Question about Compaq Computers & Internet
I am getting intermittent crashes in the general category of: Kernel_Data_ Inpage_Error the specific hex code changes a bit however from crash to crash - the manufacturer of the box (MICROPRO) ignores my email requests for help. (it's always atapi.sys) the rest of the code looks like this: STOP: 0x0000007A (0x0303DDE54, 0xC000000E, 0xF7795558, 0x0C6B860) atapi.sys - ADDRRESS F7795558 Base at F7789000, Date Stamp 3d6ddb04 Begin dump... At this piont the HD access light is on solid. Any thoughts?
Well the problem is maybe due to loose cables.. try unplugging your HDD and replug it again...
2. try to boot on safe mode
3. try a clean installation
4. download a software known as Memtest to test for your memory
Posted on Jul 25, 2009
    President:
  • 2,666 Answers
Ensure you are fully up to date via microsoft update site then check for driver updates on Compaq site.
2 Suggested Answers
  • 18 Answers
SOURCE: Atapi.sys
Atapi.sys is also a popular infection target for many Trojans. You may get stop codes of 0x00000007A, 0x00000008 and especially:
0x0000000A (0x00000000,0x00000002,0x00000001,<anything>)
which requires a virus scan like AVG 8.5/9.0 to fix since the infected driver has already modified many other files in your system.. (Remove the drive and put it in another machine and then scan it.)
Posted on Oct 26, 2009
Computer clicks then shows the kernel data inpage error screen
I'm sorry to say but that sounds like a hard disk failure. Classic symptoms.
Run a diagnostics test using Seatools:
SeaTools Seagate
Mar 21, 2014 | ASUS Silver 15.6" Vivobook V550CA-DB71T...
I am using nComputing L230 Terminal but when I log in from the terminal, the windows and all related applications crash with exception code c0000005.
Uninstall your vSpace software, reboot, download and run their cleanup utility located at www.nc-eng.com/tools/ncuninstall.exe. Apply ALL MS service packs. Verify that no device drivers are missing or conflicting. Logon/logoff to the host and confirm proper functionality. Enable the Windows Startup/Recovery to capture a memory dump. This is done by the following steps: Right click on My Computer ' Properties ' Advanced Tab ' Startup and Recovery, Settings Button, Make sure Kernel Memory dump is selected. From there you can analyze the crash dump. Additionally, to help us, providing the complete hex code when the system crashes would help. Also, you never indicated what OS you're on or what version of vSapce you're using. All this is necessary to help you further.
May 18, 2011 | NComputing L230 Network Terminal
Drive Smart Read Error / Kernel Data Inpage Error/1000-0143
have you restarted the PC? If you have and it works, then this error is NOT too much to worry about... As long as the drive is Booting for now you can copy off your files etc to say a USB drive... You do not need to copy the programs etc, usually you simply copy over your "My Documents" or "Users" directories. As all files saved are generally "Under" there if you have any, anywhere else of course you need to get them as well. Now the drive may NOT be totally "Ruined" it may simply require a Re-Format, and then replace the Operating System. After which you can restore your settings. Below is a Microsoft link that tells you how.www.microsoft.com › ... › Computer Setup and Maintenance -
Either with the "Old" drive or a "New" drive. set BIOS to boot from CD/DVD and put the Windows Install DVD in the drive, boot of this and follow instructions, when you come to the place to partition & Format, do this and do a full NTFS format... after which your system will be installed and you can load your drivers and programs again Also before doing all this go to the manufacturers web site and download ALL drivers for your model PC & Operating System. You need to do this so you can install the drivers for all your Video, Sound, WiFi network etc. after you install your operating System
Mar 08, 2010 | Dell Inspiron 2200 Notebook
Acer aspire one. linux lite. crashes. sometimes
i think the vm.linuz (also known as the kernel) has got corrupted ... try a fresh install of linux lite
Dec 18, 2009 | Acer Aspire One PC Notebook
Atapi.sys
Jul 25, 2009 | Compaq Computers & Internet
C5180 All-in-One
HP doesn't list that specific error code, however www. dumpanalysis.org had a crash dump analysis listing that or a similar code. That means your printer has an internal error state. Check with the HP articles for error codes. You should try shutting it off for two minutes then rebooting to see if you can get it back online. 0xC2FF, & 0x0000C2FF are UTF 16 & 32 bit Hex codes indicating a memory overflow error (from what I could judge). If you are fortunate it will not be a permenant condition from hardware failure, otherwise your printer may need servicing.
Mar 26, 2008 | HP Photosmart C5180 All-In-One InkJet...
Kernel stack inpage error
i have recently experienced my computer is shutting down with a message kernel stack inpage error when i play a high graphics games or playing video files
is this fixable
Feb 23, 2008 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
Kernel data inpage error
It is best practice with a used computer to completely format and
clean-install Windows. In your case, this is what you definitely need to
do after performing some hardware diagnostics. Here are links that will
show you how to do a clean install and what you will need on hand:
http://michaelstevenstech.com/cleanxpinstall.html
http://www.elephantboycomputers.com/...alling_Windows
Jan 02, 2008 | Toshiba Tecra M1 PC Laptops
Computers & Internet Logo
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
