Question about Bosch 1581AVSK Top Handle Jig Saw Kit
How do you change the blades - Bosch 1581AVSK Top Handle Jig Saw Kit
    President:
  • 1,996 Answers
You need a long shafted flat head screwdriver that fits into the hole in the handle above the blade. Then simply loosen or tighten the screw inside there, and the blade twists 90 degrees and will pull completely out. Reverse to install. Also see pg 7 of instruction manual here.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Jul 25, 2009
Ks656pe how do i change the blade? i don't have any instruction. Please
Quick-Change Blade Mechanism
Higher-end models, such as the Linefinder Orbital Jigsaw, feature a clamping lever to hold the saw blade. To change a blade, switch off the jigsaw, unplug it, and let the used blade cool down. Pull up the saw-blade locking lever and let the used blade fall out with a slight shake. Turn the jigsaw upside down. Hold the fresh blade with its teeth forward; insert the blade shank into the blade holder as deeply as it will go. Release the lever and wiggle the blade to confirm that it's snugly in place. For models with rollers, such as the Accu-Trak, nestle the blade against the rollers.
Clamp or Hex Screws
Loosen the pair of screws -- on the front of the mechanism of models such as the single-speed jigsaw -- a full turn counterclockwise with a flathead screwdriver, but do not remove them. The used blade will fall out. Insert the new blade fully into the clamp. Lightly tighten each screw alternately and then fully. On older models, you may find a single hex screw on the side of the blade. Loosen this enough to remove the blade, and then insert a new blade carefully so the teeth face forward. Retighten the screw.
Oct 03, 2017 | Saws
I have a bosch jigsaw and the blade keeps slipping out of the roller blade guide after it runs normal for a few seconds. ive reset the blade and changed it.
Hi Rebecca, I hope this helps;
BLADE INSTALLATION
Set the blade orbit selector lever to position III.
Push blade change button downward as far as
it will go and turn the top handle three turns
counterclockwise (viewed from the top of the
tool).
Insert the blade into blade plunger at a 90°
angle to the cutting direction. With a slight
upward pressure, turn the blade teeth forward
(direction of cut) and guide the back of the
blade into the groove in the center of blade
roller guide. Pull gently down on the blade to
seat the blade tabs in the plunger.
With the blade in the proper position, turn top
handle clockwise until a noticeable "Click" sound
is heard, indicating that the blade is locked in
place.
Push blade change button upward to its
original position (flush with the top of the top
handle), and the saw is ready for use.
Removing the blade is essentially the reverse
of the installation procedure, however, take
note that once the blade change button is
loosened, gently push the blade upward to
release the blade tabs from the plunger.
Feb 13, 2017 | Bosch Saws
How to change stanley 99E blade
Hello, Go to this youtube website too see video on changing the blade.
Jan 01, 2014 | Stanley Bostitch 10150 Straight Handle...
How to open stanley fatmax knife 10-778 TO CHANGE THE BLADE. thank you
How do I change the blade on the quick change/instant change knife? Warning: Blades are sharp and can cause serious injury. Be extremely careful when handling blades. Wear eye protection and dispose of used blades properly, such as wrapping in duct tape.
FULLY EXTEND THE BLADE.
Press down and forward again on the slide button until the button is in the full front of the top slot (0 through 3 in the below picture).
Note- the blade must be extended beyond the 3rd detent position. This will cause the slide button to remain in a down position, allowing the blade release button to operate.
PRESS AND HOLD THE BLADE RELEASE BUTTON ON THE FRONT SIDE OF THE KNIFE. (Step 4 in the below picture)
Note- if the blade is not fully extended beyond position 3) , the blade release button will not work.
Remove the old blade carefully.
Insert new blade.
NOW, RELEASE THE BLADE RELEASE BUTTON.
ENSURE THE BLADE IS LOCKED IN PLACE. If the blade does not retract, try carefully giving a slight tug on the blade to reseat.
Jul 13, 2011 | Stanley Fatmax Xtreme Retractable Utility...
Sabre saw- craftsman - 17256 - change blades
This saw uses a tool-free blade change. 1. Unplug the jigsaw 2. Place your finger on the lower edge of the see through blade guard, and pull it forward until it locks up in place 3. Lift the tool-free blade change holder (bright yellow piece above the blade), and insert the blade into the slot of the tool-free blade change holder. 4. Release the tool-free blade change holder to lock the blade in place. 5. Pull down on the blade to verify that the blade is securely locked in place. The teeth of the blade should be pointing forward and down. 5. Put the blade guard back down.
You can use with both 'T' & 'U' shanked blades.
Feel free to ask me any other questions about this saw.
Jan 06, 2011 | Craftsman Evolv 45 amp Jig Saw 17434
How do I change the saw blade on my 2 hp 7 1/4 saw?
If the saw doesn't have a locking mechanism for changing the blade then you will have to jam a piece of wood in the teeth of the blade so that it cannot turn. Remember safety first. Ensure the saw is unplugged and wear leather gloves when changing the blade. Use a socket or wrench to loosen the nut that holds the blade on and remove the blade. Use the reverse procedure to tighten the blade.
Oct 02, 2010 | Sears Craftsman 7-1/4 in. Circular Saw...
Changing wiper blades with a cover over blades
the cover comes with certain blades. it's there to help ice & snow from freezing to it. You can't take it off and change it. If you have trouble removing the blades, most parts stores change them free (if you buy them there)
May 04, 2009 | 2008 Toyota Camry
Can the blade height be adjusted on the flymo 300 compact?
the blade shape can not be changed they are heat treated and if bent they will break, the only way to change the blade height is by changing the blade adapter.
Apr 05, 2009 | Garden
How to change blade
remove the blade guard, should be a big nut holding on blade remove that nut install new blade, make sure the rotation arrow on your new blade is going same direction as old blade reinstall the big nut and washer , put guard back on you should be set! good luck
Mar 24, 2009 | Dewalt D24000S Wet Saw With Stand
HOW TO CHANGE BLADES ON CONAIR HCT 426 HAIR TRIMMER
digram on how to replace my blade in my hair trimmer conair hc3180v
Feb 01, 2009 | Conair HCT-426 Hair Trimmer
Bosch 1581AVSK Top Handle Jig Saw Kit Logo
248 people viewed this question
Top Bosch Saws Experts
Tim Venetis
Craig Butler
Craig Butler
Are you a Bosch Saw Expert? Answer questions, earn points and help others
