Question about Mitsubishi WS-55807 TV
Oval shaped picture problem with Mitsubishi WS55807
Whenever this rear screen projection tv is turned on, the picture arcs on the top and bottom so the picture is oval shaped.
Any suggestions?
  • atlantawmn Dec 14, 2007
    Colors in pic are not lined up.How can i fix
  • 1,153 Answers
Self test: Turn on and Press the input and menu buttons on front panel together and hold for 5 sec. after 5 sec the power LED will blink a 2 digit seq. This will let you know what error code. Count the first blinks then a short pause then the second blinks. Example 2-3, 3-4, 4-1. Let us know what it is
Posted on Dec 05, 2007
I have a Mitsubishi WS-55809 projection TV. The convergence will not ajust using the user controls and the picture looks bowl shaped in every format.
you will need to install a convergence repair kit for your model. You can get the repair kit called the " WT46807, WS55807, WS65857,WS65907, WS73907 WT46809, WS55809, WS55819, WS65809 and WS65819 Convergence repair kit " which has the parts and the CD with instrucions. Its available at the following link
Feb 07, 2013 | Panasonic PT-56WXF95 56" Rear Projection...
I have a mitsubishi big screen digital projection TV the picture is starting to look oval shaped in the screen not flat what part should i be looking at to fix problem
A lot here depends on the actual model number and if you could post a good photo of it somewhere(here or elsewhere) I might be able to still assist you.
Mar 20, 2012 | Mitsubishi Televison & Video
The top and bottom of the picture makes a rainbow effect toward each other in the center of the screen++++++++TV. model 3 ws55807 it's a 55 inch screen the problem occurs all the time. I have no TV repair...
This tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?Yes,than this tv have a dead convergence board.The tv convergence board require changes 2 STK convergence ICS and some or all of it resistors too.Fix the tv convergence board to solved the tv convergence pictures problems.The shop,will cost u like $300-350 for parts and labors.
Feb 08, 2011 | Mitsubishi WS-65807 65" Rear Projection...
Fuzzy picture, oval shaped, scrolling up slowly
I would start by checking the large filter capacitors in the power supply. I can't be sure since I'm not seeing the set, but it sounds like you're describing AC ripple. In a 20-year-old set, some of those electrolytics will be drying out. A few replacements may take care of the trouble for you.
Jan 01, 2009 | Panasonic PT-56WXF95 56" Rear Projection...
Phillips Model 60pp920217f
I expect the answer to your question is YES! The convergence amplifiers are a common problem in many projection sets. When you search for the replacements you should find that the originals have been superceded by improved parts. Also be aware that when these parts fail, they will usually damage a resistor in the convergence yoke return path. The resistor must be replaced with one of the correct value or the convergence, though responsive, will be out of range.
If you find my suggestions to be helpful, please share with us some details so that others may benefit from knowing the whole story. Thank you!
Dec 29, 2008 | Mitsubishi WD-52327 52" Rear Projection...
Mitsubishi WS-55809 dark scenes display green lines in background
the crt's pcbs need to be adjusted, screen control is not balanced
Nov 24, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Sony kp-48v75 picture arcs at top and bottom
Convergenc IC proble look for and replace all Stk392-XXX
Dec 03, 2007 | Sony KP-48V75 48" Rear Projection...
Year 2000 mitsubishi 64 inch tv
Have convergence IC's changed in your 60" TV. I only use ORIGINAL IC's, not generics or knock offs. Most companies that fix have no idea what the difference is.....
Oct 31, 2007 | Mitsubishi VS-60703 60" Rear Projection...
Mitsubishi WS-55807 TV Logo
103 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
