Question about Dryers
Brand New Whirlpool Duet 9450 Error Code PF
In January, our Whirlpool Duet dryer would not Start after being out of town for a week. It would come on, but it displayed the PF error when you press start. Repair guy came out and Whirlpool said that it was the Motor. He changed the motor. That didn't work. Whirlpool said that it was the control board. He changed it and it worked fine for 6 months. 2 weeks ago the same error happened. The Whirlpool Duet Dryer will come on, but when you press Start is turns off and displays the PF error. The circuit box isn't tripped. I can turn it on again and it will do the same thing over and over. Whirlpool tech line said that it was my power supply. Repair guy didn't believe him and ordered a new control board since it fixed the same error that I'd had 6 months before. The part order tripped my warranty and they decided to replace the entire dryer with a new unit since mine was only 18 months old and under the extended warranty. They delivered a new unit on Thursday. Same problem. The delivery guys said it was an electrical problem. Electrician came out and found no problems with my electricity. Good voltage and our house is only 9 years old. Appliance store delivered another dryer this morning. Still getting the PF error. Delivery guy said that I probably need to have the electrician change out the power cord to a 4 prong outlet with a higher gauge wire to the breaker box. Does this sound like it will work?? This is so frustrating!!!!!!!!!!!!
    President:
  • 1,714 Answers
This is a problem I've seen before, or something similar. I think you've got a bad connection on the neutral wire. Either in the plug or at the panel. Have electrician check the neutral wire back to the panel from the plug.
Posted on Jul 25, 2009
I have a whirlpool duet # gew9250pw1 it won't
my whirlpool dryer has power but does not start
Jul 02, 2011 | Whirlpool Dryers
My whirlpool dryer is getting an error code pf. What does that mean?
Here is a tips that I wrote that will help to explain why you get the PF Error Code
PF Error Code for Appliances
heatman101
Jul 19, 2010 | Whirlpool WED8300S Dryer
PF Code as soon as try to start dryer, you get the code when select the time
heatman101
p[[p
Mar 14, 2010 | Whirlpool WED6200S Electric Dryer
Whirlpool dryer duet sport MOD WED8300SW error message
I have a whirlpool duet sport electric dryer with an error code of F 26.
Mar 02, 2010 | Dryers
Whirlpool duet dryer error code pf
The error code means that the unit suffered from a power failure.just make sure that all the wiring is good there is nothing loose and the circuit breaker is in good shape you should be able to turn off the dryer unplug it for a few minutes and the plug it back in this should clear the fault code.
Feb 26, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Error code pf
PF - Power Failure - PF error code indicates a power failure during the dryer's cycle. Press and HOLD start to continue the cycle, or press off/pause to clear display.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 01, 2010 | Whirlpool Duet 3.8 cu. ft. Front Load...
Whirlpool duet gas dryer PF error will not reset as per manuals
Mar 28, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
PF Code on Duet Electric Dryer
just press cancel ..pf means power failure ..if still not clearing probably control
Aug 15, 2008 | Whirlpool GEW9200L Electric Dryer
Whirlpool Duet Electric Dryer will not get hot
Here are the source codes that pop up on the dryer with the "fix" PF Power failure "PF" flashes to indicate that a power failure occurred while the dryer was running. Press HOLD TO START to continue the cycle, or press OFF/Pause to clear the display. E1 Thermistor open Replace thermistor if found defective E2 Thermistor shorted Replace thermistor if found defective
Sep 12, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Dryers Logo
448 people viewed this question
Top Dryers Experts
