Back to:
Tags:
2 Way Radios
Generic problem for all 2 Way Radios
Cobra Model HH35 radio dummy batteries
posted by LDBAIRD on Nov 21, 2007
I have two of these radios without the dummy batteries. I would like to use them without purchasing the NiCad batteries. The owner manual says I will need the dummy batteries when using regular AA batteries.
MY QUESTIONS ARE:
1. WHERE CAN I PURCHASE THESE DUMMY BATTERIES???
2. CAN ANYTHING ELSE BE USED INPLACE OF THE DUMMY BATTERY,
FOR EXAMPLE,,A DEAD AA BATTERY,,A ALUNIMUM OR COPPER ROD?? I CAN BE REACHHED AT LLOYDBAIRD@LYCOS.COM
I have the same problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Dec 09, 2007
Helpful (85)
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
A dummy battery is just a piece of metal that the battery power can travel through - just use any round metal (not alumnium) that is the same size as a AA battery - copper wound be best
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Cobra Model HH35 radio dummy batteries:
I don't want to Accept this solution
Solution #2
posted on Nov 22, 2007
Thanks for Trying (70)
Neto
Rank:Wiz Wiz
Rating: 83%, 124 votes
I don´t know what they mean with "dummy batteries" what shape has the radio in the battery compartment? does any AA battery match directly? How many AA batteries can be installed?
I think they use a Case when you are using AA batteries and the Rechargable battery is a pack that has diferent shape that any number of AA bateries.
Thank You!
Solution #3
posted on Apr 28, 2008
Not Rated (0)
22yooper
Rank:Guru Guru
Rating: 86%, 505 votes
Normal AA batteries are 1.5 Volts each. The battery compartment on the HH35 holds 10 Batteries. If regular batteries are used they must be configured to a 12 Volt output. Thus the Dummy (Blank) is used to Make 8 X 1.5V=12 Volts.
If you use NiMH or Nicd which are rated at 1.2 Volts 10 X 1.2 =12 Volts.
Thank You!
Can you Help with these 2 Way Radios problems?
Ritron Jobcom Jobcom...
I am looking for a service manual for a Jobcom JMX-141D in...
Cobra MicroTalk PR 1100 WX (15 Channels)...
push the on button and nothing happens on only one of the...
Conair FRS214 (14 Channels) 2-Way Radio
Owner's Manual for Conair FRS214HT 2-way radio
Motorola Talkabout T5720 (7 Channels) 2-Way...
does anyone have the manual for this model of motorola...
ICOM Informatique Icom Radio U16, IC2GAT,...
loss of some channel numbers
Loading problems.
Repair Service
Find 2 Way Radio Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
Prescreened Contractors
Get Matched to Prescreened Home Media Professionals
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
