Question about Zanussi IZ12 Front Load Washer
ARMXXD 129 HAS NO REAL PREWASH CICLE ?
A week ago I've got the brand new HOTPOINT ARISTON ARMXXD 129 washer dryer, 1200 rpm, full electronic control, LCD display.
PROBLEM- When selecting the first wash cycle possible - WHITE COTTON - 90 oC, 1200 rpm, after starting, the water takes the powder detergent from both the first and the second compartment, shortly one after the other, the LCD display says WASHING, not PREWASH, and in fact there is no REAL PREWASH CICLE - as it usually should be: prewash/evacuate/spining/ short rinse/evacuate/ spining/ washing. Everything else works fine.
The user manual Phase/ Features table shows to put powder detergent for prewashing in the first compartment, so logically there should be a REAL PREWASH phase.
Q.1 - DO I HAVE TO SELECT THE PREWASH CICLE SEPARATELY, OR THERE IS A PROGRAMMING ERROR?
Q.2 - WHERE CAN I FREELY DOWNLOAD THE ORRIGINAL ENGLISH USER MANUAL?
thanks,
mih@i
5 Suggested Answers
SOURCE: prewash always flashing
yes i had a similar problem the prewash light kept coming on mid wash cycle and eventually stopped taking in the water just bypassing it straight to outlet without filling machine. i found if you remove the pump at the rear of machine and disconnect hoses there was a build of lets say deposits leading to a sensor through a opaque plastic connector to the top of machine . after cleaning the hoses thoroughly and removing all the crud machine worked as it should do, hope this helps
Posted on Jan 25, 2008
  • 417 Answers
SOURCE: Zanussi ZWD1680W Front Load All-in-One... Problem:
With the symptoms you describe i would suspect a intermittent heater element fault as you are getting earth leakage current which is tripping the whole supply rather than a current overload which would just trip the socket circuit breaker. Get the heating element checked over first as this is the most likely cause.
Posted on Nov 04, 2008
barkencoa
  • 3463 Answers
SOURCE: why Prewash light is flashing?
I think you need to clean pump filter, if not at front, then remove lower rear panel of washer, locate and remove large black hose on drum ,remove and clean filter inside, remove hose onto pump and check for obstruction there as well.
Please rate my solution.
Thanks.
Posted on Nov 12, 2009
SOURCE: how to change the language
When the power is off, press and hold the 3 buttons marked with L in the user manual.
Posted on Sep 01, 2011
Ariston artxf 129 error f02
F02: Blocked Motor, Short-circuited/Open Tachometry
Overhaul CNE
Overhaul Motor connector
Control CNE Continuity/Motor Connector
Control Motor Windings
Control Tachometry Windings
Replace Card
Dado
Jun 04, 2014 | Ariston Technologies AW 129 NA Washer With...
Error code h20
The washing machine fails to load water (The wording H20 is
displayed).
• The water inlet hose is not connected to the tap.
• The hose is bent.
• The water tap is not turned on.
• There is a water shortage.
• The water pressure is insufficient.
• The START/RESET button has not been pressed.
Dado
Mar 26, 2014 | Ariston Technologies AW 129 NA Washer With...
Front load Whirlpool washer will not fill with water this happened once while under warranty and it was some kind of senser that was out I think it is the sensor again but do not know what sensor
Hi, this could be a faulty door lock. If the washer is put on a spin cycle does it burst into life? If yes then door lock is fine. If no movement then this may just be a bad connection on door sensor (clean contacts) or it may need new door lock.
Mar 02, 2014 | Ariston ARWDF 129 NA 23" Washer-Dryer...
How to change the language at Hotpoint Ariston ARMXXD 129
May 20, 2011 | Washing Machines
Oo not know how to set wash cicle
Here is a link to the manual.
http://safemanuals.com/314159.php?k=0d3ef80b9dcedf87e0b970e74fe7b777&ID=2332433&q=HOTPOINT-ARISTON%20WF860&cM=-1
Mar 18, 2010 | Hotpoint Ultima WF840 Front Load Washer /...
Zanussi IZ12 Front Load Washer Logo
881 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
