Question about Frigidaire FRT17B3A Top Freezer Refrigerator
Fridgedaire freezer not staying cold. I can
Fridgedaire freezer not staying cold. I can unplug it overnight and plug it back in and it works ok for about a week, then won't stay cold again...Tried temp controls in middle and coldest, same issue... any help appreciated.
Did anyone help you with this problem? i have a similar problem but my freezer works fine in the summer. it does not stay cold enough in the winter. i keep the frige in my garage as a spare but it's not very helpful when it doesn't work! a repair person told me it was too cold in my garage for the freezer to work...not sure why, the frige part works fine. i'm looking into a blanket insulator from appliance zone to see if that will help.
Posted on Feb 06, 2010
The freezer is cold but why is the refrigerator warm?
Likely, either your circulation fan has stopped working due to icing, or you have ice buildup in the cold air duct between the freezer and refrigerator. Try unplugging your refrigerator overnight with the doors open, mop up any melt water with towels, then plug the refrigerator back in next day. Listen for the circulation fan in the freezer and, if it is not working or not moving air, replace the circulation fan.
May 21, 2015 | Refrigerators
My fridgedaire fridge FRT856embg wont get cold on the bottom
Im not familure with this item but on the older style fridge ice would build up in the freezer blocking the air ways to the bottom half of the fridge in this case you would need to remove the food from the freezer and fridge and unplug it open the doors and let it thaw out for a day or so I wish you luck and I hope this was helpful
Dec 07, 2012 | Frigidaire FRT21H8 Top Freezer...
I have a Jenn-Air side by side frig. The freezer side cools too cold, the frig side not enough. 2 weeks ago I took all the food out of freezer and noticed ice build up on back. I unplugged unit, let it...
If the freezer is staying cold it sounds like a defrost system problem. A bad timer, heater or thermostat can cause frost to build up on the coils and block air flow to the refrig side. Check out ACMEHowTo.com for troubleshooting the defroster problem.
There is a small duct between the freezer and refrigerator side if this is blocked the frig side won't cool.
Jan 09, 2010 | Jenn-Air JCD2389G Side by Side...
ZFSB26DRESS water runs warm and freezer not staying cold.
It sounds like the condenser coils , the coils by the compressor , need cleaned badly . This (and the compressor cooling fan) , can cause the compressor to cut off on overload (due to the heat) , thereby not circulation refrigerant thru out the freezer coils .
The water line goes from inside the freezer door ( cold ) , under the refrig ( warm ) , then to the inside refrig water reservoir ( cold ) . After that , you should get cold water , until the reservoir is drained of cold water .
Nov 19, 2009 | GE Monogram Side by Side Refrigerator
Freezer ok, fridge not cold
Often you can unplug it overnight and it'll melt out, correcting the problem for some time.  The electric element might be burned out, although I'd suspect the defrost timer.  It's usually located behind the unit, near the bottom.  Often all you will see is a 3/4" hole in the back plate with a flat screwdriver slot.  Turn it (only turns one direction) with a flat screwdriver, and all will work fine for some time (usually).  If not, standard procedure is to replace the defrost timer assembly, as the clock motor has likely gummed up.  Maybe available at http://www.repairclinic.com, or a local appliance repair shop.  They're often generic, as in not specialty oem specific.
Jul 16, 2009 | Freezers
Hotpoint CTF15ELD top freezer refrigerator - freezer O.K. refrig too warm
It's likely the door was inadvertently left open, and the cold air passages from the freezer have built up enough ice that the cold air from the freezer has no way to enter the refrigerator. Check the cealing of the refrigerator. If you can see or feel ice in the passages between the freezer and fridge, you can probably solve the problem by finding a safe temporary home for your food, and leaving the refrigerator unplugged overnight.
May 25, 2009 | Hotpoint HTS16HBR Top Freezer Refrigerator
Frigidaire upright freezer Model #FFU17C3AW1 Not keeping cold
Yes that is the correct part number.
If a new cold control does not correct the problem. Replace the compressor start relay.
Mar 12, 2009 | Frigidaire 14.1 cu. ft. Upright Freezer...
Fridgedaire modle # FRT18S6AW0 - freezer appears ok (staying cold) but fresh food area gets warm -- door seal appears ok; made sure that the vents on bottom shelf were unobstructed to allow air flow;...
If there is any frost on the back wall of the freezer you have a defrost problem and it is keeping the air from getting to the refrigerator section. Also make sure the condenser under the unit in the back is clean. Lack of air flow to cool the refrigeration can cause the same type of problem.
May 07, 2008 | Refrigerators
Frigidaire FRT17B3A Top Freezer Refrigerator Logo
372 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
