Question about Norelco Health & Beauty
How to open case on Norelco T-3000 beard trimmer
I've done this successfully in the past, but now can't seem to get the case open for my Norelco T-3000 beard trimmer. I'm trying to replace batteries once again. Suggestions?
  • Anonymous Mar 24, 2014
    How do i open the case to a wahl's 5598 trimmer to replace the battery ???
    Habit-Forming:
    Welcome Back:
    Visited the website for 2 consecutive days.
Remove the bottom screw. Next, the on/off slide switch has to be lifted off carefully with a small flat screw driver. Its kept in place with a small spring steel clamp. After you've removed it lift off the steel clamp and remove the slide mechanism by carefully twisting it out of position. Once that's done it will twist open easily.
Posted on Dec 24, 2010
My Qt4050 seems to be charging ok, but I can no turn it on with the on-off button. Any fix for this problem?
Might be a silly question but are trying to turn it on whilst the charger is connected? Most (if not all) of the Phillips rechargeable shavers will only operate without the charger connected so as to avoid connection to the mains whilst in a bathroom etc.
Dec 19, 2013 | Philips Norelco Qt4050 Vacuum Beard...
How to disassemble Philips QG3080 Beard Trimmer
dimitris, use brush to clean hair and don't open the machine.
Nov 09, 2013 | Philips QG3080 Beard Trimmer
Wheres the battery
Oct 17, 2012 | Norelco G270 Beard Trimmer
How do I replace the battery on my Norelco D-finer D350?
try checking on placement of the batteries where it is screwed outside. you unscrew it and open the cover then change the batteries.. you can also sneak into the manual for sure..
Apr 28, 2011 | Norelco D-Finer D350 Beard Trimmer
My t860 will not hold a charge, and now I can't get it to work while plugged into the charger, can the battery be replaced?
The battery can be replaced. There is a single AA NiCd battery soldered into the main circuit board.
To open up the trimmer, first take the silver screw out (located near the lower back side). Then pull the trim guard off the top (should come off easily). Next, the rubber-like ring used for adjusting the trim height needs to be pulled off -- this can be difficult but just work your way around and ease it off. Finally, the metal clip on the end of the trimming head needs to be removed, and the plasic case can then be popped open, revealing the circuit board.
If you're not comfortable soldering or disassembling it, it can likely be done at a local Batteries Plus store.
Mar 14, 2010 | Norelco T870 Beard Trimmer
How do I change the Battery in My Norelco T3000 Beard Trimer
Remove Phillips head screw at bottom of trimmer. Separate body in two being careful to notice how on/off switch is assembled. Unsolder the ni-cad battery from circuit board. Install new ni-cad battery of the same physical size that has solder tabs on it and solder it to the circuit board. I used a ni-hi (nickle metel hydride) instead of ni-cad which had different charging requirements so I limit charge time to no more than 16 hours for a discharged battery. It had been working fine for over a year. Don't forget to apply a few drops of light oil to the cutting blades to extend cutting life. Replacement blades are about $30.00
Jul 06, 2009 | Norelco T770 Beard Trimmer
How to replace battery pack for a Norelco 6885xl electric shaver
The battery pack is soldered to the shaver's circuit board. Yes, it's a poor design in building something that people can't readily service unless they have a soldering gun, ******, and wick, plus patience. However, there are plenty complaints online already, and my shaver won't get fixed by b-tching some more.
There are 2 choices for replacement:
1. Bring or mail it to a service center to have the batteries replaced. The fee usually runs $29.99-$39.99, which includes the battery, parts, labor, lubrating your motor, cleaning the interior, cleaning/stripping the cutters, heads, and trimmer, plus return shipping.
2. To save yourself $26-33 bucks, make sure you know how to solder and have the equipment described above. you can find single NiCad AA with solder tab for $3ea or a pair for about $7.95+. Table the batteries together, solder a single tab across +/- on one side, and solder the others onto their respective tabs in your shaver.
For me, I'd love nothing than to hobby around and do it myself, but with 3 kids, a full-time, job, Wii, and other hobbies, it's easiest to just send it out... some services will guarantee to have it done within 2 days of receipt. You'll just have a lil beard to test it out when you get it back. :-)
Aug 02, 2008 | Norelco 7886XL Electric Shaver
Health & Beauty Logo
752 people viewed this question
Top Norelco Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Bruce Foote
Level 1 Expert
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Norelco Health and Beauty Expert? Answer questions, earn points and help others
