Back to:
Tags:
Technics RP-HP1200 Headphones
No sound in right ear (by 2 users)
posted by Mellors on Nov 21, 2007
My headphones have benn working fine for about 10months, now all of a sudden i have no sound through my right headphone
I have the same problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by josho77, posted on Aug 13, 2008
i have a similar problem but i have sound just no bass in the right earpiece.. i took them to a repairer but they said thier is nothing wrong with them, but i can definatly tell there is no bass in the right ear.
Solution #1
posted on Aug 28, 2008
Not Rated (0)
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
I am online looking for a fix for the same problem.
The right ear goes out when i have the headphones set to the smallest head size.
When i open a little there is a spot when there is some statik then the right ear works... but goes out pretty easy.... thinking it is a loose wire on the connection to the speaker...
How do i get inside? I have unscrewed all the tiny screws on the frame... but i think i need to get into the drum area.
looking for a broken out diagram online...
-Neil
www.myspace.com/luxuryestatik
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on No sound in right ear:
I don't want to Accept this solution
Solution #2
posted on Jun 05, 2008
Not Rated (0)
Guest
Rating: 0%, 0 votes
I had the same problem and noticed that after opening them, the wire connecting the right to the left was old, dry, and partially disconnected. Still trying figure out how to fix it because the wire is so thin.
Thank You!
Solution #3
posted on Nov 21, 2007
Not Rated (0)
mikemilw
Rank:Wiz Wiz
Rating: 84%, 233 votes
Check for a loose connection in the wire. Wiggle (carefully) the wire around both the headset where it sits on your heat. Also, check the other end (plug) to see if there are any shorts. If this simple "wiggle" test shows nothing, there may be a problem with the driver (speaker) in the right channel in your headphone.
Another thing to check and this should be obvious: make sure your balance on your stereo/receiver is set to be in the middle and not to the left.
Mike
Thank You!
Can you Help with these Headphones problems?
Headphones
I have a pair of wireless head phones that work great for...
Headphones
My headphones worked perfectly when I received them, but...
Headphones
no problem -- just want to be sure headphones are hooked...
i seem to have lost bass in the right ear piece.. can i...
This has happened to the last 2 pair I have bought. After...
Loading problems.
Repair Service
Find Headphone Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
Prescreened Contractors
Get Matched to Prescreened Home Media Professionals
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
