Question about Canon i9900 InkJet Photo Printer
On screen warning said it needed to be installed. I don't know how to get to it.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 74 Answers
Go to this link - http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=331&modelid=9870
download the drivers.
Unplug the printer from your PC.
Install the drivers
Plug the printer back in.
Posted on Jul 26, 2009
Blue screen of death on my HP Pavilion g7-1219wm notebook pc
A BSOD (blue screen of death) is a general failure warning and in itself is not serious unless it continues to happen. If that is the case, you will need to read and write down the message that appears to be able to get further help.
Jan 19, 2013 | Pavilion g7-1219wm Notebook PC
Driver usb handycam dcr trv 19e
did this some time ago so i don't recall clear...
-download the XP driver from the website
-create a folder on the c drive and run it from inside this folder - it will decompress the files to a folder called Sony_usb
-run setup from the Sony_usb folder - install in compatible mode after warnings
-restart pc
-open device manager -right click on the icon with the question mark and select Update driver
-browse to the location of the Sony_usb folder
-you will receive x red message (don't recall what the warning was) click ok and another message will pop about compatilbel install - do the compatible install.
to sume up - do xp compatible install all across
hope this helps
Jul 30, 2012 | Sony Handycam DCR-TRV19 Mini DV Digital...
I have been warned that i may be a victim of software counterfeiting how can i remove this warning come to normalcy that i don't need the software or window which didn't pass genuine window...
You need legal software...
Windows has two control: When you install windows: WPA. It is illegal to crack it with AntiWPA3.cmd patch or something similar.
You have second problem: WGA. It is illegal to remove it with RemoveWGA.exe tool.
I don't know why people can find this program on www.softpedia.com to download.
Aug 23, 2011 | Microsoft Windows XP Professional for PC
Mainboard GA-G31-ES2C Warning: Backup BIOS checksum error BIOS Auto-Recovering...
If you have reset the CMOS memory you need to go into the BIOS setup screen and reconfigure the BIOS. To do that you need to press a key while the computer is booting. Usually F2 but can be other keys. It should tell you on the bottom of the first screen which key to press to enter BIOS setup.
If you don't know the settings the should be one for optimal defaults - use that one. You will also need to reset the time and date.
Save, Exit and re-boot and everything should then work.
During the boot process you will see on the screen to press delete to enter setup
Jul 23, 2011 | Gigabyte GA-G31M-ES2L Motherboard
How do you know if your freeze plug is bad on a 2000 Chrysler Sebring?
If a freeze plug is bad it will be leaing coolant. They sometimes do rust out and need to be replaced. They rust from the inside out so there is not really any warning before they go. If it's not leaking don't worry about them. If they are leaking the have to be replaced, there's not really any other fix. They can be got at any auto parts store or you could install a block heater if you don't already have one.It fits in the freeze plug holes and it's a lot easier. Hope this helps.
May 06, 2011 | 2000 Chrysler Sebring
In the middle of a game my N64 will freeze without warning and in the top right corner of my tv screen is a small white or red line.
Well it might be over heating buy dust dust causes video game consoles to heat 10 times faster than their normal heating rates trust me i know then. So use those canned dusters for computers to clean then out. Thats how i clean my consoles out and i don't recomend doing it if you don't know what your doing.
Feb 21, 2011 | Nintendo 64 Console
Hi, I need How instaler a timing belt of kia carnival 2002, I don´t Know how are the marks of each pinion
Ok sent to you the image of as it is synchronized and I recommend imagen%20001.jpgto you to change the water pump Warn me the image came to you and I wait for your comment thanksimagen%20001.jpg
Jan 04, 2010 | 2002 Kia Sedona
Can't connect the artisan 800 to our wireless network
To add the printer to your wireless network, you need to know the name (SSID)
of your wireless network. If it has security enabled, you also need to know the
WEP key or passphrase. Write down the SSID and WEP key or passphrase below:
■ Network name (SSID): _________________________________________
■ WEP key or passphrase: _________________________________________
Note:
If the WEP key is either 5 or 13 characters, it’s ASCII. If the WEP key is either 10 or 26
characters, it’s hexadecimal. The default WEP key is usually 1.
If your passphrase contains upper- or lowercase letters, be sure to note it correctly.
The printer supports the following wireless security modes: WEP 64, WEP 128, and
WPA-PSK.
If you don’t know your wireless network name (SSID) or WEP key or passphrase,
contact the person who set up your wireless network before you begin.
Insert the printer software CD.
2. Windows Vista®: If you see the AutoPlay window, click Run Epsetup.exe.
When you see the User Account Control screen, click Continue.
Windows® XP: When you see the Software installation screen, continue with
step 3.
Mac OS® X: Double-click the icon.
3. Click Install.
1.Make sure that the printer is turned on.
2. When you see the FireWall Warning screen, click Next.
3.Make sure you connected the Ethernet cable
Oct 09, 2009 | Epson Artisan 800 All-In-One InkJet...
Warning screen comes up and warns my files will be dumped and to uninstall newly installed .. BUT nothing has been installed? I believe this is related to video card it appeared immediately after playing a...
ok, you're description is a bit fuzzy, but it sounds like a Warning Box pops up and warns that _______ files will be dumped ________ and to uninstall newly installed ________ (software/hardware).
At first thought, it sounds more like a virus or malware than a real warning. What exactly does it say in the Warning and are you SURE that the email you opened and played a video from was sent by a friend AND the friend actually says they meant to send it to you? Malware could easily send itself to you inside an email with a video in it from a friends email account.
Also, updating drivers probably isn't the issue if it happens when you are not watching that video.
Update and run your antivirus program and maybe post some more specifics. Thanks
Feb 18, 2009 | IBM ThinkPad A31 Notebook
Canon i9900 InkJet Photo Printer Logo
old marine
old marine
