Question about Maytag Neptune MDE7500AY Electric Dryer
Maytag Neptune mce8000ayw belt replacement
This is the dryer with cabinet on top for shirts and pants or coats. Anyway, the belt is broken, I have the front off, but still can't access it enough to get the new belt on. How do you get the top off to have better access or is that even necesary?
protek480
  • 1714 Answers
SOURCE: How do you remove the bottom cabinet of a Maytag Neptune Dryer
OR..... you could watch the video...
Posted on Aug 07, 2009
  • 178 Answers
SOURCE: Maytag Neptune Drying Center MCE8000AYW
Email me a response to robert_fawbush@yahoo.com and I will be more than happy to provide you with parts breakdown illustrations and possible part numbers and locations to replace. The service amount verses the do-it yourself amount will be well worth the savings. Typical labor cost on appliances are 75.00 per hour and a mark up on the parts. If you feel you can do it yourself after getting the photos e-mailed to you, it will save you approx 200.00 if not a lil less or a lil more.
Please rate this solution "fix-ya" if it seems to satisfy your question.
Posted on Apr 14, 2008
onthejob5130
  • 640 Answers
SOURCE: Gaining access to dryer
open door you see 2 screws holding hinge a a piece,,remove them now remove the 2 screws opposite them ..just let door stay for now...pull the front panel to you its just on 2 clips...now at each corner of the bottom of the top theres a upside down l shaped clip remove 5/16 inche nut driver...ok left the top...swing it up and back ,,so it will lean back,...remove 4 bulk head screw and the door switch connection..and your there..onthejob
Posted on Jan 29, 2009
  • 127 Answers
SOURCE: Can the drying cabinet on the Maytag Neptune DC be
Sorry to say it cannot be removed and a simple top placed in its space.. I am sure if you wanted to tinker and mess around with it you might be able to come up with something, but there is no 'factory' conversion such as you speak.
have fun, and best of luck,
ttfn
Posted on Feb 04, 2010
SOURCE: Maytag MCE8000AZW Neptune Drying Center. Display
my bottom dryer the light dont come on or when i press start it wont start all i hear is a click...any solutions?
Posted on Jun 20, 2011
Why does my Neptune moder number mce8000ayw dryer not tumble?
If the motor runs, but the drum doesn't rotate, check the belt, part # 341241. It's probably broken and off of the drum.
May 14, 2014 | Maytag Neptune MDE5500AY Electric Dryer
Manual on How to replace belt
  • 1
    Remove the power cord from the wall outlet.
  • 2
    Open the dryer door. Remove the screws located along the inside of the doorway with the Phillips screwdriver.
  • 3
    Pull the top part of the front panel away from the MDE5500AY dryer to disconnect it. Lift the front panel up to disconnect it from the metal clips on the dryer cabinet.
  • 4
    Unplug the wire connector leading to the door switch.
  • 5
    Unscrew and remove the four screws connecting the front panel to the rest of the cabinet. Lift the front panel up and away from the dryer to remove it.
  • 6
    Pull the idler pulley toward the left to relieve tension in the belt. Slide the belt off of the idler pulley and the Neptune dryer drum.
  • 7
    Route the new dryer belt around the drum and along the pulley system. Release the idler pulley to restore proper tension in the belt. Rotate the drum to ensure the belt is positioned properly.
  • 8
    Replace the front panel onto the dryer cabinet. Replace the four screws that connect the front panel to the cabinet of the MDE500AY dryer.
  • 9
    Plug the wire connector into the door switch assembly. Lower the front panel down into its original position.
  • 10
    Replace the screws along the inside of the doorway.
Sep 18, 2012 | Maytag Neptune MDE5500AY Electric Dryer
Maytag mce8000ayw start button won't work
your starter button needs checked at least but most likely replacded
Feb 21, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Jan 28, 2009 | Maytag Neptune MDE7500AY Electric Dryer
Dryer makes noise like a bird chirpping.
You'll need to access inside the cabinet and oil the tires and belt pulley. Hope this helps!
SOUNDS LIKE A BELT IS BREAKING AND HITTING THE INSIDE OF THE CABINET
Remove the top sheet metal screws at the top rear of this unit,,then pry up the top,,,back to forward!!!,,,then have a look at the belt,,,,Replacement cost of belt usually around $12
Jan 11, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune DC Model# MCE8000AYW leaks water from the right side of drying center unit while using the "Wrinkle Release Hanging Dry Only" feature. The leak happens during the steam portion of the cycle....
Stop using the water bottle because the water is overflowing the heater steamer pan and will short the heating element and the part is no longer avaliable and the top will stop drying.
Mar 27, 2008 | Maytag Neptune MCE8000AY Electric Dryer
Squeeking in lower dryer
remove the rear panel. unplug dryer before doing anything
Oct 24, 2007 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune MDE7500AY Electric Dryer Logo
857 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
