Scart connection of tv dvd video diagram,order. all 3 leads connected but video plays black and white when con. to no 2 of tv scart.
  • 89 Answers
Set the TV mode to auto in both TV and DVD player instead of PAL NTSC or what ever
Posted on Jul 25, 2009
How to connect Sky digibox & DVD recorder to Samsung UE46ES6300 TV
Buy 2 hdmi leads and use one to connect sky TV decoder to the hdmi 1 socket on the back of the TV and if your DVd recorder has an hdmi socket attach it to hdmi 2 or leave it on the scart socket
as you don't name your dvd recorder the connections available are unknown
hdmi is the best followed by component which requires a 3 cable lead 3 video (video is red green blue plugs ) audio is red and white which is a 2 wire lead which all are needed to get video and audio to your TV
scart is the lowest quality along with composite video
Jul 04, 2017 | Televison & Video
Connecting Alba DVD to Toshiba TV
If the TV has the red, white and yellow sockets on it you can use an adapter. It's a scart plug on one end (for the DVD player) and 3 little round sockets on the other, usually red, white and yellow, sometimes red, black and yellow, like this:Amazon.
Then you need an audio/video lead with red, white and yellow plugs on both ends like this:Amazon
Or one of these:Amazon
You could also use a multi socket scart adapter to add more scarts to your TV:Amazon
Jan 23, 2012 | Toshiba Televison & Video
I need to know how to hook my DVD player to ,y Samsung TV. I have it hooked up and have a picture but its in black and white.
look on the back of the television and the DVD player, there should be a SCART socket and/or red, white and yellow AV sockets, either use a SCART lead and connect it to the SCART on the DVD player and the TV.Or use an AV lead with 3 auxiliary shape connectors and match the colour of each connector with the female sockets on both the TV and the DVD player instead of using the other component connections.
Nov 29, 2011 | Hitachi Televison & Video
When I switch on my dvd even the set up page is in black and white. Originally I was getting no picture so I made sure everything was plugged in. Then I got the black and white.
Check the scart cable , try connecting it to another scart socket on the tv. I would even change the scart lead to make sure its ok. I have had loads of similar problems like that caused by scart leads faulty or connected to the wrong socket.
pete.
Nov 27, 2010 | Philips DVDR3380/05 DVD Recorder
Connecting the dvd player via a scart cable
If you select component in on the tv, this should give you a picture,using the current set up. As for audio, depending on the tv, have you used audio in on the tv, or audio out?
It sound obvious but I (even after 5 years+ of installing tv/vcr/dvd) still get caught out with input and out put.
I am unfamiliar with Sansui dvd, if it has a scart connection on the back then yes you can connect to a spare scart on the tv. If it has the single yellow phono for video and the red/white phonos for sound, you can buy a scart to phono lead and use that, not to confuse with the component(blue/green/purple) connections. You cuold also connect the yellow/red/white phono to the same on the tv front/side or rear if available.
Aug 27, 2009 | Televison & Video
Yamaha dsp-a1
you need to set the ntsf or pal settings for hdtv and s-video is video1 video 2 or video 3 seting on input on remote
May 13, 2008 | Yamaha DSP-A1 Receiver
Hooking up DVR to TV
harleynut, you should see AV1, AV2 on your TV where the cables go. Choose one or the other. Then, Place the yellow in Video and the White in Audio L and the Red in the audio slot next to it.
Apr 14, 2008 | GPX D1816 DVD Player
Movie playing black and white
the problem sounds like its with the s video connection, try using the composite video input
Mar 27, 2008 | Sony DAV-S500 System
Can't re patch tv with set top box to watch tv
Hi.
Ok here goes.
1) Take airial lead from the wall socket in to antenna in on freeview box.
2) connect short usually black airial type lead in to antenna out socket on freeview. plug the other end of this lead in to aerial in on vcr.
3) connect the other end of this aerial type lead to airial plug on the back of tv.
4) now if you have 2 or more scart sockets on the back of tv set plug in the scarts in this order.
Freeview box scart with tv on it connect to scart 1 on tv set.
Freeview box vcr scart connect to vcr in scart socket on vcr.
Vcr scart marked tv plug scart from here to scart 2 on tv
If you have 3 scart sockets on tv you can connect dvd using scart to scart socket 3 on tv.
If Tv has only 1 scart the aerial leads will stay the same as I have stated,
Freeview must go to scart socket on tv set.
leave second scart from freeview to vcr plugged in so you can record freeview by putting vcr to line 1 or AV 1.
you will need to put tv on channel (0) & tune this channel to the video play a tape that you recognise then go to tv tuning & tune tv untill you see video playing then store this on channel (0).
DO NOT USE AUTO TUNING IT WILL PUT CHANNELS IN THE WRONG ORDER JUST USE MANUAL TUNING.
Now to view Dvd you will either need to purchase A scart switch box. Or have keep unpluging freeview scart from tv so you can plug in dvd .
If your tv has red yellow white phono sockets you can plug dvd in to these, you may need to purchase phono leads.
Hope this helps.
http://dysonmanuals.llc.nu/
Chris..
Jan 08, 2008 | Televison & Video
Watching digital tv using a Panasonic DMR-EZ47VEB
PLEASE NOTE THIS INFORMATION COVERS PROBLEMS FOR ALL DEVICES CONNECTED UP BY STUPID scart LEADS. I HOPE IT HELPS EVERYONE.
This is a common problem, the problem is caused by the fact your device is connected to the TV via a scart lead. The way it works is this: If you press the AV button on your TV remote your TV will turn over to the first scart channel. If you actively do something on the device connected via scart in this case the dvd player, (this includes things like playing a DVD or Video, or going into a menu), the device sends a signal down pin 8 of the scart lead and turns the TV over automatically to the AV channel, BUT as soon as you come out of the menu or stop the DVD/Video the signal stops and the TV will revert back to the channel it was on.
So you have 3 choices......maybe 4...
1. press the AV button on your TV remote directly.
2. Buy yourself and HDMI lead IF your TV supports it (note: you will have to select the HDMI channel on your TV remote because the auto thing is only on scart leads).
3. ONLY DO THIS IF YOU HAVE A SPARE LEAD look up a diagram of a scart lead on Google so you can find pin 8 and cut it out with a pair of wire cutters. YOU will have to still press the AV button on your TV remote to go to the channel though,
4. Connect your TV and DVD with an aerial lead and tune channel 6 on your TV into the DVD player. ps then disconnect the scart lead.
(Go for choice number one!)
Oct 14, 2007 | Panasonic DMR-EZ47V DVD Recorder/VCR
Televison & Video Logo
89 people viewed this question
Top Televison & Video Experts
Electro Med Services...
