Question about Refrigerators
Water dispensed from kenmore elite refrigerator (made in 2004), tastes awful. How can I correct this problem?
  • Refrigerators Master
  • 2,200 Answers
Hi
When the water in your refrigerator becomes foul tasting its time to change the water filter. You will find this at the very bottom of the front panel on the unit. You do not need any special tools for this job and you can purchase these filters from Amazon or Sears or any good electrical outlet.
The filter is reased by pushing the release button located just to the left of the water filter grille cap see photo
Remove the old filter and then remove the grille cap from it by twisting it counterclockwise and then reinstall the grille cap on the new water filter which looks like this. (this is a two pack) a1b47ce.jpg Reinsert the filter and grille cap until it clicks into place. It is recommended you run the water our of the water and ice maker for a few minutes to flush out the new filter. You can now once again enjoy the taste of fresh water! Hope this helps. Please remember to rate my answer. Many Thanks.
Posted on Jul 25, 2009
Dispensed water tastes like plastic
If the refrigerator is new, or if you used PVC cement, it's normal to get this taste for a few days. Take water out but not for drinking in the next days.
Oct 22, 2013 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Have an Elite 795.76282600 model and the ice tastes awful. Does it have a filter we need to change?
If your unit has a filter yes for sure you would need to change the filter.If your fridge has filter cheak your manual for part number or on the net.
Nov 27, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
No water or ice or lights on outside of door
I received my Elite TRIO 795.7101 2 weeks ago. I have ran over 3 gallons of water though it. I am still getting a bad odor and taste when I dispenser water from the door.
Nov 03, 2010 | Kenmore Elite TRIO® 7854 (25 cu ft) Bottom...
Our Ice and water has a awful taste now. It wasn't used for about 2 months, now it taste awful, do i need to have some one come look at it.
You need to replace your filter, but first run about 5 gallons (the more the merrier) of water through the dispenser. After you do so, then replace the filter and run another gallon of water through the dispenser. The idea is that you will want to clear all of the water through the reservoir inside the fridge compartment and give your water a "fresh start". IF after you try this you still have a foul taste, you can call a servicer and have the reservoir replaced but you should be all set with this method.
Good luck with this!
Aug 19, 2010 | KitchenAid KSRI25FN Side by Side...
No water coming from water dispenser.
It is possible the water control valve for that dispenser has failed and will not open. This happens a lot for those and the ice maker valves. All you need is the model number for your refrigerator and that will look like this for Kenmore. 213.564897 for example. and I will help you find the correct part number. Sea Breeze
Nov 24, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Moldy taste from Whirlpool side by side
The problem can still be in your lines, or in the dispenser itself. If you run hot water with a little bit of vinegar in the lines and let it sit for about 30 minutes and then flush the whole system this should take care of your problem
Apr 29, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Smelly water from door dispensor
I had the same problem. Drove me crazy and cost me about 5 filters at $50 a pop until I found the solultion. Water in the Sears/LG refrigerator that I have (french door trio) goes through the filter then into a container on the left front door of the refrigerator. That container stores the water so it can get cold and it also equalizes the flows in the system so that when you put your glass under the spigot the flow is steady and the water is cold. Problem is .... this tank can build up with algae/slime/foul tasting stuff. Since it is after the filter, no matter how many times you change the filter it will have no impact on the water in this container. That is why if you use the water spigot a lot, the water seems to get a little better (as the tank water gets diluted) but as soon as you don't use it for several hours or more, back comes the smelly water again. Solution for me was to remove the plastic panel on the inside of the left front door and clean the plastic bottle. It is pretty easy to remove with 2 screws and easy to pull off the hoses. I filled is with a little clorox and water and swished it around for several minutes then drained and rinsed it. Then I filled it again with a little clorox (like an ounce or two max) and put the container back into the fridge. Once in the fridge, I ran fridge water through the front water dispenser for about a gallon or so. This flushed out the chlorine in the plastic container as well as the lines between the container and the spigot. After about a half hour of work, my great tasting water in the fridge is back again. I've checked the taste on this water for several weeks now and no plastic/odor/bad tasting water any more. Hope this helps.
Oct 16, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Bad water & ice cube taste
Hello redwood City
Welcome
You said,
Your Kitchenaid Superba KSRG25FKBL15 has bad tasting water and ice cubes. You replaced the copper tubing which delivers the water to the fridge and that didn't help. You replaced the copper tubing again with plastic tubing...no better. Any suggestions? Your tap water doesn't taste this bad.You bought a Kenmore french door fridge with water dispenser in the door in July 2008. The fridge has a filter. A few weeks after the fridge came the water and ice started tasting really bad, unlike any bad water taste I have ever tasted. And your tap water is fine. The bad taste appears to be random. Sometimes you get a cup full of nasty water and sometimes it tastes fine.
First you must know you have a 1 year warranty and can have them come out to fix anything, no charge.If it persists. You will have to get tough and you , MUST INSIST THEY REPLACE YOUR FRIDGE
When installing the water line these were a part of the directions!
Did you do this before connecting the water line to your fridge?
"Place the free end of the tubing in a container or sink, and
turn ON the main water supply. Flush the tubing until water is
clear. Turn OFF the shutoff valve on the water pipe. Coil the
copper tubing."
Whirlpool remedy
Off-taste, odor or gray color in the ice
1.Are the plumbing connections new, causing discolored or
off-flavored ice? Discard the first few batches of ice.
2.Have the ice cubes been stored too long? Throw old ice
away and make a new supply.
3.Does the freezer and ice storage bin need to be cleaned?
See “Cleaning” or “Ice Maker and Storage Bin.”
4.Has food in the freezer or refrigerator been wrapped
properly? Use airtight, moisture-proof packaging to help
prevent odor transfer to stored food.
5.Does the water contain minerals (such as sulfur)? A filter
may need to be installed to remove the minerals.
6. Is there a water filter installed on the refrigerator? Gray or
dark discoloration in ice indicates that the water filtration
system needs additional flushing. Run additional water
through the water dispenser to flush the water filtration
system more thoroughly (at least 2 to 3 gal. [8 to 12 L] or 6 to
7 minutes initially). Discard discolored ice.
Let me know what works,
Thank You ,
HUUUM!!
Please remember to leave a rating.
Sep 25, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Refrigerators Logo
32 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
