Hello Becky,
I have attached a wiring diagram picture. If you find it is not exact, then you can download service manuals directly from Clarion by clicking here:
https://clarion.com/xe/en/user-support/inquiry/contactus
SOURCE: clarion radio wiring diagram
please help what wire goes where?? need a wiring diagram or manuel to install. clarion xmd1 marine am fm cd player
SOURCE: WIRING DIAGRAM
red is ignition power, or power when you turn the key on. yellow is all time power. yellow keeps power all the time, this keeps your presets and clock settings saved. black is ground. once you have then hooked up you will be able to figure out your speaker wires by trail and error, they my be green/green black, purple/purple black, white/white black, ect, but these are your speakers. Once you get the power on it should be no problem to figure out the speaker wires.
i have the same stero in my boat made 2004 it is easy red(hot) black (Ground) Orange (Illumination) (hot) the 2 fused yellow is bat direct (memory) blue w/white stripe (remote) solid blue (power attenna) the 2 white wires ft left speaker, 2 gray rt front, green left rear, purple rt rear, the single brown is for the changer i believe
SOURCE: clarion db165, need a wiring diagram
i have a clarin db165, and i need a wiring diagram or color sheet.... please! i've looked a;; over the internet with no luck.
SOURCE: I need to know the wiring diagram for a Clarion
RED 12 VOLTS SWITCHED
YELLOW UNSWITCHED 12 VOLTS
BLACK GROUND
BLUE REMOTE OUT
WHITE,GRAY,GREEN AND VIOLET PAIRS : SPEAKERS
Testimonial: "Great information. A very quick response with the correct information. Thank You"
