Request you to try following the below steps which might help:
(1)Try playing a different movie which is present on the computer.
(2)You may also try using different media player to see if the issue persists there.
Depending upon your answers I can check and see what can be done.
Try doing a restore to system default under system settings, sounds like somthing is just stuck in the memory but not for certain why it wont clear out...
Make sure you take off the little cap at the end (the one that spins -- just grab it and pull it straight off) and clean under it too. The rest of the brush may look perfectly clean but what happens is that hair gets stuck under spinning cap and, like a slowly growing washer, it pushes the whole brush toward the gear box. When it gets pushed over enough, the large yellow ring starts to rub against the side of the brush deck making it harder for the motor to turn the brush and you get that "remove and clean brushes" message.
Your problem isnt the player. Its not downloading the video fast enough at the play speed. Try pausing the video for a while to let the buffer get ahead then play it again. You can also go into the settings and change the length of the buffer from what I remember. It should be pretty clearly marked. Hope it helps!
