SOURCE: 2000 jeep grand cherokee limited starts in 3rd gear
oil pressure problem should be checked independently of other problems...Use a good accurate mechanical gauge to check. If pressure is good (no less than 15psi at idle hot (I prefer to see at least 20) check dash grounding, block ground and if OK, change sending unit. Dash and body ground can influence operation of shift and body control modules so indirectly your problem may or may not be related, depending upon what you find while testing. And it could turn out to be a defective module! They are expensive and just plugging new ones in may work, but then again, it might not. I might be totally incorrect on this...that's the value of actually being there instead of doing this by "remote control".
If you read the numerous posts pertaining to all vehicles, you will see that you are not alone with electrical problems...As long as the engineers who design this stuff, keep using "modules" to replace ordinary simple and reliable systems, we will continue to have these problems. Do some testing and I'm sure you will find a solution! (I'm still waiting for someone to make a program for a PC that will give a complete readout of every system in a vehicle, including exact faults instead of general system "suggestions")
Good luck
SOURCE: wont stay runing
try pulling the plug out on the idle air control valve then start it if thats not it try the map then the idle control
SOURCE: jeep grand cherokee slow to start
THE THINGS YOU MENTIONED WON'T AFFECT CRANK SPEED. YOU'RE BATTERY IS PROBABLY ON THE WAY OUT THE DOOR. LOOK FOR CORROSION AND LEAKING BATTERYLIKE AROUND TERMINALS AND POSTS. BATTERY IS PROBABLY LOW ON CCA'S. NOW IF TALKING ABOUT WON'T START AND TAKES LONG CRANK TIMES IT CAN BE FUEL PUMP LOSING PRESSURE IN FUEL RAIL OR LACK OF FUEL PRESSURE CONSIDERING WHAT YOU MENTIONED. EVAP SOLENOID WILL USUALY SET A CHECK ENGINE LIGHT AND WONT AFFECT STARTING USUALLY UNLESS YOU HAVE A HUGE VACUUM LEAK
SOURCE: Very rough idle on 2002 Jeep Grand Cherokee Limited Edition V8
If you haven't changed the plugs or had the fuel system cleaned, now would be a good time to do it. The number 1 culprit for rough idles is dirty injectors or plugs. You can try an injector cleaner in a can (or bottle) for under $10 and see if it helps, and then work from there. If there isn't any improvement then if you are able to, check the plugs for any gunky buildup and if you find a bad plug, make sure you replace them all (or have them replaced) at the same time.
SOURCE: 96 jeep grand cherokee starts but wont idle
CHECK FUEL REGULATOR ON FUEL INJECTOR RAIL,&ALSO FUEL PUMP, CHARLIE
Trouble Code: P0846
A/T 2/4 Pressure Switch Circuit Malfunction
Possible Causes:
2/4 pressure is incorrect, or internal transmission faults exist
2/4 pressure switch circuit is open, shorted to ground or power
2/4 pressure switch is damaged or it has failed
TCM relay power circuit to L/R switch is open (loss of B+)
PCM/TCM has failed
