Question about ASUS P4P800E Deluxe (90M8LCW0G0EAY) Motherboard
Front usb hook ups
Where do I hooh up my front usb - aguy made the machine for me and left the wires inside not hooked up?
    Problem Solver:
  • 6 Answers
Check for seven pins under it it sould be marked USB 1 or USB 2 five pins in top row and four pins in bottom row
Posted on Nov 22, 2007
When I try to print. It says you must hook up printer . The printer has ben hooked up. I printed one paper just fine. the next time it said hooh up printer. I removed cable fom printer & computer...
It seems that your computer is not recognizing the printer even when it's hooked up. Make sure the cable is properly inserted into the printer and your computer. If you have another USB cable you can use, try that and see if it works.
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Frequently, issues are caused simply by a break in the signal sent from PC to printer or vice versa. Unplugging and re-plugging the printer allows the small amount of on-board memory on the printer to be cleared, with the result that the PC recognizes the machine properly. Programs continuing to run in the background of the operating system (OS) can cause the signal to be lost. Rebooting the PC ends all programs that may be running and makes a 'clean' start, allowing the signal to be detected.
Jun 15, 2011 | Lexmark X5150 All-In-One InkJet Printer
Clarion 9700RT (1990) car stereo. Color wiring codes for these wires: White, White w/black strip, grey, 2 green, 2 lavender the stereo is hooked up but just need to hook up wires!
Memory / Constant 12V(+) Yellow Switch / Accessory Red Ground Black Illumination Orange/White Antenna Remote Blue Amp Remote Blue/White Left Front (+) White Left Front (-) White/Black Right Front (+) Grey Right Front (-) Grey/Black Left Rear (+) Green Left Rear (-) Green/Black Right Rear (+) Violet Right Rear (-) Violet/Black
These are the common colors for the radio.
Thanks
-david
Nov 10, 2010 | Car Audio & Video
Hook up for the audio on the front panel
When you are looking at the motherboard with the CPU and memory slots on the right, the audio hookup is up on the edge of the motherboard on the left. It's the last set of pins in the upper left side of the motherboard. If you have an audio jack in the front of the machine, you should have an audio cable just hanging there somewhere that is not hooked up. Hook it to the audio connector that I described.
Jun 10, 2010 | Biostar K8M800 Micro AM2 VIA K8M800 uATX...
My boyfriend hooked up my speakers in my car to my cdx-gt200, now my cd player wont even come on. He never touched any of the connection wires for the player. At first he could not find the remote turn on...
change the fuse behind the system.
"so he hooked it up to the left front speaker wire, then found the remote turn on wire and hooked it up to it." will have burned the sound system or not. remove the new installation, test it, reinstall, test again.
Jun 01, 2010 | Sony XPLOD CDX-GT200 CD Player
Will a amp work with this deck
you can get a amp to work on any deck although u may have to rig it a little bit all u need is sound coming from the stereo and if u will take the rca one end and cut it and strip it u have a wire inside each one and then u have ground wires surrounding the inside wire twirl them up like 1 wire and then strip back the inside wire hook that one to front left pos wire and hook ground wire to front laft neg and do the other rca wire the same just hook it uo to front right or if it has rca jacks on the back of the stereo just hook ur rca wires into them and to the amp
Feb 24, 2010 | Pioneer DEH-1600 CD Player
How do open the hood on a 1988 chrysler lebaron convertible?
When you pull the lever to pup up the hood in the driver seat beneathe the dashbord then go infront of your car the then pulled it up then there will be a stopper and there is a hooh just push the hook beneathe the hood while pushing it pull up the hood so that you can open the hood.
Jun 10, 2009 | 1988 Chrysler LeBaron
What wire do i hook the remote wire to coming from the amp?
Hello cjfatback,
You want the blue/white wire.
Here's what the manual shows:
Red - Power (to ACC in vehicle)
Black - Ground
Yellow - 12V positive (battery lead)
Blue/White - External Amplifier Control Lead
White - Left Front Spkr +
White/Black - Left Front Spkr -
Gray - Right Front Spkr +
Gray/Black - Right Front Spkr -
Green - Left Rear Spkr +
Green/Black - Left Rear Spkr -
Violet - Right Rear Spkr +
Violet/Black - Right Rear Spkr -
The red and white RCA pigtail leads is for AUX input
Left set of Preamp Outputs - Rear Channels
Right set of Preamp Outputs - Front Channels
Only Models C3433U, C3304U, and C3333U have a 2nd set of RCA pigtail leads for subwoofer output.
Hope this helps.
Apr 14, 2009 | Car Audio & Video
Hooking up USB adaptor to internal hard drive on desktop
clsoe the cover.
look outside of the box. look at the rear of the machine. there should be 2 USB slots. there is none in the front of the machine.
The USB driver may not be correct, since it is PIII machine. go to HP.com and download the USB driver for the machine.
Mar 04, 2009 | Compaq Presario 5000 PC Desktop
ASUS P4P800E Deluxe (90M8LCW0G0EAY) Motherboard Logo
70 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
