Question about Mitsubishi WS-65511 65" Rear Projection Television
WS65511 green flashing light on front panel. Caps have been replaced and still no fix. Can you help?
  • 67 Answers
Vote if help u
Posted on Jul 25, 2009
My tv is a mitsubishi model ws65511 our power went out when it come on tv wont work just flashes green reset wont help
thats caused by failed DM caps which discharge during power outage and then cannot be recharged when power is restored. the mitsubishi repair kit called the WS48511 - WS65511 DM repair kit available from www.tvrepairworld.com should solve the issue it has the replacement capacitors and the CD with repair instructions.
Jun 02, 2012 | Mitsubishi Televison & Video
I have a mitsubishi rear projection tv model ws65511. When i turned it on this morning all the timer light started to blink green. I tried to reset and it still blinks. unplugged and plugged back in and...
that's a very common problem for that model which is almost always caused by bad DM capacitors. Replacing them should solve the issue. You can get the Mitsubishi repair kit called the WS45511- WS65511 DM repair kit from www.tvrepairworld.com which has the caps and the CD with detailed repair instructions.
Oct 04, 2011 | Mitsubishi WS-55805 55" Rear Projection...
Green light on front of TV keeps blinking after power outage. I have tried powering back off and on and resetting the tv. Nothing works
Thats caused by weak DM capacitors when power is lost even for a minute the caps drain and then cannot charge again when power is restored so the led will blink non stop. The Repair kit called the WS48511 - WS65511 DM repair kit should solve the issue. The kit contains the caps and the cd with repair instructions. The kits available from www.tvrepairworld.com
Aug 02, 2011 | Mitsubishi WS-55511 55" Rear Projection...
The power wet off and now the timer green light is flashing and it wont turn on model # ws 55511
Thats caused by the 7 capacitors on the DM power board. They discharge when the power is lost and then cannot recharge when power is restored and the indicator light will blink non stop indicating the DM has not completed the boot sequence. Replace the DM caps. The WS48511 - WS65511 DM repair kit is the correct repair kit for your model. You can get the repair kit from www.tvrepairworld.com
Jul 08, 2011 | Mitsubishi WD-52525 52" Rear Projection...
WHEN WS65511 IS TURNED OFF GREEN POWER LIGHT FLASHES
According to the Service Manual:
Slow flashing power light means the Timer is set for automatic turn on.
Dec 08, 2009 | Mitsubishi WS-65511 65" Rear Projection...
I have the ws65511 and the famous green blinking light and i have changed the 7 caps and no luck..anything guys?
Change the whole board.
The IC is deffective it dead.
95% of the times the board with IC will dies. Boards with burn parts,will have to much juice to the IC it will die.
Jul 25, 2009 | Mitsubishi WS-65511 65" Rear Projection...
Green light flashing
this means the DM board is not booting up. You will typically need 4-8 capacitors to fix this issue. you have to pull out the board and solder in new parts. let me know if you feel skilled enough to do this and I can give directions. The caps will usually bulge at the tops and are 1000uf .. mitsubishi recommends replacing with 680uf 16v caps..
Jan 02, 2009 | Mitsubishi WS-65513 65" Rear Projection...
Green light will not stop blinking
often the capacitors will show no visible sign of swelling. 90% of the time the blinking light symptom is caused by those capacitors
May 12, 2008 | Mitsubishi WS-65511 65" Rear Projection...
Flashing light
The blogs on this subject are enormously helpful but you gotta be persistant to solve this TV problem because the fix may not be just the caps. I have a WS 65813, left the house for 3 months, came back to a blinking green light. Read Fixya and others and determined the fix is the caps on the DM board. Went to Radio Shack, got the caps, replaced them, plugged the TV in and now no light what so ever. In and out with the DM board 5 times before I called a local repair guy who told me to bring in the light box (chassis)..he said "I must have really done it.", meaning I'm way over my head and that's what I get for reading Fixya blogs and others. I swallowed my ego and decided to give him the light box chassis and $400 estimated. To take out the light box you have to remove the front panels. When I removed the glossy panel I noticed the cable connector to the power switch had separated, no doubt from the stress of sliding in and out the chassis to access the DM board (there is not much spare length in the cable feeding to the front panel). I reconnected it and voila! at least back to the blinking light..although still not fixed even with new caps. I read more blogs and saw there are three 4A SMT fuses on the underside of the DM PWB that someone suggested to look at. Got out the VOM, and there it was a bad fuse as open as the back side of my Mitsubishi. To see if it was the culprit and not having a replacement I soldered a small strand of wire across it, re installed the DM board now the 6th time and MADE SURE all connectors are back in place VOILA and it is fixed (temporarily) Super Bowl eve. I plan to get the right fuse and replace my temp fix. Lesson learned, you can mess things up trying to fix things so stay patient if you are a DIY're... you have to trial and error more since you are not the expert and are fixing things once. But it feels real nice saving $1,000. Now on to my charger on the boat.
Nov 02, 2007 | Mitsubishi WS-65813 65" Rear Projection...
Flashing Green Light on Front of 73" Projection TV
on the signal board replace the caps by the 5/9 volt regulators. c2p04 is the main culprit. 6 caps in total can be changed. I believe c2p05 also.
Oct 12, 2007 | Mitsubishi VS-50707 50" Rear Projection...
Open Questions:
See all Mitsubishi WS-65511 65" Rear Projection Television Questions
Mitsubishi WS-65511 65" Rear Projection Television Logo
132 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
