SOURCE: Sony Handycam CCD-TRV21 8mm Analog
Hi, Based on your post/description, you would need a video capture device installed to your PC. This maybe an internal PCI card or the newer external versions via USB or FireWire such as Pinnacle, Leadtek . Most brands/models will allow you to hook the camera using RCA (yellow) connector and/or S-video (black with multiple pins). You have to use the Line-in (blue) of your PC as the audio input. In some old cameras, the audio may be mono RCA, you would need an RCA combiner (2 female to 1 male) and connect it to a stereo baby phone to RCA cable. These products come with an installer CD for the drivers and a video capture software similar to Windows MovieMaker. Hope this be of some help to you and give you an idea. Post back should you need additional information. Good luck and kind regards.
SOURCE: Canon UC1 8mm video camcorder
No solution..... but eager to know where one can get the battery packs and charger fir this camcorder (UC1) A 8 mm videotape is stuck within the camera housing and can not be ejected...No battery and charger available..
Where are those battery packs available f.i." SUNPAK RB-E77MF 6V 1700 mA ??
I would highly appreciate your advice
Thanks in advance
J.van Bochove
e-mail: [email protected]
SOURCE: Sony Digital video Camera Recorder DCR-PC6E/PC9E
hello..
did you received my message?
Clarification Request
by welcomejee, posted on Sep 01, 2008
please mention what dvd recorder you have or you want to transfer movie files on PC hard disk.
SOURCE: Need adaptor for older Sony analog camcorder - CCD-TRV70 DC 6V
You need to get a Digital to Analogue converter such as the Canopus ADVC110 A/D Converter. (circa $225). There may be cheaper alternatives. (you might also be able to use a digital camcorder that has a built in Analogue to digital converter):
Canopus 77010150100 ADVC110 Converter
The Canopus comes with a 6-pin firewire cable. Since your Dell Studio has a 4 pin Firewire (actually called iLink) you will also need a 6-pin to 4-pin cable or an adapter:
Firewire 6-PIN To 4-PIN Cable
Cables To Go - 27028 - Firewire 6-Pin Female 4-Pin Male Adapter
You hook your Sony up to the A/D converter with audio and video cables (usually supplied with your camcorder) and hook the converter to you Dell with a firewire cable. Then you capture the video using some video capture software. I don't know what comes with windows these days.
SOURCE: CASSETTE ADAPTOR VW-TCA7E tab won't retract
I had a similiar problem, or so I thought, but my son has just found that it needs a battery, which I did not even know, so maybe yours just needs a new battery? the cover is near the tab, hope this helps
