Question about Samsung SYNC SGH-A707 Cellular Phone
Front display is orange
My sync has a red/orange streak in thefront display. att says the screen is cracked. I can't see any damage. Got a replacement and after 3 weeks, the replacement has the same problem. I had no insurance and att wants $210 for the now broken replacement.
  • 12 more comments
  • notluvinsync Nov 22, 2007
    I am curious about the (phantom) cracked display. Is this somewhat common with this phone or am I just unlucky?
  • Anonymous Nov 27, 2007
    I have an orange line running vertically through the front display. It's looks like a crack too. I think the screen may crack just from the pressure of holding the phone to your ear with one finger on the top half.
    Cingular replacement had me pull the battery to inspect the water exposure dot on the inside. Since it was red and indicated some exposure to moisture, they rejected any claim even though I was calling about a cracked LCD. Every thing else works fine on the phone. I believe that the screen failed physically under normal use.
  • kennan Nov 27, 2007
    My phone has the same problem. Screen worked fine for four months, then the orange blob appears. There is NO sign of any type of damage to the phone or screen!. Called ATT warranty department, they say is phone was damaged and now the phone has no warranty remaining. They were able to tell the phone was damaged( they concuded this sight unseen and from hundreds of miles away, pretty impressive). The orange blob has several postings on the WEB on this Samsung Sync. Thanks to the useless ATT customer service, I will look forward to changing cell phone service.
  • Frank Spade
    Frank Spade Nov 30, 2007
    I Have the same exact problem . I returned my sync 2 weeks ago they sent me a replacement and in less then 2 weeks the front display was defected again I Just recieved my old phone with a bill for $210.00 Ny phone is cased and hasn't been dropped I feel this is a basic defect in the phone.
  • Anonymous Jan 11, 2008
    I bought two of these from ATT last January. On both, the front screens are now blue and orange. One after 5 months, the other after 9 months. AT&T store where I bought them says they were damaged by the user (me). No way. I am going back and and making a small scene and putting this on record. The warranties expire in two weeks. I will not use 'ATT if they continue this foolishness.
  • deltron zero Jan 13, 2008
    same problem came up for me 2-3 months ago after owning it for about 6
    months. the inside screen is fine so i can still use it, but the
    outside screen cracked while in my pocket. at first i thought maybe
    it's some glitch because the outer plastic didn't seem damaged so i
    restarted the phone, but i still got the same colors.
    eventually it got
    bigger, and after contemplating sending it back to claim a defect, i
    happened to stop by the kiosk at the mall where i bought the sync and
    asked some guy if it can be replaced under warranty. first thing he
    said when he saw it was "it's cracked, they won't cover that" and i
    asked if there was anything i could do about it, and he said "you can
    buy a new phone" and then tried to sell me his own bb lame.
    hopefully i can find a broken phone on ebay and use its working lcd module (from what i've seen, the front and back lcd are one piece..can someone confirm?)
  • Anonymous Jan 23, 2008
    in two peaces
  • Anonymous May 15, 2008
    I've had a Sync for almost a year and my front screen just cracked, giving me the dreaded orange blob on the looks like the sun with a corona around it. I didn't drop the phone or stress it in any way. Its obviously a defect in the design..I know that I shouldn't have bought Korean garbage, and I'm sure nobody is gonna repair it. Everything about cellular phones and service plans is an absurd rip-off.
  • Michael6 May 16, 2008
    Same problem here. Mine just started the orange front screen thing yesterday. I can't see any damage as far as being cracked or anything. I keep it in a case and so far have not dropped it or anything. From reading here it sounds like a phone defect. If it costs $200+ to fix i will just keep my orange screen.
  • Adam Ostrow May 20, 2008
    Yup, same here. The phone was in my pocket and working fine as I went to dinner, I didn't fall or run into anything or any other thing that could cause it to break, and then I get home and the screen is flickering. Now there's that orange **** flooding the outer screen, so now I can't see when I have a message (not that it was ever THAT easy with the quickly turning-off screen), and I can't use the active flip to answer it anymore. Same time frame, about 8-9 months.
  • b2537b Jul 06, 2008
    I have had two of these phones and the problem is a cracked lcd screen under the outer clear plastic shell. It takes virtually no pressure at all to break this. You can do it just by sitting down with the phone in your front pocket or by exerting pressure on the front screen with your hands when holding it. Samsung is aware of this problem (according to the retailer that I bought my second phone from) but they won't admit it's a design problem and claim it physical damage which is not covered. The Samsung D807x, a slider, has the same problem. Your best solution is to stay away from Samsung as there is no fix and they won't support their product.
  • mvl3589 Jul 08, 2008
    I have 3 SGH-A707's which is now been replaced with teh Samsung Sync. I'm 2 weeks past the annual purchase and one just blacked out with the lower 1/2 looking like a line graph. If I open the phone and close the front display works, but the inside screen does NOT. Another of my famous 'Syncs' has lost/dropped calls since day one. Sims card was replaced, but still drops call or displays emergency calls only.
    And AT&T wants $210 for a new one; That would be out of my pocket $640 times 2 = $1,280 for 3 phones for 1 year. Hmmmmm. They HAVE to have better options!!!!!!!!!!!!!!!
  • Anonymous Nov 05, 2008
    Same problem for me. I went to sleep and woke up to find the LCD cracked.
    Best solution....
    Take your own or your girlfriend's nail polish. Paint the window black. It hides the orange splotch.
    Then set your phone so that you hit a button to answer it and not active flip.
  • Workmaster May 16, 2009
    No, this is a common problem with this phone. Mine did the same thing, cracking without reason. Frustrating, especially when you go to the AT&T store and they tell you that You've invalidated your warranty because of it.
  • 537 Answers
Look on eBay for this same phone to see if there are any phones that you can buy for cheap that have this part. Just don't buy one with a broken screen :-P
Posted on Nov 21, 2007
I totally agree this phone sucks!!! My screen just went blank after 2 months of use!
Posted on Oct 29, 2008
Samsung should recall and replace these phones at no charge!!!!
Posted on Jul 08, 2008
Posted on Jun 13, 2008
My A707 phone screens (both) just stayed blank when I tried to turn it back on after charging. I carry it closed and use a bluetooth headset for ordinary use. So maybe there really is a problem with this phone!
Posted on May 10, 2008
You can remove the cracked screen on the front display by removing the outer red shell GENTLY! Then extract the shattered screen. You will have a very bright but clear display.
Posted on Jun 03, 2009
  • 8IIIIID Jun 03, 2009
    **** all of u jackassssses
My husband experienced this same thing with his phone. We called att who told US that the phone was under warranty and they would send a replacement free of charge if he would send them his broken phone. They sent us back his old phone (missing the battery and cover) and new sync phone along with a bill for $210.00 which was not our agreement. We would never have purchased another sync. If we were planning on spending $210.00 we'd have picked a phone that wouldn't break in 2 weeks. They said pay or we'll terminate your service. My husband wanted to pay to keep his service. I said tell them to reimburse us for the first phone and then we'd pay the $210.00. Still waiting to hear from them one year later...and we haven't paid for the new sync yet.
Posted on Oct 25, 2008
There are lines through the screen (red and blue) like the screen is cracked but the screen s not cracked as far as i can see
If the set got struck on the screen the screen itself may not be cracked but the panel (The entire front where you view the image is called a display panel) may be damaged inside.
A good photo would tell me--usually it will look like a odd burst or lines and or colors more pronounced where the screen was hit and spreading out in a uneven pattern---Google for "Pictures of Damaged LCD or Plasma screens"
Dec 06, 2012 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
Cracked screen
This is the end of the road for this set----the screen is part of the DISPLAY PANEL--ENTIRE front screen unit and if damaged it is fatal.
Cost of the replacement part alone will exceed the cost of the set new or replacing it with a new set.
sorry, but the Panel's are very fragile in nature.
May 21, 2012 | Samsung LN46A550 LCD TV
The screen went black with a red streak up the middle
Hi,what makes the phone to display phone half of it is white with this big black dot to the side or red streak up the middle, is because there is a flex inside that connected to the screen of the phone that makes the phone display is faulty and it needs to be replaced so that the screen can be as one again.
Take care.
Jun 30, 2010 | LG Vu CU920 Cellular Phone
My question concerns a Toshiba Regza model 52HL167 which displays a perfectly normal picture on the right half of the screen and a blurred and streaked image on the left half of the screen. The lcd...
This will most likely be down to your screen controller board, Take the back of the tv and look towards the top middle, You will see your screen cable go into a rectangular board this is sometimes covered by a metal plate, remove this and check Ebay or Google for a replacement, there will be a part number on the board
Hope this helps?
Mar 05, 2010 | Toshiba 52HL167 52 in. LCD HDTV
I havee anotebook pc thats cracked in
I take this to mean the screen is cracked and getting worse. The only way to repair a cracked screen is to replace it. You can send this to a company like mine or someone locally. Why not call HP about a warranty replacement?
Aug 05, 2009 | Compaq Computers & Internet
Projector projects red screen.
My take on this...if that pin was *shorted* to another pin in the connector and not just bent, you could be looking at a damaged video input section. The pins in the video connector consist of the 3 color signals(red--green--blue), their individual grounds, and syncing. If this has indeed happened, which is *VERY* easy to do, the projector must be repaired by a service facility.
May 05, 2009 | Dell 3400MP Multimedia Projector
Screen is damaged - is it replaceable?
While actually replacing the screen is a simple task, the cost of the replacement could eassily be the same or close to a replacement set. Check in your area for the cost of a replacement panel. I suspect the cost will be too high to be practical. It loks like this may end up in the trash.
Sorry about the bad news...
Jan 27, 2009 | Dynex 32 in. LCD Flat-Panel HDTV
Broken exterior screen
i have the same phone and what happen that the computer screen gave off a static charge. the phone needs replacing there is no fixing it.
Aug 30, 2008 | Samsung SYNC SGH-A707 Cellular Phone
Horizontal streak in screen
Does it only show up on Cable or does it shows on all Dvd, Cable, Sat, etc ?
Jan 09, 2008 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Front Display LCD is Cracked. Where can I get the part?
The front LCD on my Sync broke within 2 weeks while it was in my pocket (no dropping needed). I also agree that there is a design flaw with the front screen. Unfortunately, ATT won't take returns on damaged phones which I tried numerous times arguing the phone was defective and it wasn't user negligence. To make me more furious, one manager tried to sell me a case for my now broken phone. I recommend finding a non-functional phone on eBay. I got one for 20 bucks + a backup battery and a car charger.
Nov 22, 2007 | Samsung SYNC SGH-A707 Cellular Phone
Samsung SYNC SGH-A707 Cellular Phone Logo
295 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
