Question about Aiwa NSX-A777 Shelf System
Tape deck problems Aiwa CA-NSX777
Dual tape stations. Put tapes in both and neither would play. Book tells me to turn off pause on tape2, it's on but I can't turn it off. From Sony folks they told me to unplug for 1 minute and plug back in. Didn't work. I could hear a clicking sound on tape1 like it's trying but then nothing. Arrow light bounces back and forth, forward and reverse. All this until tape1 door will not open now. A tape is in there and I assume it's stuck.
Don't have a clue.
  • 10,594 Answers
Tape drive mechanism requires service (cleaning and lubrication) and might need replacement of drive belts. Of course its qualified tech job.
Posted on Jul 25, 2009
Kenwood KX-79 CW dual cassette hook up?
Just connect the deck via tape 1 the out of the deck going to the in of the amp. While the out of the amp goes to the in of the deck.
The tape deck itself will automatically choose the player that plays the cassette. One will play the other will be on pause (if you press both play buttons) till the tape stops then the other will play. For recording from tape to tape one deck will be the copy and the other the copier. There should be a dubbing button which you press to record tape to tape. Some models have a high speed dub also. For recording from the amp unless both decks have record buttons you will only be able to record with one deck. Make certain the dub button is not set.
Dec 25, 2013 | Kenwood Audio Players & Recorders
Technics M14 cassette deck has hum. Bought used and had hum but I got it to go away by switching the tape select dial to metal,etc. but hum came back later. I'm thinking ground or a wire to that switch. ...
If the hum is audible without monitoring a tape playback it has nothing to do with the oxide formulation or any aspect of the media.
Determine the conditions present whenever the hum is present:
Player just turned ON?
Tape deck Playing or Paused?
Tape deck Recording or Paused?
"Tape" selected at the receiver?
Any source selected?
What switch are you referring to? You could have a floating ground or shield through a Tape Monitor or other control. Audio cables between the Deck and the receiver could be faulty or require reseating with a twisting motiuon to remove oxide build-up.
Hum can enter any unshielded cable running near any motor, magnetic field or some light sources. Sometimes simply reversing the polarity of an AC power cord will cure it.
Feb 02, 2011 | Yamaha KX-393 Cassette Deck Dual Cassette...
I need to know how to record 1 tape onto another tape on a Technics rs tr-575 dual cassette deck
press the synchro start button, the tape deck should now go to REC PAUSE, press the SPEED button till you get the required recording speed then press the synchro start again and it should start to record from deck 1 to deck 2.
make sure the tabs at the top of the tape you want to record on are intact,
if not just put a bit of sticky tape over holes.
hope this helps?
Feb 05, 2010 | Technics RS-TR575 Single Dual Cassette...
How do I record from one tape deck to the other?
Put your "blank" in the deck with the record button, normally red button and press rec/play and pause at the same time, put your "origional" in the other deck and press play and pause at the same time, then un-pause both at the same time. Make sure that the hifi is set to tape as if you record tape to tape when listening to radio foe example, you will get a strange "mix tape" of your origional and the radio.
Jun 05, 2009 | Audio Players & Recorders
Will not dub another tape
This site is useless. It tells you nothing.
Why does it exist?????
Jan 19, 2008 | Sony TC WE435 Stereo Dual Cassette Deck...
Sherwood 460 equalizer hook up
Connect the EQ to the Sherwood as if it were a tape deck: EQ's outs connect to receiver's tape ins (play) and EQ's ins connect to receiver's tape outs (record).
Then you hook the tape deck up to the tape ins and outs on the EQ: Tape deck outs connect to EQ's tape ins (play) and tape deck ins connect to EQ's tape outs (record).
This will put the EQ in your receiver's tape loop.
The CD player should be connected to the receiver though the CD in's and out's (or if your Sherwood doesn't have a CD in/out, then use AUX or TAPE2).
To hear the EQed signal with all receiver sources (like the CD player) you'll need to engage the 'Tape Monitor' button or switch which will route the tape loop to the speakers.
Jan 09, 2008 | Audio Players & Recorders
Tape decks playig too fast
Hi I can probably tell you what is wrong, but there is usually not much you can do except take it to a shop and have the motor replaced. I most cases there is a hole in the back of the cassette capstan drive motor, or on a small circuit board close to the motor where the speed is adjusted at the factory. You could possibly adjust the speed by ear until it sounded right playing a factory recorded tape with a song you know well, but I recommend these adjustments be left to a tech with a frequency counter. Also, these adjustments normally never need to be touched unless replacing a motor, so it is likely something internal has gone wrong with the motor, and it should be replaced under most circumstances. Hope this helps, Good Luck.
Sep 27, 2007 | Aiwa CA-DW50 Cassette/CD Boombox
Teac A-21 Stereo Cassette Tape Deck turns un, but won't play cassette tapes...
very likely that the drive belt has broken. I have fixed a TEAC myself using a large O-Ring from a hardware store (I know I was lucky to find a very close match). Open the unit and find the broken belt and take it to a hardware store to "size up" a replacement. Use the opportunity to oil the gear shafts and clean the rubber pinch roller.
Jun 22, 2007 | Teac DUAL CASSETTE A/R 110/220 Single Dual...
Aiwa NSX-A777 Shelf System Logo
455 people viewed this question
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
