If the timer piece you are referring to is behind the square white cover, and it's moving slightly back and forth, you should visually check the ice making area it's self to see if the ejector fingers are jammed with ice, or against the ice stripper. Ice Maker jams can be caused by reduced water pressure to the unit mainly from the water filter, your water filter in the toe kick should be replaced at an interval of 6 months to a year, regardless of filter status light. When water pressure is low, not enough water fills the unit and the undersized cubes can become lodged or stuck in the ice maker while being ejected, equally so if there is an over fill situation caused by other failures the ice maker can't eject at all. Pleazer Appliance...
Ejector fingers
Ice Stripper
