The washer is NOT tripping the breaker but it's powering itself off and when the breaker is flipped off and on the machine powers up properly but after a few minutes it will power itself off again automatically. Also, the interior light won't go off. No fail code is being displayed. Thanks in advance for help and direction.
SOURCE: Last night the WM2077C washer showed a LE error.It
Hello there:
this LE means this
LE
Locked motor error. Cause: The connector
(3-pin), male,white) in the motor harness is not connected to the
connector. (3-pin,female,white) of stator assembly. Or the electrical
contact between the connectors. (3-pin,male,white) in the motor harness
and 4-pin,female,white connector in the main PWB assembly is bad or
unstable. Or the motor harness between the stator assembly and main PWB
assembly is cut (open circuit) Or the hall sensor is out of
order/defective.
Testimonial: "Tech tips were very helpful. Ran out of time on my end. Would highly recommend tbirdfan1 to anyone. more later...."
SOURCE: LG front loading washer is turning itself on,then off
You have a fault microprocessor, or the "Brain" is sporadically faulting... You need to get this looked at... it isn't a minor thing unfortunately... look get a firm "Quote" from a reliable service center man
SOURCE: LG Tromm will not turn on.
I have put mine on a surge protector. It is a computer after all. It is hard to say whether or not you have suffered damage to the motherboard. Trial and error testing to see if you have power at your outlet. Hopefully you can repower and all will be well.
SOURCE: LG WM3001HPA Washer interior light is on but will not power up
Door close interlock switch is out of adjustment. Remove side panel(s) and adjust it back to a point where it recognizzzzzzzzzes it closed. Bolt eveything back to gether and you be done!
