Question about Kenmore 12102
I have a 12 sticher Kenmore maching that won't lay down the stiches? Everything is threaded but the thread won't go into the fabric
    Problem Solver:
  • 16 Answers
Check the needle, make sure it is not in backwards. Groove in the needle to the front. If you are sewing on a knit you may need a ball point needle/needle for knits.
Posted on Aug 02, 2009
When sewing a straight stich The bottom thread is loose.
Your upper and lower thread tensions are out of balance. The upper thread tension is too high or your lower thread tension is too low. Make sure your bobbin thread is correctly routed under the tension spring. There is a small screw on the bobbin case that always you to adjust tension.
Feb 20, 2017 | Sewing Machines
Hi. I just bought this machine and I am having trouble with my bottom stiches. I have tried every remedie but the stiches is too loose
Read this hope it helps
http://www.threadsmagazine.com/item/4302/understanding-thread-tension/page/all
May 19, 2016 | Sewing Machines
Stitching tension
hi,
different fabrics and layers has diferent set up on threading. try cotton fabrics w/ thread tension of #3 to #4 and stich # 8 to #12.if you change fabric and layers gradual setting on dial tension should be done until you acquired the good set up.have a nice day.regards
May 29, 2009 | Singer 8280 Mechanical Sewing Machine
Can't pull thread from spool
The sequence of setting up of thread from spool to needle is not complied to actual setting is one factor to be consider it affect the sequence timing of sewing.Particularly some machine are common in starting up threading.fig. shown a basic flow of thread on red color.It maybe a helpful oneb1934dc.jpg
In addition to this the set up of thread to bobbins winder is also need in right place the thread should be in clockwise rotation when coming out to bobbins casing as shown in fig.76e4431.jpg as you can see when thread was pulled out from bobbins winder is moving counter clockwise.If you try to sew, try cotton fabric and set dial to # 3 to 4 and stitch set range to 8 up to 12 depend on layers and thickness,After setting try to sew manually ,turn hand wheel by your hand first,let upper tension catch the lower bobbins tension and arranged thread and insert fabric use hand turning hand wheel several time until stich appear on fabric observed loop thread on lower bobbins on fabric.if accumulation of loop thread on lower adjust upper tension also dial tension gradually until it has a smooth stich appear.
Mar 15, 2009 | White Sewing Mighty Mender WW100...
Threading directions
  1. you can follow this figure,f0b2e9d.jpg also check your bobbins winder direction on fig.744147a.jpgit is important to acquired the right direction of the thread to avoid accumulation loop of thread in lower bobbins shuttle.There different set up of thread in different fabrics and how many layers.If you are on production process make records on different set up against different fabrics so you will not lost.On cotton yoou can start set up of tension dial to # 3 and set up stich range to 8 to 12 make sample manually run by your hand in sewing sample if you locate the exact set up run the machine pressing foot pedal.
Mar 14, 2009 | Kenmore Sewing Machines
Thread loops
Proper set of bobbins and tension set up vs. fabrics will sew you satified.Also incude regular maintenance cleaning of the feeds dogs with a brus,also the shuttle assembly need sometime to clean.Some threads and fabrics chips accumulates in the feed dogs and shuttles assembly.In setting up thread bobbins the thread should be clockwise direction as you pull out on slot coming out to the bobbins (as you shown in my inserted image manual).The loop thread should be propely in the sequence position same like in the image refer to it.If you use cotton/ polyester fabric in the begining of trial set tension dial to No.3 and stich to No. 8 to 12 any convenient to you Use needle No. 14 .Posible make a record if you are sewing different types of fabric mostly silk fabric is hard to sew adjusting to lower stich can posible sew satisfactory.
Mar 10, 2009 | Consew 206RB
Kenmore sewing machine older model 1345381
hi! there wind thread on bobbins winder 4 times by your hand rotate clockwise,insert in shaft bobiins winder on top of your machine near hand wheel push latch to engage loop thread on disc winder tension start your machine on pedal foot automatically winder disengage if already filled up of thead pull this winder and insert to bobbins casing insert thread to slot and pull out winder 6411c87.jpgshould rotate clockwise as shown.insert on shuttle hook casing and close cover needle plate.next thread your upper
97b52e8.jpgthreading tension as shown on red threading from spool pull threading and loop to dial tension threading and insert thread to lever needle and to needle hole tip. pull tread under the needle foot and feeder tooth.rotate hand wheel counter clockwise to hook up thread bobbibs and appear at top of needle plate,teo thread shoul appear,set dial tension to # 3 and stich to # 8 range to # 12 depend on fabric and layer of fabrics and set on straight stich sewing,let needle on upper position insert fabric for trial sewiing.put down foot needle lever. manually by hand rotate for assurance needle is free to sew if obtruction on loop bobbins thread occurs adjust all tension gradually then try again until free from sewing w/o problem star sewing.
Aug 08, 2008 | Kenmore Drop-In Bobbin 505S-21BH...
Thread loops up on the bottom of my piece and then binds up the machine.
Make sure that the tread is fully between the tension disks. Hold the thread at the spool and when placing it through the tension assembly pull both ends firmly.
When you increase the tension, pull on the thread while the presser foot lift lever is down and see if it gets harder to pull. If not, the thread is not between the disks or the machine is malfunctioning and must go for repair.
Large loops on the bottom are almost always caused by little or no tension on top.
Nov 13, 2007 | White Sewing White 4400 Computerized...
Kenmore 12102 Logo
132 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
