Question about Kenmore Elite 45986 Front Load Washer
Kenmore Elite Washer: Around 5 yrs old. Machine washes for anywhere between 10-20 minutes and then stops, and the minutes lite starts flashing. Sometimes if you reset and start washing process again it will complete all cycles. Hit or miss. No odd noise from washer.
  • joe_abeyta Jul 25, 2009
    The solution was very helpful and timely. I received a response within 3 minutes of posting my question. Nice job.
    Where can I order part?
  • 6,784 Answers
HI, this is a typical logic sector malfunction, the CCU is damaged and, you will need to replace this vital Control unit asap. this will restore your units operational value.
The CCU(Central Control Unit), is the Main initiator of the entire wash cycle. There are several run time chips located inside the CCU's housing. these chips will become unstable overtime. This instability will cause disruptions within the wash cycle. The flashing minute light is one of many indicators that will signal issue that will concern the CCU's integrity.
Posted on Jul 25, 2009
  • Michael Masters
    Michael Masters Jul 25, 2009
    You can order by phone if you wish by Calling this number below. Simply give the representative your complete model number and the actual part you need as well(CCU) or, you can give me your model number and, i will set up a link so that you may order it on-line as well.
    1-800-366-PART (1-800-366-7278).
  • Michael Masters
    Here is the actual link below to order directly from parts direct page(Kenmore).
    CLICK HERE
Keeps Stopping and saying UE
uE error code 79631512210 Kenmore Elite Washer - Sears ...
www.searspartsdirect.com > Ask an Expert
Jan 10, 2014 - uE error code 79631512210 Kenmore Elite Washer ' SearsPartsDirect. ... After unloading the washer completely, the machine attempts to rebalance the .... to ensure proper fit and to keep appliances running for years to come.
UE Error code on my front loading Kenmore washing machine
www.shopyourway.com > Manage My Life > Questions
Jun 13, 2011 - I have a Kenmore 3.5 cu. ft. front loading washing machine (model #4027) and it is 1 year old. ... what does the F35 error code on my kenmore elite front loading washing machine mean? F13 code on Kenmore Elite HE3 front loadingwashing machine.
Jan 21, 2016 | Kenmore Washing Machines
Kenmore elite washer
hi
unfortunately the programmer is faulty
Dec 31, 2017 | Kenmore Washing Machines
Stop frequently on spin and rinse cycle F6 code
I have a Kenmore Elite he4t front load washer that was working fine and then we moved and now it stops washing midstream and flashes an F and a H. I have to pause and restart then it will stop washing again after a few minutes and flash the same codes again. I reset again and then it stops with 1 minute left and will not drain.
Apr 06, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite front load washer stops and blinks F35 and locks up
f35 code indicates a pressure switch problem. Try unplugging unit for 2 minutes.Plug back in and test.If F35 reappears,check hose from tub to pressure switch
Nov 04, 2009 | Kenmore Elite 45986 Front Load Washer
Washer full and then stops and gives a beep while flashing F 51
On Kenmore F51 means Motor RPS Failure, the motor is not spinning or the motor sensor detects a fault.First unplug the power cord for one hour or so to check if it is a jammed sensor, and see if reset.
Dec 06, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore Elite Oasis HE/ Error Code F1
f-1 error code,, replace main contol board ,,pressure swtich is loacted inside board would not fill drain and spin once replaced there will be no more problems, if machine is 2 yrs should be covered under warranty
Nov 24, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite Washing Machine LD Fault
mpratt, check to make sure there is no restriction in your pressure switch tube.it could also be kinked.
Oct 22, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Loads interrupted
interrupted wash cycles and also give a code of F06. A service tech was supposed to be at my residence today... he did NOT show. This machine is little over a year old. Tried unplugging with no sucess. Any help would be appreciated.
Sep 15, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Oasis Elite---110-27086601
This error only shows in diagnostic mode, with power off choose any buttons except stop and power, press in intervals 5 seconds on and 5 seconds off until 88 appears and all light light up. If the user panel is faulted F 2 will flash in the display, press the same button you used to start diagnostics to jump to the next error code and once through 88 will flash and diagnostics will start. Sometimes once F2 flashes and the machine has not been repaired it will stick at that mode.
Aug 07, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Elite 45986 Front Load Washer Logo
41 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
