Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Washer not filling or agitating, during wash & rinse cycles
Washer was purchased new in 2/09. Worked for one load this a.m., then quit. It runs thru the rinse cycle to drain & the spin cycle.
  • 6,784 Answers
HI, this will occur if the timer mechanism has become unstable. you will need to replace this defective timer control module asap, if possible.
Posted on Jul 26, 2009
After working well for six months, my washer now expels water at random points during the wash and rinse cycles.
Check inside the fill hose for debris. There is a screen designed to block debris from getting inside the machine valve. If the screen builds up with debris the water slows down. Sounds like the water is filling too slow. Also the unit and/or the load may not be balanced causing it to stop and drain out. If it's okay then see what lights are blinking when these events occur and post here.
Jun 06, 2013 | Haier HLP21E Top Load Washer
Water won't quit filling and agitator does not engage into the cycle.
Did you solve this problem -have one doing the same-feed back -please!
Mar 22, 2012 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Whirlpool top load washer no low-speed agitation. The unit fills, starts the wash cycle with normal agitation, but after a few minutes it just sits there soaking until the it's time to drain/spin. Drains...
Either the wire going to motor for non working speed is loose or damaged, or motor is bad. It could also possibly be timer not sending power to motor for that speed.
Sep 27, 2017 | Whirlpool Ultimate Care II LSQ9549L Top...
No water during any cycle.
if no water is coming in how is it agitating?is it filling at the beginning,then it starts to wash the clothes,now does it drain and then it won't fill again,send the model number and more info,
Jul 02, 2010 | Kenmore 24032\24036 Top Load Washer
Will not spin on any rinse cycle
Hi, This washer does not have a belt. While the washer is agitating, if you lift the lid will it stop? Some models will agitate but not spin if the lid is up. It sounds to me like the lid switch might be going bad.
If you will get me a model #, I can look this up for you and give you a better idea.
Vic
Jul 05, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Agitater will not agitate during the wash cycle or rinse cycle. it will fill and . drain and spin.
2 things to look for , first check a SWITCH where the lid closes , this will send a signal that is OK to WASH & RINSE cycles , it could be that the SWITCH is either loose or defective , check it out with a multimeter. second , you have to open the washer and check at the bottom a small motor where the discharge hose is connected , remove motor and check for debris , usually it gets clogged , not letting to do the wash & rinse cycles, hope this helpful , AJ
May 09, 2009 | GE WBSR3140DW Top Load Washer
Washing machine not agitating during wash cycle. Only when rinse
This occurs when your transmission has failed & requires replacement.... Good luck!... Bill
Apr 28, 2009 | Maytag MAV4755 Top Load Washer
Basin will not fill with water during rinse cycle but will agitate and spin.
most new washers have cold water only rinse and spray rinse ck cold water coming into machine during wash if no cold comes in suspect cold side of fill vale not opening ..could be wiring issue or a bad valve
Oct 24, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Won't Agitate
If you can hear the motor during the agitate cycle, the the transmission has stripped gears.
Dec 17, 2007 | Frigidaire FWS833A Top Load Washer
Agitator Not Working
check your motor coupler, lid switch
Nov 08, 2006 | Hotpoint VBXR1090D Top Load Washer
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
144 people viewed this question
Dan Webster
Dan Webster
Sal De
