Question about HP Computers & Internet
Monitor status - no input signal. What does this
Monitor status - no input signal. What does this mean?
My monitor is completely blank and does not respond to anything. When I turn it off and back on a quick message comes up about the monitor status and it says there is no input signal. Any advise?
The problem might be coming from your video card or try changing your RAM
Posted on Jul 25, 2009
What is monitor status no input signal mean?
It means that for the selected input (many models have multiple selectable inputs), no video signal is present. Check to be sure that the cable(s) are connected correctly and that you have the proper input source selected for the monitor.
Sep 02, 2014 | Computers & Internet
No input signal on monitor-not connected to tv-computer works fine except for the no input signal
no input or signal means that the monitor is not receiving any signal from the CPU and if the power light is amber then and the cpu works fine then there could be a problem with the cable connecting the CPU and the monitor ...check the cable.
Mar 03, 2014 | Dell Computers & Internet
I have a Dell 1704 FPVt monitor I use it in conjunction with an touch board with a monitor split cable. when I plug the team board in the dell monitor goes blank. It doesn't do this with the old m
Isolate the problem per above. Eliminate the monitor, split cable and software settings so that each, individually work. Then eliminate team board - do you have a spare?
It could mean sharing the monitor signal means weakens it so that one can display and the other does not work. Prove it with a different source computer. Don't know if buffer devices exist or how to increase input sensitivity.
Mar 07, 2013 | Dell 1704FPVs 17" TFT LCD Flat Panel...
My computer comes on and a analog shows up and my screen turns blank
Is it a desktop computer? If it is, check the video cable in the back of the monitor, a blue video cable means analog input and a white video cable means it's a digital input. You may have a digital input and all you need is to press the button on the monitor that has a little monitor symbol and see if it switches input types. If you have the blue cable connected to the monitor and you still get no signal then you may have a bad video card.
Sep 03, 2011 | Computers & Internet
When turning on my monitor the Acer name appears then disappears and a box that reads "no signal" appears. Then the screen goes blank and the blue power button turns yellow.
This means that your monitor is not receiving a signal from your computer. The easiest way to fix this is to plug the monitor into the computer. I hope this helps and have a nice day!
May 03, 2011 | Acer Computers & Internet
Monitor is blank. Green power light is on steady.
Self test failed means Monitor is bad.
Check input settings, whether DVI mode is selected.
Dell Monitor has 3 year warranty by default, Contact Dell Techncial support
Jan 13, 2010 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
Monitor stays blank power light blinking
In this case if you monitor say no input or no signal it means the monitor connector cord are not connected properly to the motherboard. Or if you have a video card you need to plug your monitor connector to the video card. Because if you a video card and the monitor cord are connected to the motherboard the monitor will not be display. So check the monitor connector if it is correctly connected.
Dec 02, 2009 | Samsung Computers & Internet
Screen Goes Blank
Ive seen this on other monitors. Look for a 1 and 2. Some monitors do NOT auto detect a signal, and this one might not. Look for a way to set the monitor from Digital input to VGA input. Try that and see.
Jul 21, 2009 | Dell E173FP 17" LCD Monitor
Montitor is blank
chk ur monitor with the input cable disconnected(the one coming frm CPU to MONITOR) if ur monitor shows any thing like no input then ur monitor is ok
and it means that ur OS has crashed.
Install new OS.
Jul 08, 2008 | Computers & Internet
Computers & Internet Logo
725 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
