Question about Whirlpool ED2FHEXN Side by Side Refrigerator
Won't dump ice
Whirlpool side by side with ice bucket on the door will not dump ice. We just had the relay switch replaced about a month ago.
    Problem Solver:
  • 17 Answers
Ice maker defost heater o/circuit,shuts off the ice maker will require a new ice maker
Posted on Jul 26, 2009
How do i prevent ice cubes from freezing in the bin
It is happening because the air getting into refrigerator through the small gap between the door so please
Change the refrigerator's rubber seal
Jul 26, 2014 | KitchenAid Refrigerators
Whirlpool Gold icemaker won't make ice
Try this and add tap water to the empty ice maker. Turn it on if off and if after the water freezes the ice maker cycles dumping the ice into ice bucket and if the ice maker does not refill with water on its own you will need to replace the=> 2188746 Water Inlet Valve
If the ice maker does nothing then replace the=>
2198597 Ice Maker Assembly
Thanks John Tripp Appliance 911
Feb 16, 2014 | Whirlpool Gold GS6SHEXNQ 25.6 Cu. Ft....
I cannot get the ice bucket out of the door. It has always been very difficult to remove unless it was just after I emptied the bucket and let it completely dry out before returning it to the door. I...
its just partially defrosted, ice chunks are up inside and through the unit, keep using the hair dryer,, also , once its defrosted completely, Look for a small leak , thats whats causing your problem in the first place
Jul 16, 2011 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
No ice comes out of dispenser
Sounds like the ice bucket is not all the way into its slot. Im assuming the ice bucket is in the freezor and not attached to the door.
Oct 27, 2009 | KitchenAid Superba Architect KSCS25INSS...
Kenmore side by side icemaker
Your product is an IDI (In Door Ice the bucket is in the door) or a Non-IDI? By the way, you mention the Ice maker. The thing is that if the ice maker is not runnning then you don't have ice to dispense and obviously the fact that the motor is working or not is irrelevant. So that's why I suppose that the problem is not the ice maker but the trajectory of the cubes from the bucket to outside of the door.
In the Non-IDI sometimes it happens that the safes in the bucket jump the locks were the bucket resides so the auger motor (the one that move the shaft so you get the Ice) is still running but you can't get ice because the bucket is not in the right position. Just try to relocate the bucket.
You can see if the motor is moving the shaft pressing the light switch that is at the top of the freezer. Then dispense, when you press the switch the main board thinks that the door is closed so you can dispense and see if the motor is moving the shaft.
Other failure mode is the flapper door, it depends if the dispenser works with full electronics or if it's an electromechanical dispenser. Full electronics dispenser use a stepper motor to move the flapper door so the failure is that when you press the pad and the flapper door is closing, if you press it again then it get stucked, the motor dispense but the flapper door is closed. With electromechanical dispenser, maybe is the dashpot mechanism.
If any of these solutions couldn't fix your problem please tell me. I think that I can solve this particular problem.
Feb 18, 2009 | Whirlpool GS6NBEXR Side by Side...
Refrigerator Problems
Check to see if there is some sort of interlock mechanism that does not allow ice to be dumped if the door to the freezer is open. I have a side by side and the "switch" got stuck - simulating the door being open... and when that occurs, ice maker gets turned off.
Feb 04, 2009 | Whirlpool GS6NBEXR Side by Side...
Ice does not dispense through door of kenmore elite side by side
take ice bucket out, dump ice, clean with hot water and let dry ,,,, put ice back in and try it ,,, bucket is most likely frozen up thru ports
Nov 28, 2008 | Kenmore 53642 / 53644 Side by Side...
Whirlpool side-by-side refrigerator ice dispenser
First pull out the ice bucket and close the door.  Set for cubed ice.  Press the button for ice to come out and listen for a loud clunk noise.  That is the sound of the solenoid.  You can open the door, hold the light switch and press the button and watch for the solenoid moving up and down.  Solenoid is at the back of the freezer in a little square opening where the rod on the ice bucket goes into.  If that solenoid is moving ok then put the bucket back in while the solenoid is in the down position and cubes should work.  If solenoid is not working then it will need to be replaced.  Let me know what you find.
Oct 13, 2007 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool ED2FHEXN Side by Side Refrigerator Logo
321 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
