Television standby light is not lit. TV does not respond to power/joy switch on the bottom of the TV. TV does not respond to remote control... Possible that Main board BN94-07727Dis the culprit? Could I have 2 bad Power boards? How do I determine if both boards are bad, seems illogical that both boards are bad.
SOURCE: Magnasonic DVD803-2 DVD player, stuck at standby
Hi kamil. Mo medenom, nomogom! I think problem isn't in power supply. It should be in control board (madaar-e farmaan). Hossain Shahidzadeh
SOURCE: Visio p42hd, no picture
Yes it does sound like the mainboard. But we have to confirm. I will see if there is a service manual for this unit in my collection but do you think you can safely work on it? Have you worked on electronics before? The last thing I want is you hurting yourself trying to fix it. HV circuits are not to be messed with unless you know about them.
SOURCE: Vizio 42 in L42HDTV10A no power no lights no nothing
You can look at the various module failure symptoms and service / replacement options for the L42HDTV10A here:
http://www.coppelltvrepair.com/search?Q=l42hdtv10a&As=false&Pf=&Pt=&Sid=false&btnsearch=Search
since you have replaced the main parts in the tv already it is safe to say you have bad led strip these can be tested with a 12v dc power supply
