I think maybe the third gear is slipping
When im in third gear it seems like the gear is slipping but i really dont no if thats wut is it cuz it could be my programer...do u have any ideas??
  • 86 Answers
New clutch
Posted on Jul 27, 2009
Well, just trying to fix my ION Tailgater. Ive check the fuse but it seems to be fine. I think the battery is ok since never had problem with it,in the inside every cable is connected fine and nothing...
Check the fuse with a continuity meter. Changing to 110 from 240 doubles the current thru the transformer. The rectifier diodes in the power supply may be burned to create an open which will cause it to not operate. Look inside on the circuit board for a fuse for the DC section.
Feb 08, 2018 | The Computers & Internet
Transmission slipping in third gear
There is a point that a machine works and a point that it stops, you need a transmission rebuild.
Aug 30, 2017 | 1993 Mitsubishi Galant
My Schwinn doesnt gain speed
axel bearing either is bad or needs grease or not adjusted correctly
Oct 08, 2012 | Schwinn 700c Mens DSB Dual Sport Bike
Who do i change the oil on my crf 450?
personally i like to change the oil on my crf450 every 3-4 rides and if im riding it hard or cleaning the engine out, i do it every ride. The gear oil i do about every 6-7 rides unless im riding it hard then i do it less. Everybody will have there own opinion on how and when you should do it.. Some do it after every ride but i think thats a little obsessive. I like to use amsoil 10w-40 for the engine oil but i think any synthetic will do. I used to use the normal honda oil but i switched to synthetic and it cleaned it out a lot and ran better to be. I use a semi synthetic on gear oil and dont find anything wrong with it. im not an expert at this at all and maybe im doing this all wrong but whatever it runs fine and works fine for me.. as long and you make sure the oil is clean, air filter is clean, and keep the right amount of oil in it it will be fine. But i would highly recommend using a synthetic oil for the engine and probly a semi synthetic for the gear oil to reduce the clutch slipping. * also mobil 1 makes a pretty good 10w 40 as well but amsoil is 2 bucks more so i just do that. You can change the oil yourself or have someone else do it its really really easy. Also make sure you change the oil filter every time you change the oil to.
Aug 03, 2010 | 2005 Honda CRF 450 R
Problems selecting 3rd
shift fork problem im thinking. But we dont want to go there, change to a synthetic oil 20w50 and if your already using that type then do an oil change to see if that wont help it a bit. I've noticed that everytime i change my oil the shifting gets a "little" easier. I used to have problems of mine popping out of second a lot.. when it does that, i change the oil and make firm positive shifts to make sure i dont cause any further damage, and to work/wear the gears together again so the wont slip.After your oil change see if you can skip third and go into fouth then step it back down into third, try this over and over again. Then from a stop try to see if you can normally go into third gear if you cant... well you probably know what that means. let me know if this was helpful thanks.
Apr 10, 2010 | 2003 Honda CBR 600 RR
Rear end humming noise
check the play in the pinion gear bearing on the rear end i think! you will find the yoke ie lose and also the bearing has excessive play and needs ro be changed
Jan 22, 2010 | 2000 Chevrolet Blazer
Mercedes benz 260E gear slipping
Try changing the fluid in the transmission first this may solve it, if you are not sure when it was changed.
Jul 18, 2009 | 1987 Mercedes-Benz 300-Class
2001 Hyundai Accent high rpms on highway
you need to make sure your trans is shifting to high gear. if not thats why your rpm's are to high.
Jun 11, 2009 | 2001 Hyundai Accent
Tranny, fuel, or relay/electrical on 94 Z28?????
sound like problems in the ignition system .check wires spark plugs and coils.clean injectors
Apr 09, 2009 | 1994 Chevrolet Camaro
Need a driver 4 belkin_f8e207_keyboard
This keyboard is really out of date and belkin has stopped publishing the drivers on their website.
Driverguide.com have the original Win95, Win98 drivers though, but it will not work in Windows XP...
Instead you can use third party software like the free keytweak
Jan 06, 2008 | Belkin (F8E207) Keyboard
Computers & Internet Logo
43 people viewed this question
David Payne
David Payne
