ESP 7 printer that had a paper miss feed & print head is missing
I have ESP 7 printer that had a paper miss feed & then it stated that the printer head was pissing or miss alined. I have removed the ink cartridge & carrer then replaced them but the printer still state that it miss alined. What else can I do?
  • 295 Answers
Go to www.kodak.com/go/printheadsupport and click on 3rd link on how to replace a printhead correctly. take it out and then again put printhead back in to the carriage and press the bulls eye backward u will hear a snap sound confirming thet it has been placed correctly.install ink cartridge .your issue will be resolved. contact kodak @ 1800 421 6699 for further assistance
Posted on Jul 27, 2009
Printhead Loose or missing. Install printhead or ink cartridges.
THE PRINT HEAD is the LASER that puts the image on the drum which puts the image on the transfer belt then paper or the drum puts on the paper. Missing the Print Head !!!!!!!!!!!!!!!!!!!! did you get it second hand? Not something you can get at a store. Contact the company and see about it being repaired.
Nov 15, 2015 | Kodak Esp 2150se Wireless Office...
Why is print head loose or missing?
The print head houses the printer LASER if it is missing NO Printing. OR Loose normally the print head is located well inside the machine so you cant see the LASER beam when it is working.
Take the machine back to who sold it if the LASER ?PRINT HEAD is missing
Nov 15, 2015 | Kodak ESP Office 2150 All-in-One Inkjet...
Kodak ESP C315 Error code 3513 missing print head
Kodak esp c315 .i have the kodak esp c315 and keep getting the printhead loose missing or not installed correctl
Apr 14, 2014 | Office Equipment & Supplies
Black and red ink missing on the paper
Blocked print head nozzles
Inkjet printers need to be used frequently to prevent blocked print head nozzles. You may have blocked print head nozzles.
Try the printer maintenance to clear the printer nozzles.
After several deep cleaning attempts and there is no improvements in the print then a new print head is required. Also try - Removing the print head, run it under hot water for 2 mins, then let soak for 10 min. then used a can of compressed air to dry thoroughly. It may fix the blocked nozzles.
A new print head maybe expensive and it maybe more cost effective to purchase a new printer.
Sep 04, 2012 | Kodak ESP 3 Multifunction Printer/ Copier/...
USELESS! I guess the life of an ESP 3 is up to a year, because after Kodak replaced my first ESP 3 with a second, I'm now having issues. It's also MOST frustrating that if one cartridge is empty and...
Regarding the empty ink cartridges, ink is a lubricant for the print heads. Some color ink is used even if you only print in black or viceversa. If you printed with a color missing, you could destroy that print head from the friction of running without ink to lubricate it. That's why most printers won't allow you to print with a color missing even if you aren't using it.
If you allow a color to go empty, the residual ink in the head could clog and become permanently blocked. You would never be able to print that color again. So always replace ink cartridges as soon as they are empty.
Regarding the printer not being able to detect the size of the paper, you probably need a firmware update. Here is the support information from Kodak website.
And I have to agree with you, printers don't have a very long life cycle, but you should get at least 2 years out of it! Good luck!
Dec 06, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Print head missing reinstall
Follow www.kodak.com/go/itg and try the step by step solution.If issue persists,Call Kodak @1800 421 6699 and get a new printhead free of cost.....Printhead has gone bad and it is the part in which we install the ink cartridges.It takes the ink out of the cartridges and spit the ink on the papers,...Cheers and Enjoy..
Dec 29, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
My esp5 all in one printer says there is an error a paper jam but there isnt one please help
1. Take out both the ink cartridges, wait for 5 seconds.
2. Take out the printhead, and close the printer access door
3. Take out the power cable without turning OFF the printer, and wait for 30 seconds.
4. Now connect the printer with the power cable, and turn ON the printer.
5. If the printer is giving an error” printhead missing”, now put the printhead back.
6. Closing of the printer access door brings up error message “missing cartridge.”
7. Insert both the ink cartridges into the printhead.
8. Close the printer access door, and wait until printer gets ready for printing.
9. Give a print command after loading paper in the upper tray.
Best of Luck
Saj
Oct 27, 2009 | Kodak ESP 5 Printer
Incomplete printing of black text
try this.
OK, Canon will hate me for posting this.
1. Remove ink cartridges
2. Remove print head
3. go to sink or tub (stainless steel, not plastic type), pick up a roll of paper towel on the way.
4. Fold several layers of paper towel and place on flat surface.
5. Run hot water until HOT!
6. Turn hot water back to a dribble.
7. Run the dribbling hot water through print head, be careful not to wet the gold contacts.
8.When water running through print head is clear, place print head on paper towel.
9. Repeat number 7 and 8 until no colour shows on paper towel.
10. Gently DAB print head (DO NOT WIPE) inside and out with dry paper towel until dry.
11. I normally replace print head after drying, but you may wish to let it air dry overnight.
12. Replace print head in printer and install cartridges
13. Start printing.
I do this to all 4 of my Canon printers every 6 months or so.
If any colour fails to print after this process it means your print head probably needs replacing.
Jun 30, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Horizontal colored lines through grayscale printed photos
Hi George,
It sound's like an ink-feed issue:
1) Dirty heads, even after cleaning
2) No-ink or poor quality ink
3) Damaged head: some are part of the cartridge, some are not
4) Air bubbles in ink
The test page is typically not as hi-res nor as saturated as a
photo print. The hi-res photo puts the greatest demand on the print head.
The color lines you see are actually lines of missing color,
where the head has failed to deposit ink, so one or two primary
colors are missing from the complete picture.
For example missing yellow will make a blue line.
Missing magenta will make a green line
Missing cyan will make a red line.... etc..
Clean the heads again and again, print again and again,
hoping to flush the system.
BUT, keep in mind that cleaning wastes huge amounts of
ink and tiny little cartridges of ink cost more than many new printers.
Martin
Apr 24, 2008 | Canon PIXMA iP90 Mobile Printer
261 people viewed this question
k24674
jasbo
jasbo
