SOURCE: getting this message below with ALL emails I send with Outlook
Do your messages actually get through or are they rejected? And is this with Outlook? It appears likely there may be a piece of malware involved...
If you need assistance, please let me know some more of the details. Thanks for rating FixYa!
SOURCE: I want to add additional memory of either 1 or 2 gigs. Only have 512. How do I install it?
You can find the memory type and specifications for your laptop here:
http://www.crucial.com/store/listparts.aspx?model=Business%20Notebook%20nc6220
When you get the memory, it'll come in 1 or 2 little sticks with gold contacts. You'll need to turn off your laptop completely, flip it over and lay it flat on a table. You'll need a small phillips head screwdriver to open the access panel. Your laptop has one or more access panels on the bottom. One of them will have memory modules in it. You'll know when you find it because the sticks are laying flat near the surface. TO remove them, there are two small clips on the sides of the module that hold it in place. If you unclip the module by pressing outward on these clips, the module will "pop up" so you can remove it. Install the new RAM modules by reversing this process and booting the laptop up. Hope this helps!
SOURCE: Can I open the case of the Dell Inspiron 1200 to upgrade internal
System has only 1 memory slot, and Max is 1 GB
SOURCE: I have the M530. It
Your camera is using the internal memory instead of the card. To get it to stop doing that, with no card in the camera, go into the menu and find "format" and follow the on-screen instructions to erase the internal memory. Then, in the future, don't use it again....always have a card in the camera.
This item appears to be a tablet. You may find a more responsive answer by re-posting in the appropriate forum.
