SOURCE: 21.6 VOLT RECHARGEABLE POWER PACK WON'T HOLD A CHARGE
There is nothing to do but replace it, they do wear out.
SOURCE: 12 volt rechargeable battery
Walmart has them> I would definately buy from them because if you get it home and then find out that you have other problems than a new battery, you can always take it back.
SOURCE: I have a Sport Spot Vec189POB Power Series. I
In March, 2006, Black & Decker purchased Vector Products, Inc.
Since the acquisition, Black & Decker has assumed the manufacturing
of all Vector products. For customer service and warranty information
for Vector products, please contact Black & Decker Customer Service.
http://www.blackanddecker.com/CustomerCenter/Default.aspx
SOURCE: can you replace a Peg Perego Four Wheeler 12 Volt
yes!!!! you should use SEALED lead acid batteries, not golf cart or boat batteries due to risk of build up of gases inside the little chambers and possible explosion or acid burns. batteries from computer back up units are great and you can find pretty good deals on ebay for those. keep the connectors off the old battery and use it on the new one. the one possible downside is the bigger battery might not fit in the regular spot, but you can modify the space usually with a few strategic cutouts. good luck!
SOURCE: Can I use a 12 volt DC power supply with the Meade
Yes you can just make sure that the power cord has the CORRECT pin polarity- you can order the 12 volt cigarette lighter style cord from Meade.
http://www.meade.com/support/index.html
