Question about Refrigerators
Side by Side Fridge door doesn't seal completely
We moved a side by side and the movers bent the bottom bracket on the refrigerator door - now it won't shut. We tapped the bracket straight and it helped, but it doesn't seal tightly when shut. Is there a way to increase tension?
    Champion:
  • 363 Answers
I would clean all of the door seals with a damp rag, and all of the contact points, also you can adjust the level of the unit a little in the front
Posted on Jul 30, 2009
Fridge freezer not closing comletely
Make sure there isn't something in the drawer that is holding the door open and that the baskets are installed correctly.
Sep 09, 2014 | Refrigerators
How to remove freezer door with water/ice dispenser on GE profile TFH22PRSM
TAKE OFF KICKPLATE ON BOTTOM OF UNIT. UNHOOK WATER LINE FROM QUICK CONNECT UNDERNEATH. ON TOP OF FRIDGE THERE IS A COVER OVER THE DOOR BRACKET. REMOVE THAT COVER. THEN REMOVE THE 2 OR 3 SCREWS HOLDING BRACKET TO TOP OF FRIDGE. THEY USUALLY ARE 5/16TH SCREWS.MAKE SURE THE HAVE DOOR SHUT OR SOMEONE HOLDING THE DOOR WHEN DOING THIS. AFTER REVING SCREWS AND BRACKET LIFT DOOR UP OFF BOTTOM HINGE AND WATER LINE FROM DOOR WILL COME OUT WITH IT.
Jan 17, 2013 | GE (PSS26MSRSS) Side by Side Refrigerator
When I close the fridge side the freezer side pops open a little and stays open. The appliance is 5 years old. This started very recently
a couple of problems can cause door problems first open door and check seal for damage [popped off trac or rip-tears]other is hinges worn- bent-loose --if seal is good at top and bottom of door are hinges check for loose if loose tighten -if bushing lookes like a little round washer type is broken or missing replace --needs realignment loosen top hinge and close door and adjust till door is straight and stays closed tighten door hinge done good luck
Jun 28, 2011 | Jenn-Air JCD2389G Side by Side...
MSD2754GR FRIDGE SID DOES NOT GET COLD OR SHUT ALL THE WAY UNTIL YOU LIFT UP THE FRIDGE SIDE AND SHUT. CAN I FIX THIS BY PUTTING A WASHER AT THE BOTTOME OF THE DORR OR IS THERE TOO MUCH ON THE DOOR AS MY...
The lower hinge on each door may have a door closing cam. It raises the door up ¼ inch when opening and this assist in closing the door. If it's wore out and doesn't work the door may not seal and the gasket can be damaged. Watch the operation of the door to see if it rises up when opened.
Leave the door shut and let the magnetic gasket hold the door in place. Put something between the bottom of the door and the floor to hold it in case it slips.
Remove the bracket holding the pin and hinge assembly taking note of order of removal of parts. Slide new cams on. You probably need two.
Jun 01, 2011 | Maytag MSD2456G Side by Side Refrigerator
Both the freezer and fridge doors hinge on the right, and the left hand side has sagged a little so neither neither door is sealing properly. How do I adjust the doors to raise the left side of the...
May 04, 2011 | Refrigerators
We have this model westinghouse fridge which currently opens to the right but are moving house and the fridge needs to open to the left. I can see holes on the left side with white plugs in them so it...
Yes depending on age. once changed doors never seal properly. because cabinet warps and seals flatten on one side. suggest to sell and buy another. you will never be happy if converted.
Aug 30, 2010 | Refrigerators
Swap door sides on hotpoint future RLA30 fridge?
tip unit over on side,placing an old blanket or similar on floor under unit.there are 3 little bolt/screws holding each bracket to the underside of unit,unscrew these/lay brackets on floor, slide door down off pin on underside of top.and unscrew this pin.change over from right to left replace door onto pin replace bottom hingepin,adjust door for" squareness " and tighten all screws lift back upright and switch on...will take a little time to settle down temp wise.... make sure seal sits tight all round good luck ..geoff
Feb 19, 2010 | Hotpoint RLA30 Compact Refrigerator
My brother moved and the movers removed the side by side doors
The dispenser assembly comes apart from the front. It should give you access to the waterline as it comes up from the bottom.
Eric
Jan 19, 2010 | Amana SXD524VW Side by Side Refrigerator
How do you adjust the doors to closed completely?
The lower hinge on each door may have a door closing cam. It raises the door up ¼ inch when opening and this assist in closing the door. If it’s wore out and doesn’t work the door may not seal and the gasket can be damaged. Watch the operation of the door to see if it rises up when opened.
Sep 03, 2009 | GE GSH22JFR Side by Side Refrigerator
Refrigerator door not closing
look at bottom of door. there is a metal bracket called your door stopper. this only allows door to open so far. if pushed open to far then you bent this bracket. bent back to normal position. your door will close
Jun 21, 2009 | Whirlpool Refrigerators
Refrigerators Logo
75 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
