p
pam barnwell Posted on May 23, 2017
I am using Pattern 8050. (view B) I am stuck on step 4. No matter how I look at this, I can't seem to get it right. Please help.
2 Related Answers
Anonymous
  • 214 Answers
  • Posted on Jul 26, 2008
SOURCE: alignment
go to the printer settings and align the printer head
nyilasrobert
Robert Nyilas
  • 627 Answers
  • Posted on Nov 05, 2009
SOURCE: Please help me!How can be remote viewed right in
You can use Remote Desktop connection which requires a valid username and password on the remote machine.
1helpful
My Photosmart 8050 still won't work. I got it to print a test page, align cartridges, and it worked fine. Now, when I try it online or not on line, it just won't take a command. Now, exactly which...
Hi!
First of all, you'll need to COMPLETELY uninstall the printer:
1. Unplug it from the computer.
2. Uninstall the ALL software/drivers through Add/Remove Programs (or Programs and Features - if you're using Windows Vista/7).
4. Restart the computer.
4. Go to Printers and Faxes (through the Control Panel) and make sure the printer is NOT listed. If it does - delete it.
5. This is an important step, follow carefully:
  1. Start -> Run.
  2. Type in: cmd
  3. Press Enter.
  4. Type in: set devmgr_show_nonpresent_devices=1
  5. Press Enter.
  6. Type in: devmgmt.msc
  7. Press Enter.
  8. Device Manager window should be opened. Click on View.
  9. Click Show hidden devices.
  10. Expand the Universal Serial Bus Controllers. branch and delete ALL "grayed-out" devices under it (right click on them, then click Uninstall; click OK).
  11. Repeat step 13 for any grayed-out devices (if exist) under: a) Printer; b) DOT4 (not sure what the exact branch name - but it's something like this); c) Other devices. (** If you want, you can remove all the non-present (grayed-out) devices in all preset - except for in Non-Plug and Play Drivers [which is too risky if you don't know what you're doing]).
  12. Close the Device Manager.
6. Restart again.
7. Reinstall the printer software/driver (DON'T PLUG THE USB CORD YET) using the installation CD (or better, download the latest software from here!).
8. Plug the USB cord when asked - or when setup is done.
Please do tell if your problem's still unsolved!
Good luck,
Pelu.
2helpful
2answers
I need to know the torque settings on the head for a 94 jeep grand cherokee laredo
Assuming the motor is an inline six
1.Middle bolt is number 1.Clockwise torque to 22 f/lb
2.Same pattern to 45 f/lb
3. same pattern to 100 f/lb
Be sure to use loctite 592 to the threads and some head gasket sealer to both sides of the head gasket.
Hope this helps
Alignment
Epson rx 500 print problem
Please confirm that the head cleanings were done using the most effective method listed below.
1. Make sure the printer is turned on but not printing.
NOTE: You cannot clean the print head if the any of the cartridges are expended. Replace the appropriate ink cartridge before proceeding.
2. Load letter size paper.
3. Click on START.
For Windows 95/98/ME: Click SETTINGS, PRINTERS, then right click on the EPSON STYLUS PRINTER ICON. Select PROPERTIES from the drop-down menu. Proceed to Step 4.
For Windows 2000: Click SETTINGS, PRINTERS, then right click on the EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. Proceed to Step 4.
For Windows XP: Click CONTROL PANEL, PRINTERS AND FAXES. Right click your EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. If this icon is not showing, select VIEW INSTALLED PRINTERS. Then right click the EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. Proceed to Step 4.
For Windows Vista: Click CONTROL PANEL, HARDWARE AND SOUND then PRINTERS. Note: these steps may vary depending on how Vista is setup. Right click on the EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. Proceed to Step 4.
4. Click on the UTILITY or MAINTENANCE tab, then click on HEAD CLEANING.
5. Follow the instructions on the screen to clean the print head. Cleaning takes about 30 seconds, during which time the printer makes some noise and the power light flashes. Never turn off the printer while the power light is flashing, unless the printer has not moved or made noise for more than 5 minutes.
6. When the power light stops flashing click PRINT NOZZLE CHECK PATTERN and then click NEXT.
7. If the nozzle check pattern has no gaps in its lines, click FINISH. If the pattern has any gaps, click CLEAN to clean the printhead again.
8. If the situation continues after three cleaning cycles and nozzle checks, replace one of the affected ink cartridge(s).
9. Once the cartridge(s) has been replaced, please follow steps one through seven up to three times.
If the nozzle check still has gaps after you have run at least 3 consecutive cleaning cycles and replaced the affected ink cartridge(s), your printer will require service.
We know that having a printer serviced/fixed costs more than buying a new one, check out this link http://www.epson.com/loyalty .
Problem printing
1) Make sure the printer is turned on but not printing.
2) Load letter size paper.
3) Click on START.
For Windows 95/98/ME: Click SETTINGS, PRINTERS, then RIGHT-CLICK on the EPSON STYLUS PRINTER ICON. Select PROPERTIES from the drop-down menu. Proceed to Step 4.
For Windows 2000: Click SETTINGS, PRINTERS, then RIGHT-CLICK on the EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. Proceed to Step 4.
For Windows XP: Click CONTROL PANEL, PRINTERS AND FAXES. RIGHT-CLICK your EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. If this icon is not showing, select VIEW INSTALLED PRINTERS. Then RIGHT-CLICK the EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. Proceed to Step 4.
For Windows Vista: Click CONTROL PANEL,HARDWARE AND SOUND then PRINTERS. Note: these steps may vary depending on how Vista is setup. RIGHT-CLICK on the EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. Proceed to Step 4.
4) Click on the UTILITY or MAINTENANCE tab, then click on HEAD CLEANING.
5) Follow the instructions on the screen to clean the printhead. Cleaning takes about 30 seconds, during which time the printer makes some noise and the power light flashes. Never turn off the printer while the power light is flashing, unless the printer has not moved or made noise for more than 5 minutes.
6) When the power light stops flashing click PRINT NOZZLE CHECK PATTERN and then click NEXT.
7) If the nozzle check pattern has no gaps in its lines, click FINISH. If the pattern has any gaps, click CLEAN to clean the printhead again.
8) If the situation continues after three cleaning cycles and nozzle checks, replace one of the affected ink cartridge(s).
9) Once the cartridge(s) has been replaced, please follow steps one through seven up to three times.
Color printing problem for Epson CX4200
try this :
3) Click on START.
Dark red prints with lines throught the picture
3. Click on START.
Printer doesn´t print using the mangenta ink cartridge
try this :
3. Click on START.
5. Follow the instructions on the screen to clean the printhead. Cleaning takes about 30 seconds, during which time the printer makes some noise and the power light flashes. Never turn off the printer while the power light is flashing, unless the printer has not moved or made noise for more than 5 minutes.
1helpful
2answers
Printing in blue only
try this:
1) Make sure the printer is turned on but not printing. Ensure there are no error lights or messages appearing in the LCD.
3) Click on START.
Color of prints very faint
It is unfortunate that you are having this difficulty with your printer.
To help preserve the life of the ink cartridges we suggest that you turn the printer off when it is not in use.
1. Make sure the printer is turned on but not printing. Make sure there are no error lights or messages appearing in the LCD.
3. Click on START.
k24674
ADMIN Andrew
ADMIN Andrew
