Question about Westinghouse Computers & Internet
My westinghouse lcm-17v2sl is showing a yellow tint sometimes
  • 61 Answers
Check the pins in the cable and make sure the cable is securely connected. If one pin gets bent, you can get odd colors. Might even try a new VGA cable.
Posted on Jul 25, 2009
My westinghouse LCD LCM22w3 is not turning on. The switch light will turn on for a few seconds but then turns off. I have no imput signal
Helo,
This is a very common problem with the LCM-22W3 monitors. The problem is caused by a failure of the filter capacitors in the power supply board. Here is a link to a repair guide that shows how to open the unit and what to look for and replace to repair the monitor. This is a very easy repair.
http://www.ccl-la.com/blog/index.php/repairing-the-westinghouse-lcm-22w3/
Jan 26, 2013 | Westinghouse Computers & Internet
Not turning on
Check the capacitors on the power supply board in the unit. This is a very common problem with this unit but it is easy to repair. Here is a link to a repair guide that shows how to open the monitor and what to look for.
I hope this helps.
May 20, 2012 | Westinghouse Electric LCM-22W3 22 inch LCD...
My monitor Westinghouse Mod# LCM-19v5
The most common thing that causes no power or a blinking power light and no picture is a failure of the power supply board. The board can be repaired and the monitor will be as good as new. To repair the board you just need to replace a few parts called capacitors. Here is a link to repair information on the Westinghouse LCM-19V5
http://www.ccl-la.com/blog/index.php/repairing-the-westinghouse-lcm-19v5/
I hope this helps, if so please rate my solution.
Oct 21, 2011 | Westinghouse LCM-19v5 Monitor
My Westinghouse LCM 22w3 was working great with full res at 19xx x 16xx. Now it is no longer recognized by my Windows Vista system. In Device manager, the monitor shows as a General PnP 17" with res...
I suggest you test your computer by using a different known good monitor. If it works ok you will know your Westinghouse has a fault and if it doesn't you will know there is a problem with your computer (video card maybe?)..
Sep 29, 2017 | Westinghouse Electric LCM-22W3 22 inch LCD...
Westinghouse Model: LCM-17v2 SL DC Input : 19V === 2.6A S/N: W17C I need a power cord. Westinghouse Monitor Model:LCM-17v2 SL DC INPUT : 19V === ...
Hello Mike, you can order the adapter by calling the Westinghouse parts department at the toll free number 1800-701-0680 and selecting option 2 for parts. You can also send me a request for the part to westytech@westinghousedigital.com.
Aug 21, 2010 | Westinghouse Electric LCM-17v2 17"...
Westinghouse model LCM 17V2SL what type of wire is needed to get speakers to work?
You need stereo mini phone plug male-to-male, one end goes into audio line out (green) on the PC sound card, the other end goes into audio line in on the monitor jack (green). then you need to set the volume control PC and at the monitor. You can get the cable from Radio Shack.
Mar 05, 2010 | Computers & Internet
Need power cable for a westinghouse LCM-19v1 SL monitor
We carry the power cords for this model at our web site at:
www.ccl-la.com
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Oct 17, 2009 | Westinghouse LCM-19v1 Monitor
Can't find correct setting for westinghouse lcm22w2 monitor
I don't know if this actually will fix your problem, but all LCM 22w2's are plagued with the 'white screen of death' and eventual power shutoff, including garbage characters and faulty menu, video output, etc. Here's how I fixed it.
The Westinghouse LCM 22w2 has bad capacitors on the yellow power supplyboard. This is a common problem plaguing motherboards and LCDflatpanels that use capacitors from Taiwan. If you know how to solder,or know somebody that can, it's actually a pretty easy fix. Take outthe yellow circuit board on the inside, write down the specificationsfor each of the capacitors (the cylindrical things) go to theelectronics supply store and get the replacement capacitors. You can goover the voltage specification (not under), but keep the capacitancevalue matching. Replace one at a time. Go to www.badcaps.net foradvice, tutorials and training on doing this. *You really shouldreplace all the capacitors*, but the very large one next to the powerplug I did leave on the board because I couldn't find a match. To mydelight, the white screen of death went away and it was working as new!
I saved a ton of money fixing this, it's definitely worth learning how to solder to do this.
http://www.ctcco.com for professional hosting solutions
Jan 07, 2009 | Westinghouse LCM-22w2 Television
Monitor shuts off for a few seconds when i play games or watch videos.
I fixed it! It's the power supply board. The bad news is you need to solder.
The Westinghouse LCM 22w2 has bad capacitors on the yellow power supply board. This is a common problem plaguing motherboards and LCD flatpanels that use capacitors from Taiwan. If you know how to solder, or know somebody that can, it's actually a pretty easy fix. Take out the yellow circuit board on the inside, write down the specifications for each of the capacitors (the cylindrical things) go to the electronics supply store and get the replacement capacitors. You can go over the voltage specification (not under), but keep the capacitance value matching. Replace one at a time. Go to www.badcaps.net for advice, tutorials and training on doing this. *You really should replace all the capacitors*, but the very large one next to the power plug I did leave on the board because I couldn't find a match. To my delight, the white screen of death went away and it was working as new!
Dec 16, 2007 | Westinghouse LCM-22w2 Television
Computers & Internet Logo
Top Westinghouse Computers & Internet Experts
Jim Goldsmith
Jim Goldsmith
cxbxr_3
cxbxr_3
Level 1 Expert
Are you a Westinghouse Computer and Internet Expert? Answer questions, earn points and help others
