Question about M&S Systems BV-2000 Bagged Canister Vacuum
Where can I find a part for my BV2000 in house vac? It is the smallest unit made by M S & S Systems in Dallas TX. The suction impeller is grinding in it's housing, so I need a motor/suction pump. I have removed this combination from inside the vac assembly
  • 58 Answers
You will have to replace the whole motor as these motors where never made to be serviceable. if you take the motor to a local vacuum shop than can order you a new one. though i would recomend replacing the whole tank unit with a Nutone or Hayden they are far better systems.
Posted on Jul 26, 2009
No suction
Sucked up a sock?? No seriously.. it may be as simple as that or that an on board filter is clogged. Check your manual for all filters and Hepa/screens and others. Also, is the unit making any odd noises since the non -suction scenario? Whining or screeching sounds, where is the motor impeller/vac bearing or similar is damaged or a hose is kinked within hte unit itself.. <not normally unless the unit has been taken apart and placed back together and crushed the main return vac hose. .
Apr 30, 2010 | Dyson DC14 All floors Bagless Upright...
Lack of suction at power unit
Check that the Handle has a slider to adjust air flow, Electrolux Vac's arent really designed for carpet cleaning, check hose for breaks or cuts and everything is secure, while its on run your hands all over the hose and vac to locate any air flow that should not be.
Let me know.
Nov 15, 2007 | Electrolux Centralux Vacuum
Poor suction (new bag, clean filter, clear hose)
check the impeller on the moter it may be missing a fin or two (question does it make any unusual noise or vibration ?)
May 01, 2009 | Vacuums
Brushes not rotating on my Hoover Steam Vac Dual
The brushes are all connected to a single shaft. This square shaft is connected to 2 sets of gears and then another shaft which is turned by an impeller (suction from the vaccum pump is used to turn the impell and thus the brushes). There are 2 bearings that the impeller shaft turns on. It's likely these are rusted up and just need a bit of WD 40. Took me 30 min to take apart, lube, and put back together. Remember, its plastic. If things won't come apart, look for another screw. Mine was a brand new unit and the top bearing was rusted.
Sep 22, 2008 | Hoover Steam Vac Dual V w/ SpinScrub...
No suction
On some units there is a screen that protects the impeller of the motor. If this gets sealed off with debris then it is like putting a potato in the tail pipe of a car. Taking the top off the unit reveals the motor. DO UN-PLUG the unit first from the electrical outlet. Take off the exhaust piping if any to allow the motor to be lifted out of the canister. There is typically enough wire to allow this without taking any wires off. Look at the bottom of the motor to make sure the nut has not spun off the impeller and it is still attached to make suction. The look at the hole (aprox. 2" round) to make sure it is clear of any debris. If it is not clean it and re-install everything. If the impeller is off the motor it is new motor time.
Hope this helps!!
VR
Sep 09, 2008 | Electrolux Central Vacuum
Hoover steam vac
I had the same problem just before the impeller broke. Lower the handle and check the hose connection at the bottom is not broken. Turn the unit on with the handle down, then check the suction on the accessory hose, leae it disconnected. Take off the bottom container, and check the suction on the round intake tube (lower one towards the front), with the handle up and with the handle down. If the suction increases dramatically when the handle is lowered, the impeller is probably in it's self-destruct stage. (same as mine). Soon the impeller will break off, and BINGO no suction at all.
Jun 25, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Spot Bot
Their customer service # is 1-800-237-7691 and they can tell who to call for service. You can also go to bissell.com, there is a link for service centers, just put in your zip code and a list will come up.
BISSELL Service Center Locator Please enter your ZIP Code: CANTRELL SUPPLY INC. 2918 SOUTH COOPER F-2 ARLINGTON TX, 76015 (817)465-9121 11.1 miles BRANCH VACUUM & JANITORIAL SUPPLIES, L.P. 12895 JOSEY LANE #122 FARMERS BRANCH TX, 75234 (972)247-5838 15.7 miles FORT WORTH SHAVER & APPLIANCE 1900 MONTGOMERY STREET FORT WORTH TX, 76107 (817)335-9970 16.3 miles AMERICAN VACUUM CO. 5545 W. LOVERS LANE DALLAS TX, 75209 (214)357-8419 18.2 miles KIRBY CO. OF DALLAS 4118 MAPLE AVE DALLAS TX, 75219 (214)526-7951 19.0 miles BRUNER KIRBY CO., INC. 5608 MC CART AVE. FT. WORTH TX, 76133 (817)292-8421 19.4 miles VACUUM DEPOT 5359 WEDGEWOOD FT WORTH TX, 76133 (817)292-4472 19.4 miles MODERN AMERICAN MAINTENANCE 8545 CAMP BOWIE WEST FORT WORTH TX, 76116 (817)244-0919 19.9 miles ALL VAC, INC 4451 LOVERS LANE DALLAS TX, 75225 (214)521-2558 20.2 miles KIRBY CO. OF DESOTO 104 N. HAMPTON ROAD DESOTO TX, 75115 (972)223-4029 23.8 miles AAA VACUUM CLEANER CO. 9845 WALNUT HILL LANE DALLAS TX, 75238 (214)348-1620 25.0 miles BROADWAY VACUUUM 4401 BROADWAY BLVD GARLAND TX, 75043 (972)240-7971 31.1 miles THE VACUUM DOCTOR 500 NORTH GALLAWAY - STE. 10 MESQUITE TX, 75149 (972)329-1104 31.4 miles CHAMPION VACUUM, INC. 8809 LAKEVIEW PARKWAY #128 ROWLETT TX, 75088 (972)463-2755 34.3 miles VACUUM & SEWING DR. OF TERRELL 811 WEST MOORE, SUITE E TERRELL TX, 75160 (972)563-0330 49.8 miles var prm = Sys.WebForms.PageRequestManager.getInstance(); prm.add_initializeRequest(resizectl00_ctl00_cphAllContent_cphContent_pcaMain_ctl02_ctl00_pnlActivity); prm = null; function resizectl00_ctl00_cphAllContent_cphContent_pcaMain_ctl02_ctl00_pnlActivity() { var elAct = $get('ctl00_ctl00_cphAllContent_cphContent_pcaMain_ctl02_ctl00_pnlActivity'); var bounds = Sys.UI.DomElement.getBounds($get('ctl00_ctl00_cphAllContent_cphContent_pcaMain_ctl02_upServiceCenter')); elAct.style.width = bounds.width + 'px'; elAct.style.height = bounds.height + 'px'; Sys.UI.DomElement.setLocation (elAct, bounds.x, bounds.y); } Locating Stores... progressbar.gif
Feb 29, 2008 | Bissell 12005 Spot Bot Handheld Vacuum
Wet dry vac suction not woking
The wet and dry vaccuums should normally have the dust filter removed when used for wet work. If the filter was left in, it will certainly be clogged and useless. I would suggest trying the unit with no filter, just to check there is good suction. If there is, a replacement filter is required. If there is still little or no suction, then it is possible that there is a blockage within the impeller area somewhere. Wet dust/dirt tends to stick really well to the impeller blades, reducing their efficiency to point of almost no suction. I'm not sure if you can get that far into your unit, if you can, it would be worth using a stiff brush to remove and adhered debris.
Dec 17, 2007 | Vacuums
Rainbow D3C Low suction
You might check the carbon brushes on the motor, it could be that the motor is not running fast enough, which would mean replacing the motor. With the hose off, do you have good suction where the motor goes into the vac? If it is good there, then either the powerhead isn't working or the hose is clogged.
Dec 09, 2007 | Vacuums
Has no suction
I just went through the same thing.  Your fan or impeller is probably broken off the shaft and no longer on the motor shaft.  My local repair shop wants $9 for the impeller and $29 to replace it. You will have to take the thing apart and put on a new fan or impeller blade and I'm still trying to do that to my vac.  I think I will have to heat the nylon impeller with a hair dryer to get it onto the shaft and then tighten the left hand nut. My vac is held together with torx screws so add a torx screwdriver to the price if you don't have one and want to do the job yourself.
Aug 19, 2007 | Eureka Whirlwind 4383 Upright Vacuum
M&S Systems BV-2000 Bagged Canister Vacuum Logo
130 people viewed this question
Top M&S Systems Vacuums Experts
Thatvacguy.com
Electric Hospital
Electric Hospital
Are you a M&S Systems Vacuum Expert? Answer questions, earn points and help others
