Question about AudioBahn A2002T Car Audio Amplifier
No rcas inputs on amp
I have a ACAP501Q amp, ithink lol . but there r no rca jack in put show do i hook it up?
  • 655 Answers
Hello sting_ya_sco,
The ACAP501Q has 2 sets of of RCA jacks. The first set is input and 2nd preamp outputs. The jacks are factory covered with plastic protectors. Just pull the protectors off and plug in the cables.
Hope this helps.
Posted on Jul 25, 2009
I have RCA cables , How do I use my computer music ? What connections and settings?
Are you trying to play music off your computer through a stereo or receiver??? If so you will need a cord with red & white (rcas's) on one end & an 1/8" jack on the other...Run it out your headphone jack of the pc (usually color coded light green) and turn input of stereo to corresponding input you plug into..
May 23, 2016 | Kenwood Kr-5600 Vintage 70s Am/fm Stereo...
How can I connect my itouch to my pioneer VSX-52TX receiver
You can use the RCA jack and an RCA cable to your aux in on your receiver.
Oct 16, 2013 | Pioneer Audio Players & Recorders
I have a boss bass 1200 low profile amplified sub that isn't working. my power wires connected and receives juice, my ground is grounded, and my remote is hooked up. also my rcas are connected and the...
+ positive from battery ground is of course - anywhere on body put it on last.to avoid sparks if + is powered up! U can put a link between remote and positive it should then be on. Led normally goes blue rca s need a signal from stereo make sure its a amp out or sub out not an input on stereo set all knobs to middle and if speaker is connected to amp speaker + - it should be on, try an mp3 player with jack to rca for testing a known signal.amp may have loop rca make sure its on inputs.some have high inputs too using speakers wire stick with rca
Jan 17, 2018 | Boss Car Audio & Video
Amp went to protect mode and will not reset to green.
Be sure the rca's are not getting severly pinched or worse you drilled a screw into them.
Second make sure your connecting the RCA's to the
1. OUTPUT of the radio
2. INPUT of the amp
if you connect any other way its wrong and could damage both radio and amp especially you screw into the RCA's your sending 12 AC Volts to ground.
Apr 06, 2010 | Swiss Audio SMX-4400C Car Audio Amplifier
4 subs and two amps
I'm not that familiar with the insignia line but If the amps have an "input" and an "output" for the RCAs then run the RCAs in one, Then hook the output of that one to the input of the other. I did this with my 2 memphis 500Ds and it worked great. It also looks better than a couple of splitters, but yes You would just get two splitters with all female connections on them so you can plug 2 sets of RCAs into the one set. Also it doesn't really matter how you hook the RCAs up unless you are going for stereo sound then you would need to make sure the rights are hooked up together and the lefts are hooked up together. I hope I could help.
-Andrew Hawkins
Jul 22, 2008 | Car Audio & Video
Trying to hook up mp3 player
they are out jacks and you need to run the rcas to an amp and then run your speakers off the amp your mp3 player should work when you plug it in the front and press source aux unless the front jack is an out only
May 25, 2008 | Pioneer DEH-P400 CD Changer
Right side speakers don't work
if you are using RCAs as inputs to your amp.Swap the R to L @ RCAs to see if its comming in okay from radio.If both RCAs have audio then amp is bad ,If amp has any type of switches , move swithces to see if it comes back .Also if both RCAs inputs have audio .Move the RCAs when connected on amp to see if amp has bad connection in board to RCA jacks..If audio comes back on bad side when jack is moves .Then you have bad solder joints on board..If not then you must have bad outputs on amp..
Dec 22, 2007 | Car Audio & Video
Help
No. The amplifier gets its signal from the RCAs connected to the "input" jacks, but the "output" jacks are just there to make it easier to add another amplifier. You only need to connect the inputs for the amp to work.
Jun 29, 2007 | Jensen A600HLX Car Audio Amplifier
AudioBahn A2002T Car Audio Amplifier Logo
67 people viewed this question
Top AudioBahn Car Audio & Video Experts
Tygh Duval
Tygh Duval
Colin Stickland
Colin Stickland
Jerry Naidoo
Are you an AudioBahn Car Audio and Video Expert? Answer questions, earn points and help others
