Question about Kodak EASYSHARE 5100 All-In-One Printer
When printing out photos they come with excess ink on them
The ink runs together and very distorted
  • Steven Ford May 11, 2010
    Are you using the recommended ink? Have you tried cleaning the print heads?
  • 295 Answers
Update the kodak aio home center software on ur computer. open printer accesss door and take out both ink cartridges and then remove printhead. go to www.kodak.com/go/printheadsupport on how to take out and install printhead again. install both ink cartridges . open home center,click on ? @ top right hans side .after clicking on question mark choose maintenance and then choose clean printhead. issue will be resolved. contact kodak@ 1800 421 6699 if u have same problem
Posted on Jul 27, 2009
How do i need to purge the ink lines on an epson 3880
Purging Procedure - If you have just installed a new archival or Quadtone cartridge you must purge the Epson print head of all of the old, non-archival, ink before you can begin to print with the full archival effect. The print heads in the Epson 200/400/440/500/600/640/740/800/850/860/900/1160/1520/Photo/Photo 700/Photo EX/Photo 750/Photo 1200 printers hold about 3 to 5 pages worth of ink. Always run a Nozzle check before printing. Even if you get a perfect nozzle check on your first try after putting in a new cartridge, run at least one or two head cleaning cycles. This will prevent any excess ink from over filling the print head. After the cleaning cycles, use the purging test patterns below to purge your system of the old ink. After printing about 5 (8.5x11) pages of this pattern, 98% of the old ink will be gone. The rest will come out slowly and may take as many as 20 or more pages, but at the 98% point you will see good results. If you have an Epson 3000, 5000 or 9000. See below
Sep 11, 2015 | Epson Stylus Pro 3880 InkJet Plotter...
Not printing in black one line prints and the second line is distorted
If your printer not printing black then the following may work: remove all the ink supplies. Remove the printhead and soak it for about 5 minutes in 0.5" of very hot water. Gently blot the printhead on a soft damp paper towel to remove the excess water, then replace in the printer and then reinstall the ink supplies.
May 04, 2011 | Epson WorkForce 310 All-In-One InkJet...
When I print a glossy photo print, right at the end the printer makes a noise as if its labouring and there are excess ink smudges on the corners of the print. It only happens when printing glossy paper.
i think the problem is with your print head. i have the same problem before. when i put out the print head to check. there's a lot of excess ink. this may be the reason for the ink smudges on the corners of your print. and when you set your printer to photo printing. it is programmed to put larger amount of ink than normal printing. the best way is to have your printer checked by your service center or change your printhead to a new one. goodluck!
Apr 19, 2011 | Canon PIXMA MP210 Photo All-In-One Printer
My mx860 is printing fine for every ink cartridge except the big black one. it hardly prints the black ink at all - sometimes i just get a black page. this is recent - after a month of not using it. i...
Hold a piece of tissue under the ink jets and see if the tissue draws ink out of the cartridge. If not the cartridge is blocked or empty. If ink does come out there may be a faulty contact on the cartridge or printer. Try swap out the cartridge with a known working one and see if that works.
Jan 26, 2011 | Canon PIXMA MX860 OFFICE AIO-2.5IN LCD...
Printer always uses large black & runs out, cant isolate other
The BK5 is for black text only. The other black ink is used for shades of black/gray together with the three basic colors in printing color photos. You cannot use it to print black text.
Jul 29, 2009 | Canon PIXMA iP4200 InkJet Photo Printer
I have a Xerox Phaser 8400 with image problems. After power up it prints a Startup Page - That page is black text which faded and slightly distorted in some areas and in areas that are in Color only...
What you are describing is a bad print head. You can try running the eliminate light stripes several times, and jet substitution, but most likely the print head will have to be replaced to remedy your problem.
You can try googling. Phaser printer print heads or phaser printheads.
There seems to be a secondary market appearing for those print heads. I can tell you from Xerox, if you have no maintenance agreement, they cost $750 per print head.
Honestly, having worked on about every type of color printer known to man, the new solid ink phaser printers, produce a dry ink image of 2400 x 2400 dpi with ink particles that align end to end. The resolution of those printers are remarkable and can be purchased for less than the price of one of those new print heads.
Now for reliable, albeit somewhat not as sharp a color image, but still exceptional, you really can not beat an HP.
The ink stick technology really no longer has the color vividness advantage it initially had. The inks that align end to end, have ended that advantage and are sure a lot cheaper to operate per page.
Feb 27, 2009 | Xerox Phaser 8400 Laser Printer
My HP Photosmart suddenly started blobbing out ink.
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 06, 2009 | HP Photosmart D7260 Printer
Pictures printed from computer are pale and faded
Are you using photo paper to print your pictures? If you print your photos on regular paper the ink on the photos can bleed or run together in the paper fibers. Try using paper made to print photos and see if that helps
Dec 05, 2008 | Office Equipment & Supplies
I have a Kodak easyshare all in one printer 5100
You need to clean the printhead of the printer to solve that
issue. Because everytime you print, excessive inks are going
to the printhead that's the reason why it's clogging the
system up. That's because Kodak printers is using
"pigments" as inks that's why Kodak printers are producing
high quality prints unlike other printers - a photo printed from
kodak could actually last for about 100 years. Now back to
your issue, you need to clean the printhead from the printer
but not manually. You could clean it by going to the
software of the printer namely the KODAK HOME
CENTER SOFTWARE. You need to click the "?" mark
icon on the upper right corner of the software window then
under the General Links select Maintenance then choose
Clean Printhead. Do it at least twice and then try making
prints. If that still doesn't work try calling Kodak Technical
Support Representative: 1-800-421-6699
I hope I have been some of help. ^_^
Nov 10, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Kodak EASYSHARE 5100 All-In-One Printer Logo
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
