Garden Logo
R
Richard Lee Baran Posted on May 21, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
John Deere LA140 will not start. seems to be no power to starter motor. Battery is up and headlights will come on
jamessizer
Level 3:
  • John Deere Master 7,515 Answers
  • Posted on Jun 09, 2017
jamessizer
John Deere Master
Level 3:
Answers
7515
Questions
0
Helped
691167
Points
37181
3answers
Lost all power on my John Deere D160
limited info generic answer pop can be anything check fuse and solenoid --check for spark --fuel to narrow down problem --no spark electrical problem --no gas fuel problem
1helpful
John Deere LA140 won't turn. New battery. No sound when I turn the key. No headlights, what should I do?
Check your connections at the battery. May have a bad ground or bad battery connection. Also check to make sure new battery is good by supplementing with a jump start. If new battery is good and connections are solid, you most likely have a broken wire somewhere. The lights may only work with the mower running though. I believe on my LA105 the lights only come on with the engine running and dim/brighten with the RPM of the engine.
Apr 07, 2013 • Garden
1helpful
The flywheel is only cranking slowly at start up, engine won't fire. The lead to the starter motor and the starter motor heats up, smokes a little. I have checked the battery, replaced the starter solenoid...
If your unit has OHV engine you need to check the intake and exhaust valve gap. Call your local repair shop to get numbers and check this website out. Go to smalleng.com they have a video for just what you are looking for. Good Luck...
John deere lane rider la135 wont start.
You don't mention if they are on and are bright or are week. Do they dim when trying to cranks the motor? I would start with checking the ground wire at the battery and where it connects to the frame. Make sure both are clean. From there, have the battery tested and then the starter.
May 02, 2010 • Garden
Starter
motor problem. solenoid main function to start only.
Top John Deere Garden Experts
john h
Sean Wright
Sean Wright
Jay Finke
Jay Finke
Are you a John Deere Garden Expert? Answer questions, earn points and help others
