Question about Samsung Digimax A400 Digital Camera
Memory card problem
I bought a Kingston 1GB memory card for my Samsung Digimax A400, but it won't fit properly, (meaning it won't go down all the way). One time, I got the camera case to close, and it formatted the card, but then the camera shut off. When I did it again, it formatted, then shut off. I had brand new batteries in the camera. What can I do?
  • 537 Answers
Are you sure you have the right type of memory card? Make sure you use an SD/MMC card. You might try another SD card.
Is this a new camera? I bought one once and the card slot was defective. I took it back right away, rather than trying to force a card into it.
Mike
Posted on Nov 21, 2007
Where can I find a download of Digimax A400 driver for Mac
You don't need a driver.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use iPhoto or any other photo cataloging program.
Oct 27, 2012 | Samsung Digimax S730 Digital Camera
Download software for Samsung digimaxA400
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as the free Picasa ( http://picasa.google.com ).
Mar 20, 2011 | Samsung Digimax A400 Digital Camera
I have a message on my digimax A400 screen stating CARD LOCKED can u help plse?
Look at the memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Feb 26, 2011 | Samsung Digimax A400 Digital Camera
Impossible to format my new memory card 4GB (chart error)
The A400 works with MMC and SD cards, 2GB or smaller. It will not work with higher-capacity SDHC cards.
Sep 20, 2010 | Samsung Digimax A400 Digital Camera
I bought a 4GB Memory Card for my Samsung Digimax D53. I put it the camera and Try to format it but it says check sd card. I tried another 1GB memory card and it worked. I know that the problem is with my...
Unfortunately, you can't. The D53 works with MMC and SD cards. Your 4GB card is actually an SDHC card. While it fits into the slot, it is electronically incompatible and will not work. Since this is a hardware issue, it is not something that can be changed with a firmware update. You need to use cards 2GB and smaller.
May 14, 2010 | Samsung Digimax D53 Digital Camera
Lost instal disc for samsung a4 digimax camera
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
Nov 04, 2009 | Samsung Digimax A400 Digital Camera
Mislaid instructions for Samsung Digimax A400 camera
You can find the manual in PDF format here:
http://downloadcenter.samsung.com/content/UM/200802/20080225143127765_A400_English.pdf
Mar 26, 2009 | Samsung Digimax A400 Digital Camera
My camera says card locked
Check the side of your media device, it will be locke.
See pic: http://en.wikipedia.org/wiki/Image:SD_Cards.png
Slide the little switch to the unlock position.
Dec 09, 2008 | Samsung Digimax A400 Digital Camera
RAM NOT DETECTING
I had the same issue on this board where it came with a Samsung 512 MB 533 MHz PC2-4200 DDR2 DIMM. I put in a 1 GB Kingston with the same specs (533 MHz PC2-4200 DDR2) and it would not recongize the Samsung anymore with the system reading as 1 GB of RAM instead of 1.5 GB. Tried every configuration and would only see the Kingston. It would only see the Samsung if I pulled out the Kingston regarless of the slots I use. So, I just bought the exact same make/model of Kingston and it recognized that fine and the system now has 2 GB of memory (max this board allows). And, I had already installed the latest BIOS for this board from Intel before doing all this so wasn't an old BIOS. I'm figuring the board didn't like something about the Samsung memory (speed, module configuration, etc.) that made it not play nice with the Kingston. If interested I bought the DM8400A/1G Kingston modules. And, this board appears not to support dual channel memory. Only has channel A, slots 0 and 1, and I read need two channels to support dual channel (seems obvious). Boards that supports dual channel memory normally have 4 memory slots, two for channel A and two for channel B, then put in matching modules in slot 0 for channel A and B and have dual channel memory access. And if want more ram, then matching modules in slot 1 for channel A and B.
Jun 25, 2008 | Intel D102GGC2 Motherboard
Samsung Digimax A400 Digital Camera Logo
71 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
