, or 8.9cm)
The harddrive is a SATA unit also.
This is a general example of a 2.5 SATA harddrive,
http://www.newegg.com/Product/Product.aspx?Item=N82E16822148591
Inside the outer case (External Enclosure) is also a small circuit board (PCB)
The harddrive plugs into the small circuit board, and the circuit board has a USB cable attached to it.
(Or there is a small cable from circuit board to harddrive. Then a USB cable to the circuit board)
I would suggest removing the 2.5 SATA harddrive, and install it into an economical external enclosure.
Example of a 2.5 SATA External Enclosure,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3195233&CatId=2783
Basic guidance in removing the Harddrive from a Samsung S2 Portable,
1) It looks as though the outside front is a thick cover like a label. It may be that you peel back the corners, and there will be a screw in each corner.
(For example; Where it states Samsung. Go to the right corner. Does this cover-like material peel back? Is there a screw underneath? Remove it.
Go to the opposite corner. Now above to the left and right corners)
The unit looks to come apart in two halves.
Might just be held together by sticky tape.
Here are some videos performing opening the external enclosure, (Case) of other external portable harddrives,
1) http://www.youtube.com/watch?v=dMzRYCZXVEs&feature=results_video&playnext=1&list=PLC129A4F797CCC09E
2) http://www.youtube.com/watch?v=Y2vUMO2mGLE&feature=related
There are other related videos. In general most are not very professional, but get the job done.
For additional questions please post in a Comment.
Regards,
joecoolvette
Sep 18, 2011 | Samsung S2 Portable HX MU010EA 1 TB...
My unit is not powering on. I plugged in an 18v power supply into the unit and it was on for a few seconds and then shut off. Did I burn out the unit?
thirdjonesbo,
This solution will be rather lengthy. I apologize for the length of it in advance, but feel it is necessary to explain my possible solution.
Please bear with me.
joecoolvette
Inside the external harddrive case is a SATA harddrive.
The SATA harddrive plugs into a small circuit board, via an interface connector, OR small cables.
[Interface Connector.
On the back of a SATA harddrive are metal pins that stick out. The ones to be concerned with are the 15 pins for Power, and the 7 pins for Data. The 15 pins for Power are grouped together, as well as the 7 pins for Data. An Interface is simply a connector that has socket holes in it, that the pins stick into.
If you have never seen a harddrive, much less a SATA harddrive, the above statement will be as clear as mud.
Let me show you the pins on the back of a SATA harddrive, to help clarify this,
http://www.interfacebus.com/SATA_Pinout.html
Under the heading - Serial ATA Signal Assignments, view the illustration.
On the right you will see the Power Cable, headed towards the Power Connector. If you could enlarge this illustration you would see there are 15 pins.
On the left you will see the Signal Cable, headed towards the Signal Connector. Again, if you could enlarge this illustration you would see there are 7 pins. Signal is also Data.
(Data = Information. Information is processed back, and forth to the harddrive through this cable)
An Interface connector is rectangular in shape, and has socket holes to fit these pins.
Or, as stated above, it may have two small cables as shown in the illustration, and they plug into the Power, and Signal (Data) pins.
Either an Interface connector, or two small cables lead up to a small circuit board.
IT MAY BE that you are fortunate, and the circuit board bore the brunt of the overload of voltage, and did not get to the SATA harddrive inside.
My suggestion would be what I would do myself. This suggestion may not be what you would do.
I would open the external harddrive case, and look for obvious signs of electronics failure on the circuit board, and on the harddrive itself.
The harddrive also has a circuit board. It's on the bottom of the harddrive.
If you see obvious signs of damage such as,
1.Black marks on any of the various electronic components, or 2.Electronic components that have melted, swelled up, or look burned,
on the circuit board of the SATA harddrive, then you may want to stop here.
The 'cure' may be more costly, than the information you have saved on this external harddrive.
But,
IF, the circuit board of the SATA harddrive looked good to me, I would risk a small amount of money, to see if I could get the harddrive to work again.
Again, just my personal preference, and not direct advise that this is what you should do.
I would buy an External Enclosure, and install the SATA harddrive in it. The External Enclosure also has a circuit board inside, and uses a USB cable to connect to the computer, just like the External harddrive that you have now.
Average cost for a decent external enclosure for a SATA harddrive is around $30 USD.
Here is an example, (Not an advertisement for the external enclosure manufacturer, or said website),
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2145406&CatId=2780
The external enclosures come with info about how to open the enclosure, and install the SATA harddrive.
Should you have gotten this far, thank you for your time.
Regards,
joecoolvette
Nov 21, 2009 | Western Digital My Book Essential 1TB...
My son tripped over the cable cord and the cable/antenna input came off. Is it repairable and is it costly to get it fixed
It depends if the connector broke the tuner it is attached to. Most times the chassis of the set would need to go into the shop. I would generally charge $80.00-$120.00 if the tuner was still good - a new tuner would cost $60-$100 more if bad
The better solution is to use the video audio inputs (if on satellite or cable box) or use the video inputs by changing channels through the VCR (if on cable or antenna and a VCR is available)
Oct 22, 2009 | RCA P52926 52" Rear Projection Television
Cable female adaptor is missing
The small metal box is the tuner. The tuner has to be removed to replace the broken off RF connector. The connector has to be soldered to the tuner housing (metal box) and the leg of the connector has to be soldered to the circuit board, board has to be checked for cracks or if it is broken. If board is damaged the tuner will have to be replaced, if its available.
Aug 17, 2009 | Emerson EWF2703 27" TV
Cable input jack bronken off
Jul 25, 2009 | Orion STV2763 27" TV
Cable connector repair
use RCA cables instead of ch 3
Oct 24, 2007 | RCA D52W15 TV
Televison & Video Logo
268 people viewed this question
Top Televison & Video Experts
