Question about Liftmaster, Chamberlain, Sears Door Bracket
My house was prewired for a garage door opener well on the wall they brought the wire through and just tied a knot in it ,now each side of the garage door it has wires for the sensors so far so good right well then in the ceiling theres a hole but first off theres no cut off ends to those wires and then to top it off there not even long enough if i were to just start cutting them in half i even tried pulling at them and nothing, problem is theres a bedroom above the garage so i cant even go into a attic space to see what these idiots did anyone have any suggestions where to start here i thought the hard part was over installing the opener to the ceiling and door thanks for any help Chip.
    Problem Solver:
  • 17 Answers
Usually the installers will make a not at the end of the wires so that the dry wallers wont dry wall over the wires (it hapens all the time with dry wallers).I would strip off bolth wires by the garage doors.Inside the wire their will be either four little wires or two little wires strip them as well.On one garage door twist two of the wires together so that the wires contact each other.On the other garage door where the other wire comes out of the wall strip the wires (if you have four wires coming out of it you will have to use a multi meter and connect the ends of the probes of the multi meter to the same two collers of wire that you twisted together on the other door.If you have only two wires coming out of it then do the same thing you just wont have to worry about which two collers you are using.I.e. I twist red and black together on one door then I connect my probes to the red and black on the other door.Using the resistance option or the tone option on the multi meter you should be able to tell if this is a single line like I think it is.If it is a single line then the meter (if on the resistance option will read anything other then o.l.).O.l. standing for open line. (If on the tone option then you will hear a tone).If this is one line then you will just have to go to the hole in the ceiling and cut the wire in half using daulfins or barell conectors and a little wire you should be able to extend you wires.(I asume on the door opener their are two different terminals to connect two different doors).DONT pull on the wires.This will only make things worse.per state law the installers have to staple their wires to the studs and pulling on these wires can lead to them breaking off in the walls or them shorting out.It is comon for a low voltage electrican to only use one wire when installing two doors close together they just forgot to leave a little extra wire in the hole in the ceiling and then cut the one wire into two sepret wires in that same hole.
Posted on Jul 28, 2009
How do i repair the pull cord on a craftsman
If the eye hole is nt broken just put a piece of rope 1-2' ft feed rope through eye .tie ina knot pull back through if u dont see an eyeloop u will have to replce the trolley
May 13, 2014 | Sears Craftsman LiftMaster Chamberlain...
Garage door works with the remote, but not the door closer in the garage
Replace button on wall. Check wiring between button and opener.
Look at product manual and see if manual has troubleshoot section.
If there is no wire between wall button and opener, the remote may be one of those 'self learning' unit and may have to be reprogrammed. And -or battery replaced.
Otherwise the wall button connects directly to circuit board on opener, and cannot be repaired without ... parts, schematic, electronic knowledge.
Replace garage door opener.
http://waterheatertimer.org/pdf/Liftmaster-garage-door-manual.pdf
Add a comment and say what you find.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Jun 11, 2013 | RTO Automatic Garage Door Closer
My house was pre wired for garage door opener Just bought a chamberlain opener wanted to know how to wire it.there are about 7 little wires coming from out of wall
You have 7 wires coming out of the wall but you don't say where they go. Only someone with the knowledge and equipment could trace these wires. If it were me I would use the wires that came with the new opener and follow the directions exactly.
Aug 25, 2010 | Sears Craftsman LiftMaster Chamberlain...
How to program chamberlain tricode tc2 to my garage door
I HAVE PREWIRED WIRES AND I'M TRYING TO CONECT MY THE WIRES TO MY GARAGE DOOR OPENER. THE PREWIRED WIRES COLORS ARE AS FOLLOWS: BROWN, GREEN, ORANGE, GREEN AND WHITE, BLUE AND WHITE, ORANGE AND WHITE, AND BROWN AND WHITE. WHICH TWO DO I CONNECT TO THE WHITE/RED AND WHICH ONE TO THE SOLID WHITE WIRE?
Feb 20, 2010 | Sears Craftsman LiftMaster Chamberlain...
Access Master Garage Door Opener opens by itself
The most common cause of this is a bad wall control or the wiring going to it. The wall control goes bad from use and the wiring sometimes has intermittent short caused by the staples the installer used.
Jul 31, 2009 | Sears Craftsman LiftMaster Chamberlain...
My unfinished house did not come with the wall opener/closer button attached. The wire is there. I got a switch but the wall has four wires (red, black, white , and another. The new mount only calls for...
Look at the rear of your opener and see what color wires are connected to terminals 1 and 2. These will be the two wires you should connect to the wall button.
Jun 30, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door opener motor will not open garage door
It sounds like you did a really good job! My Craftsman 1/2 hp gar. dr. opener has a red reset button on it on the l/h side as you are looking at the light/motor from the garage door opening. You have to take the light cover off to be able to see it. My reset button is on the same side as the ground wire. You might check the ground wire while you're there. I really hope that this fixes it for you (and me). I'm quite sure it will as you know your way around the garage door opener already. Good Luck and Let me Know (Please) if it fixed it or not. If I think of anything else, I'll let you know. Have a Good Day!
Jan 16, 2009 | Sears Craftsman LiftMaster Chamberlain...
Ceinlg fan
If your house has only a black and white wire, than you need to tie the black, balack and white striped wire to the black of the hous. You than have to use the pull chains on the fan when the switch is on, to turn the fan or the fan light on or off. If youre house had a red wire than that would be tied in with the black and white striped wire and you would have two swithes on the wall to control the fan and light instead of having to use the pull chains.
Sep 27, 2008 | Hunter 23852 Classic Original Ceiling Fan
Liftmaster, Chamberlain, Sears Door Bracket Logo
1,418 people viewed this question
Top liftmaster Home Security Experts
Lawrence Oravetz
Jean DeLauche
Jean DeLauche
Are you a liftmaster Home Security Expert? Answer questions, earn points and help others
